3.4L supercharger
Discussion in '1st Gen. Tacomas (1995-2004)' started by CHMM, Sep 14, 2019.
  1. Dec 21, 2021 at 11:00 PM
    #3841
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    You guys have much more reception to turbos - that's better in my book
  2. Dec 21, 2021 at 11:04 PM
    #3842
    YotaGangYotaGang
    YotaGangYotaGang PreRunners are wannabe 4x4’s
    Covina
    95, 97, 01 Tacoma | 06 Tundra | 07 FJ Cruiser | 08 Prius
    A rtt i never use and 30 light bars
    is is carb legal in LA
  3. Dec 21, 2021 at 11:06 PM
    #3843
    treyus30
    Trey
    Mesa / AJ, AZ
    Breathing too much oxygen is illegal there
    Milor likes this.
  4. Dec 21, 2021 at 11:11 PM
    #3844
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    they support OBDII codes if you program them in (or something like that) but they're not OBD emissions legal.
  5. Dec 21, 2021 at 11:12 PM
    #3845
    treyus30
    Trey
    Mesa / AJ, AZ
    Hmmm... annoying
  6. Dec 21, 2021 at 11:15 PM
    #3846
    Empty_Lord
    Dan
    tis the way of emissions.
    now the 93 mr2? a haltechs fine as long as it passes the sniffer.. go figure.
  7. Dec 22, 2021 at 7:33 AM
    #3847
    1997tacomav6
    Denver
    I’ve had mine running for 3 years without any issues
    Digiratus[QUOTED] likes this.
  8. Dec 22, 2021 at 7:38 AM
    #3848
    1997tacomav6
    Denver
    Well if your Colorado and want to go for a drive let me know.
    You will have a perfect AFR all the time with much better timing numbers and a much better power curve.
  9. Dec 22, 2021 at 7:44 AM
    #3849
    1997tacomav6
    Denver
    Haltech has its own system that will throw a check engine light that shows up normal on the dash but you use the computer to see what the light, code is and to clear it
    treyus30[QUOTED] likes this.
  10. Dec 22, 2021 at 8:06 AM
    #3850
    1997tacomav6
    Denver
    8 months ago or so I stumbled across the haltech and the 3.4.
    Didn’t know anything about it.
    I searched google and forums and ran across SNPSPEED.
    Even there I didn’t find much for results.
    I saw the packages he sells and the custom harnesses me makes for the 1st gens.
    I rolled the dice because I could not find anyone that could give me results with the haltech and the 3.4 supercharged.
    my biggest frustration was with my methanol my AFR were never consistent and I had to be consistently monitoring the system and making adjustments.
    And my open loop power coming on at 3k on day and another day at 4k.
    It has its own mind when it wants to kick in. Now that power comes on instantly with a perfect AFR that is set.
    So I’m putting this info out there so others can see if it fits for them.
    It’s definitely the silver bullet for a perfect tune with full support and tuning your truck.
    The power is in your tune!
    With the haltech you can control EVERY aspect of your ECU, from timing to fuel map to injectors, multiple maps, no MAF to deal with or open loop closed loop to fight with and
    is the state of the art with full support , not some 20 year old CD 7th injector setup with limited functionality and little support.
    The 2 dyno graphs I showed on top of each other we’re done back to back, one with the haltech, one with the stock ECU 5 minutes apart and the truck still was not tuned at 100 percent.
    It is expensive so it’s not for everyone but wish I had known about this option years ago.
    I’m doing the leg work on what to do and not do and what works best here.
    Your 3.4 turbo or supercharged will run the best it ever has with a haltech! No if ands or buts.
    treyus30[QUOTED] and Digiratus like this.
  11. Dec 22, 2021 at 9:08 AM
    #3851
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    I feel for you man. Emissions testing and inspections tie your hands on what you can do legally for sure. I feel very fortunate that Washington State stopped all that shit as of 1/1/2020. I have already deleted the upstream CAT and it allows me to do the Haltech without having to worry about it. Eventually, I may delete the downstream CAT too. It is the last 'restriction' in my exhaust system.
    1997tacomav6 likes this.
  12. Dec 22, 2021 at 9:11 AM
    #3852
    1997tacomav6
    Denver
    Switching back and forth is a breeze, a whole 5 minutes at the most:)
  13. Dec 22, 2021 at 9:16 AM
    #3853
    Empty_Lord
    Dan
    The swapping is easy. It’s getting all the monitors to set after. The aftermarket cats are meh. Take FOREVER to set catalytic monitor.
    I’m trying to figure out what loop hole I managed to find with my 05 tundra. Still never needed emissions to get plates since I’ve owned it
    1997tacomav6[QUOTED] likes this.
  14. Dec 22, 2021 at 9:36 AM
    #3854
    1997tacomav6
    Denver
    So why don't you just use the test pipe then swap back for testing=15 minutes or less,
    I'm not sure what monitors you have besides 2 cat sensors plugs down stream,
    If its those they can be tied off removed and a plugged for the holes with a bolt
  15. Dec 22, 2021 at 10:47 AM
    #3855
    Empty_Lord
    Dan
    The catalytic monitor happens during a drive cycle. Usually takes 80-100 miles. But with my cats being border line for a while now they would usually take 1-2k miles to set the monitor
  16. Dec 22, 2021 at 10:55 AM
    #3856
    TMFF
    TMFF Well-Known Member
    Tim
    Thornton, CO
    01/02 DCLB
    Stuff and junk and things...
    It's not a PWM fuel pump so when the truck is running the pump is running at 12V and full volume all the time. Key on engine off will cycle the pump until a ignition signal is present. The regulator is what is setting the rail pressure.
    Again it's not wrong to run a high LPH pump and will keep the fuel cooler in theory but for the 300ish HP that this engine with a small pulley puts out a 165+LPH pump is sufficient.
    This is a great explanation of volume VS pressure.
  17. Dec 22, 2021 at 10:14 PM
    #3857
    1997tacomav6
    Denver
  18. Dec 22, 2021 at 10:15 PM
    #3858
    Empty_Lord
    Dan
    How much power is it putting down these days with the haltech ( I’m sure I missed your post with as hectic as works been for me)
    unstpible and 1997tacomav6 like this.
  19. Dec 23, 2021 at 6:42 AM
    #3859
    1997tacomav6
    Denver
    Hopefully January I will get a new dyno done after the methanol map is tuned.
    The haltech strongest improvement is the new power in the lower rpm’s that comes on right away.
  20. Jan 1, 2022 at 6:22 PM
    #3860
    ForestRunnerFrank99
    ForestRunnerFrank99 Well-Known Member
    Josh
    Rancho Cucamonga, CA
    '99 TRD 4x4 Manual 3.4l v6
    Fox Coil-overs, Dakar Leafs, Intake, Tires, Rims
    Can someone more experienced then me rate these rotors:
    I found an old guy who doesn't want his gen 1 supercharger any more due to him being old. He said it's mine for a really really good price. I'm just wondering how these Rotors look cause it does have 370k miles on it.
    unstpible likes this.
