3.4L supercharger
Discussion in '1st Gen. Tacomas (1995-2004)' started by CHMM, Sep 14, 2019.
  1. Oct 5, 2019 at 6:38 PM
    #381
    CHMM
    CHMM [OP] GTO
    Gabe
    Castle Rock, Colorado
    2001 TRD Xtra Cab 4x4 Supercharged
    5100s SPC UCAs Energy bushings #70 spring clutch mod Supercharged
    Awesome. I gotta go up and check it out maybe tomorrow.
    1997tacomav6[QUOTED] likes this.
  2. Oct 5, 2019 at 6:56 PM
    #382
    eon_blue
    Azusa, CA
    I don't think warming up a vehicle to operating temp is necessary these days...maybe if it's below freezing out it might be a good idea, IDK. That said, I don't think it's good to just hop in and floor it either.
    Usually what I do is I wait for my AFR gauge to read a steady 14.7 before I shift into gear and move...takes maybe 10 seconds. When I fire it up the gauge will go down to about 11 and then every couple seconds go up a point or two until it hits 14.7 and stays thereabouts (the gauge will always bounce around between ~14.4 - 14.8). I don't think it necessary or anything it just satisfies my OCD lol.
  3. Oct 5, 2019 at 7:02 PM
    #383
    1997tacomav6
    Denver
    Personally, I always wait a minute or so. If it’s below 30 degrees I wait 5 minutes
    CHMM[QUOTED][OP] likes this.
  4. Oct 7, 2019 at 1:57 PM
    #384
    CHMM
    CHMM [OP] GTO
    Gabe
    So I’m noticing that BMWs and Porsche SUVs are following me now. What’s nice is no one races or taunts me. It’s not like driving a corvette. It’s the perfect sleeper truck.
    1997tacomav6 likes this.
  5. Oct 7, 2019 at 2:31 PM
    #385
    CHMM
    CHMM [OP] GTO
    Gabe
    65A8F1A2-EE65-4B27-99DB-5965AE5888CD.jpg The 2.2 is here.
    1997tacomav6 and Robmonster117 like this.
  6. Oct 7, 2019 at 4:18 PM
    #386
    CHMM
    CHMM [OP] GTO
    Gabe
    So coming up is a dyno before with stock pulley and after with the 2.2. I think it won’t be an issue like John said. It’s the elevation. Up here there is not as much O2. So we need more air to get the same 02. So we’ll soon scientifically find out what’s up with the dyno data.
    otis24 and 1997tacomav6 like this.
  7. Oct 7, 2019 at 4:18 PM
    #387
    1997tacomav6
    Denver
    Your making progress, the items were on the desk, now they’re making their way to the floor to the truck?
  8. Oct 7, 2019 at 4:19 PM
    #388
    CHMM
    CHMM [OP] GTO
    Gabe
    LOL
  9. Oct 7, 2019 at 4:20 PM
    #389
    frenchee
    frenchee Favorite Member
    Oceanside CA Area
    2003 Tacoma TRD Double Cab 4x4
    Converted to 4WD DD VW MK6 TDI
    Damn. Awesome picture.
  10. Oct 7, 2019 at 5:33 PM
    #390
    CHMM
    CHMM [OP] GTO
    Gabe
    man if we could meet now and have you help me slap on that pulley.... I just have a record of breaking and stripping too many things. LOL.
  11. Oct 7, 2019 at 5:43 PM
    #391
    1997tacomav6
    Denver
    Can’t do it now, possibly this weekend, I just dropped my truck off to the dealer
    because my fuel trims went crazy. Either I have a vacuum leak I can’t find or a fuel pump is getting tired.
    Hopefully they fix it or find the issue tomorrow
  12. Oct 7, 2019 at 5:46 PM
    #392
    eon_blue
    Azusa, CA
    You still on the original fuel pump? Wouldn't be surprised if that's it if that's the case
  13. Oct 7, 2019 at 5:49 PM
    #393
    CHMM
    CHMM [OP] GTO
    Gabe
    Sorry to hear that man. Keep us posted. Hoping it’s minor.
  14. Oct 7, 2019 at 5:49 PM
    #394
    1997tacomav6
    Denver
    Actually no, the 1st fuel pump died at 300k and I’m at 605k,
    Long Fuel trims went from 0 to 4, to 12-24,
    So we have an issue, having a smoke test done for the vacuum leak is what Im Thinking.
    That’s the nice thing about a scanguage, you can catch a problem before it actually
    hits you head on with fuel trim info.
    eon_blue[QUOTED] likes this.
  15. Oct 7, 2019 at 5:53 PM
    #395
    eon_blue
    Azusa, CA
    Hopefully that's it and they can track it down. No check engine light? Usually a vacuum leak bad enough to make you run lean like that will trip a code
    opteron likes this.
  16. Oct 7, 2019 at 5:57 PM
    #396
    1997tacomav6
    Denver
    Yea, but usually the long term trim is above 25 before a code is trigger.
    So it’s nice to catch it before hand with the scanguage.
    Plus 24 means it’s running lean but when the methonal kicks it it’s running perfect
  17. Oct 7, 2019 at 5:59 PM
    #397
    CHMM
    CHMM [OP] GTO
    Gabe
    that’s awesome. That scan gauge is useful. It tells you. Then you drive the truck to get repaired or maintained. That’s pretty cool.
  18. Oct 7, 2019 at 6:00 PM
    #398
    1997tacomav6
    Denver
    Yea, if I didn’t have a scanguage I would have no idea about this
  19. Oct 7, 2019 at 6:01 PM
    #399
    eon_blue
    Azusa, CA
    I highly recommend something like the Scangauge or an OBDII plug-in with a scanner app on your phone. You can read all that stuff in real time and see a problem before it gets worse. Like an AFR gauge except you can monitor many things at once.
    The Scangauge is nice because you don't have to rely on using your phone, but they're more expensive.
  20. Oct 7, 2019 at 6:02 PM
    #400
    CHMM
    CHMM [OP] GTO
    Gabe
    They don’t even have those in the third gen. It seems like a must.
