3.4L supercharger
Discussion in '1st Gen. Tacomas (1995-2004)' started by CHMM, Sep 14, 2019.
  1. Apr 25, 2022 at 11:43 AM
    #4021
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Is there a recommended octane booster? I would really like to hear you guy's thoughts on what is available, what you have used and your reasoning for choosing that one.
    I have seen products from Boostane and VP Racing come recommended on TW. Are there others that might be a better choice?
    https://www.amazon.com/dp/B01C4IH6Z...colid=1P5D39KHH5V3M&ref_=lv_ov_lig_dp_it&th=1
    https://www.amazon.com/dp/B07P13524K/?coliid=ISJUIEHEFEL6T&colid=1P5D39KHH5V3M&ref_=lv_ov_lig_dp_it
    I live where 92 octane is readily available, but I also go to some remote places where 91 or higher isn't. What have you guys done when all you could get was 87 (or 85, lol) or accidentally put in the wrong one?
    Milor likes this.
  2. Apr 25, 2022 at 2:20 PM
    #4022
    m3bassman
    m3bassman Well-Known Member
    Green truck
    I have the can but never used the boostane. One word though is that shit is potent. You'll want to back it or something to contain the smell.
    Digiratus likes this.
  3. Apr 25, 2022 at 2:43 PM
    #4023
    Digiratus
    Roaming the PNW
    The RedHead
    Even unopened is has a strong odor?
  4. Apr 25, 2022 at 2:47 PM
    #4024
    ChargedSHOTaco
    ChargedSHOTaco Well-Known Member
    Boostane does not smell any different that other octane boosters. Boostane does work really well, and you can feel the truck advance the timing to get more power. It does leave a yellow deposit on your O2 sensors, not sure if the deposits are harmful. I used to run Boostane all the time when I lived in Texas the weather would get warm.
  5. Apr 25, 2022 at 4:10 PM
    #4025
    m3bassman
    Green truck
    Yeah. It's rough. Maybe mine had a slight leak, but I've not noticed.
  6. Apr 25, 2022 at 4:15 PM
    #4026
    Digiratus
    Roaming the PNW
    The RedHead
    It looks like Boostane comes in two different strengths, Professional or Premium? Which one are you using?
  7. Apr 25, 2022 at 4:57 PM
    #4027
    m3bassman
    Green truck
    Premium. I believe the professional is not for on road use.
  8. Apr 25, 2022 at 5:25 PM
    #4028
    Digiratus
    Roaming the PNW
    The RedHead
    I'm not sure I fully understand what that all means. Not that it matters, at least for how I think I might use it, it would be mostly in off road use.
  9. Apr 25, 2022 at 5:46 PM
    #4029
    m3bassman
    Green truck
    One will eat catalytic converters the other is safe for them.
  10. Apr 25, 2022 at 6:31 PM
    #4030
    Digiratus
    Roaming the PNW
    The RedHead
    If one is to believe what Boostane says on their website, this is not true. Also not true is that there is an issue with how long it keeps. The website does specify that the "pro" version is not street legal where the premium version is.
  11. Apr 25, 2022 at 7:16 PM
    #4031
    m3bassman
    Green truck
    You realize how much this went full circle I hope.
  12. Apr 25, 2022 at 7:30 PM
    #4032
    Digiratus
    Roaming the PNW
    The RedHead
    Well, I had hoped that more people would have chimed in but this has helped to clarify things for me.
    I think I am going to pick up some of the pro version of this stuff.
    ChargedSHOTaco and Bmann88 like this.
  13. Apr 26, 2022 at 9:30 AM
    #4033
    Milor
    Milor Well-Known Member
    shaun
    03 Tacoma sr5 .TrD offroad 5spd..
    supercharged 2" pulley 6 puck clutch
    I run boostane professional. I buy the 4 pack of 32oz cans for $112.00 . 2 ounces in a tank of 89 or 91 octane is enough to make the truck not ping and you can feel the difference in power. not a crazy difference but for instance a certain long hill climb in my area (the "4lanes" going to Shaverlake east of Fresno Ca.) id be going up just over 70 in 4th gear with just 91, with boostane I can easily pull them at 80 and without boostane I cant use 5th gear, but with it it cruises up in 5th
    Digiratus[QUOTED] likes this.
  14. Apr 26, 2022 at 10:57 AM
    #4034
    TMFF
    TMFF Well-Known Member
    Tim
    Thornton, CO
    01/02 DCLB
    Stuff and junk and things...
    I haven't felt the need for them if your tune is in the ball park. I even road tripped from Denver to Montana all on 87 with no issues. I even ran flat out up some passes to see if it would ping but nothing at 10 psi and 11.5ish AFR.
    I have used Torco while racing in Baja in a bronco that runs on pump gas. It worked as advertised, read the fine print as some of those raise the octane 0.1 points with doesn't help you at all besides lightening your wallet.
    https://torcoracefuel.net/products/torco-accelerator
  15. Apr 26, 2022 at 1:07 PM
    #4035
    Digiratus
    Roaming the PNW
    The RedHead
    Are you running it in ever tankful? Acording to their chart, 2 oz of pro adds about 1.5-2 octane. Does that seem about right to you?
    Wow, that is impressive. That's wiith a standalone is it not. Haltech?
  16. Apr 26, 2022 at 1:10 PM
    #4036
    TMFF
    Tim
    Thornton, CO
    01/02 DCLB
    AEM FIC6
  17. Apr 26, 2022 at 1:19 PM
    #4037
    Speedytech7
    3435 E Trent Ave, Spokane, WA 99202
    It's less Tacoma and more mod
    I take it you're running pretty reserved timing then huh? We were gonna build a turned down tune for Mike on 87 when he doesn't want all the power on tap and would prefer to burn the cheap stuff.
  18. Apr 26, 2022 at 1:41 PM
    #4038
    TMFF
    Tim
    Thornton, CO
    01/02 DCLB
    IIRC the AEM only retards timing and I'm pulling maybe 1-2 degrees at high boost. The Factory computer is pulling the rest VIA knock sensors.
  19. Apr 26, 2022 at 1:50 PM
    #4039
    Speedytech7
    Yeah that tracks with what I observed with the stock ECU too, it pulls a ton out of the base map. We have the ability to trim what the knock sensors read and analyze it which is nice. Right now with the Haltech and no stock computer, it is programmed to be 15-17 degrees advanced at WOT up to 7psi, but it can advance or retard from there based on the severity of knock events and that's been programmed into the knock compensation map. First counts of knock it richens a bit before pulling a ton of timing to see if that resolves. If it detects more severe knock it can retard more.
    You kind of put yourself into a lower power feedback loop runnin 87 with SC on stock computer (even with AEM) though since you'll see more of the knock events that cause the stock computer to start reacting. Each degree of advance is worth roughly 10hp so it's not a metric to shrug off in favor of more boost. I'd rather run a couple less psi and run more timing advance.
    Digiratus and unstpible like this.
  20. Apr 26, 2022 at 1:53 PM
    #4040
    galaxyz
    galaxyz Well-Known Member
    2016 Tacoma TRD Off Road
    Stock ecu?
