3.4L supercharger
Discussion in '1st Gen. Tacomas (1995-2004)' started by CHMM, Sep 14, 2019.
  1. Sep 16, 2019 at 7:47 PM
    CHMM
    CHMM [OP] GTO
    Gabe
    Castle Rock, Colorado
    2001 TRD Xtra Cab 4x4 Supercharged
    5100s SPC UCAs Energy bushings #70 spring clutch mod Supercharged
    Ok. Thanks for all the feedback. I picked one up!!!! I’ll circle back with photos and reviews. YOLO...
    Maximo_23, 1997tacomav6 and otis24 like this.
  2. Sep 16, 2019 at 8:31 PM
    1997tacomav6
    Denver
    Got a meeting setup for tomorrow with you at 7am, I think you will be pleased with what a supercharger can do after your test drive :)
    04yota and CHMM[QUOTED][OP] like this.
  3. Sep 16, 2019 at 8:33 PM
    CHMM
    CHMM [OP] GTO
    Gabe
    Thank you!!!!
    1997tacomav6 likes this.
  4. Sep 17, 2019 at 7:38 AM
    1997tacomav6
    Denver
    Well we meet up and he took my truck for a drive.
    I think he’s definitely sold on how a 600,000 mile supercharger can transform the 3.4 motor. :)
    Nice meeting up with you and let me know when it’s installed.
    Remember to make sure you use a gates supercharger belt when you install it.
    The others will not last including the Toyota belt.
  5. Sep 17, 2019 at 9:54 AM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    Hey John is it true that they sort of "overbuilt" this 3.4's internals to accept a SC? I always wanted confirmation on this point and figured you're the guy who knows these things.
  6. Sep 17, 2019 at 9:57 AM
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    You don’t need the fuel pump so we can just stop the nonsense right here
  7. Sep 17, 2019 at 10:23 AM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    If he's just putting the supercharger on and running it stock then he might not need anything if he's lucky. But if he has a ping happy engine like some of us do then fuel mods/upgrades are a must. Really just depends on his setup and engine.
    I will say though to avoid the Walboro 190lph pump that URD sells and includes with the 7th injector...it whines like a stuck pig.
  8. Sep 17, 2019 at 10:30 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Great contribution
    camillethetoy likes this.
  9. Sep 17, 2019 at 11:00 AM
    TashcomerTexas
    Coming from someone that actually runs a s/c installed after 200k. Yeah.
    mechanicjon likes this.
  10. Sep 17, 2019 at 11:06 AM
    TashcomerTexas
    If you’re going to run the 7th injector alone that’s ample enough delivery for fuel to avoid ping.
  11. Sep 17, 2019 at 11:11 AM
    eon_blue
    Azusa, CA
    The 7th injector kit comes with a new higher flow fuel pump as part of the kit. Higher flow is needed with that kit from the added fuel demand from the additional injector
  12. Sep 17, 2019 at 11:20 AM
    TashcomerTexas
    I haven’t installed it for over 2 years and the truck is rich af so...
  13. Sep 17, 2019 at 11:54 AM
    JKO1998
    Utah
    You must be right, only option
  14. Sep 17, 2019 at 1:47 PM
    CHMM
    CHMM [OP] GTO
    Gabe
    Well we went on a ride. Thanks John! The truck is the coolest truck I’ve seen. The hood is ridiculous. The speed is ridiculous. Thanks so much!
  15. Sep 17, 2019 at 1:49 PM
    #35
    CHMM
    CHMM [OP] GTO
    Gabe
    As far as the fuel pump, I might be able to get away without upgrading. I’m using the stock pulley at 6k feet above sea level. As far as my truck, it drives right and it’s been taken care of. Like, I have a new frame on it with stickers and bar codes like the new trucks.
    otis24 likes this.
  16. Sep 17, 2019 at 1:56 PM
    #36
    CHMM
    CHMM [OP] GTO
    Gabe
    So, it’s gonna be installed at Smooth Ride In Northglenn. Tom over there worked at Stevinson Toyota West for a long long time. He’s put em on and fixed S/Cs and engines. He’s saying it will be fine. I’m swapping the fuel filter as added insurance. We’ll see what happens.
  17. Sep 17, 2019 at 1:58 PM
    #37
    eon_blue
    Azusa, CA
    Get yourself a boost and AFR gauge to go along with the supercharger, AFR is especially important to monitor and you need an aftermarket wideband gauge to read it properly. Will let you know if you're running too lean or too rich, and these engines love to run lean when boosted. Too lean will kill the engine in no time
  18. Sep 17, 2019 at 1:58 PM
    #38
    CHMM
    CHMM [OP] GTO
    Gabe
    Does this belt come with the kit or do I have to pick it separately? Thanks
  19. Sep 17, 2019 at 1:59 PM
    #39
    CHMM
    CHMM [OP] GTO
    Gabe
    Which one do you recommend?
  20. Sep 17, 2019 at 2:01 PM
    #40
    eon_blue
    Azusa, CA
    Boost gauge you can pretty much go with anything you like the look of, they're pretty basic and can range in price pretty wildly.
    AFR gauges are a little more expensive, I got mine (AEM brand) off Amazon for around $170 if I remember right. Comes with everything you need, O2 sensor, metal bung to weld to the exhaust, wiring and gauge.
    https://www.amazon.com/AEM-30-4110-UEGO-Ratio-Gauge/dp/B00N3VGPYS
    I have one of the original TRD boost gauges but unfortunately they aren't available anymore through Toyota, and hard to find used (usually pretty expensive too). I think Speedhut can custom make a TRD replica boost gauge though
    QMEDJoe and CHMM[QUOTED][OP] like this.
