3.4L supercharger
Discussion in '1st Gen. Tacomas (1995-2004)' started by CHMM, Sep 14, 2019.
  1. May 1, 2022 at 12:47 PM
    #4061
    Milor
    Milor Well-Known Member
    shaun
    03 Tacoma sr5 .TrD offroad 5spd..
    supercharged 2" pulley 6 puck clutch
    did that sensor stop the check engine light? I am having that problem right now on my Truck. I have the shorty Jba headers and am also catless. I tried using the urd sensor thing that plugs into the rear 02 sensor but it hasn't stopped it from tossing the generic 02 light. If Im running the truck hard and driving like I stole it The truck won't throw a code but if i'm cruising slow or idling at a light it will throw the code. It also has brand new 02 sensors and also has the air fuel sensor and the trucks afr's look good
    unstpible likes this.
  2. May 1, 2022 at 1:56 PM
    #4062
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    What is the code you get?
  3. May 2, 2022 at 12:29 AM
    #4063
    Milor
    shaun
    I'll have to see what the code is tomorrow. All it says though is something about generic. nothing about low/high voltage or faults.
  4. May 2, 2022 at 10:01 AM
    #4064
    Digiratus
    Roaming the PNW
    The RedHead
    There are several codes related to O2 sensor functions, some are for the upstream sensor and some are for the rear one. And how you 'fix' them depends on which one(s) they are. Let's see which one you are getting.
  5. May 2, 2022 at 11:22 AM
    #4065
    Milor
    shaun
    its po136 for the rear 02 sensor. Its brand new. I'm thinking its an exhaust leak. The fit of the JBA headers is terrible and they never stay tight.Pretty sure thats it. this weekend I tightened everything up on the exhaust and it ran so much better for a few hours.I'm betting I already have an exhaust leak again.
  6. May 2, 2022 at 12:36 PM
    #4066
    Digiratus
    Roaming the PNW
    The RedHead
    Did you say you have no CATs? I would expect the P0420 code if that were the case. FWIW, the URD sensor defeat system only applies to the P0420 code.
    I am pretty sure that our ECUs do not rely on any data or feedback from the downstream sensor for tuning. I think your P0136 code is coming from the upstream O2 sensor.
  7. May 4, 2022 at 2:55 PM
    #4067
    Milor
    shaun
    I ended up having an exhaust leak after I fixed that it stopped throwing the code.
  8. Jun 12, 2022 at 8:16 PM
    #4068
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    Anyone running the GM knock sensors, did it do anything for you beyond cure a CEL? I believe my truck is pulling timing and I don't know why - a battery reset gives noticeably more power and response. No active CEL. Chasing bad fuel economy.
    Would like to try reducing knock sensitivity but the GM KS seems like an unpopular mod and doesn't come well recommended, but it's my only bet before diving into a Haltech, which will have to wait until at least tax refund season.
  9. Jun 12, 2022 at 10:41 PM
    #4069
    Digiratus
    Roaming the PNW
    The RedHead
    Crank knock sensor? Why go with a GM one?
    I know the Toyota one is $$$, but why not consider an aftermarket Denso? It's what I just did.
  10. Jun 13, 2022 at 12:00 AM
    #4070
    treyus30
    Trey
    Mesa / AJ, AZ
    Not a crank sensor...
    The GMs are apparently less sensitive or looking for a different frequency to detect knock so they allow more timing advance. Hard to find technical info on it though and admittedly it's a bit sketchy
    Digiratus[QUOTED] likes this.
  11. Jun 15, 2022 at 10:08 AM
    #4071
    Rldanie
    Rldanie Punisher78
    Colorado
    2002 Supercharged, 2” pulley, FIC, Methanol, Transgo Shift Kit
    Engine Performance upgrades: Supercharged (Magnuson) FIC/6 Champion Radiator Toyota Corolla thermostat 168° JBA Headers JBA cat back exhaust Upgraded fuel pump Volant Cold Air Intake With custom plexiglass cover TransGo Transmission A340F Valve Body upgrade B&M Transmission cooler Methanol Injection 2 inch pulley Future Plans Supra Injectors Light weight crankshaft pulley Leather seats Off-road upgrades 3” rough country lift 33x12.5” Dick Cepeks Other upgrades: JL Audio 12W6 Sub in custom box JL Audio C5 Mids and tweets all the way around Sound dampened whole cab Transmission temp sensor Gen Tex rear view mirror (temp and compass) Blue instrument panel, a/c control panel lights, shifter, ashtray, glove box. Blacked out badges Blackout bumpers and grill MariMoto Projectors with demon eyes LED Taillights Second generation leather steering wheel with audio controls Custom leather wrapped automatic transmission shifter 3rd gen 4 Runner key ring light (blue) 3rd gen 4 Runner hood scoop
    Anyone have an extra seventh injector plate?
    blank one
  12. Jun 15, 2022 at 10:16 AM
    #4072
    1997tacomav6
    Denver
    Block off plates available at LCE under EGR plates
  13. Jun 21, 2022 at 9:34 PM
    #4073
    Milor
    shaun
    my truck did not like the stock knock sensors. the gm cured my problems and is letting me have more timing than the aisin sensors
    treyus30[QUOTED] likes this.
  14. Jun 21, 2022 at 9:36 PM
    #4074
    Milor
    shaun
    just saw your truck race the trx in the TFL video. It smoked the newer taco and sounded so good! is that before or after the haltech?
    1997tacomav6[QUOTED] likes this.
  15. Jun 21, 2022 at 10:34 PM
    #4075
    treyus30
    Trey
    Mesa / AJ, AZ
    Awesome, good to hear.
    Milor[QUOTED] likes this.
  16. Jun 22, 2022 at 4:43 AM
    #4076
    1997tacomav6
    Denver
    Thanks, yes it smokes the new Tacoma, Tundra (turbo v6 not sure yet ) and 4 runners all day long easily.
    Was before haltech and was running like shit that day, was way too rich with the methanol.
    TRX has 700hp! 8 speed transmission and 90,000.00 being sold now as used.
    Highly doubtful you will ever see one with 700,000 miles tho :))
    Soo glad those stock ECU days and tune issues are behind me :).
    Haltech is definitely a game changer for more power and a perfect tune.
    unstpible and Milor[QUOTED] like this.
  17. Jun 22, 2022 at 10:51 AM
    #4077
    04TrDtAcO4x4
    04TrDtAcO4x4 Well-Known Member
    2003 Tacoma
    Got a link to the video?
  18. Jun 22, 2022 at 5:52 PM
    #4078
    01Montaco
    01Montaco Well-Known Member
    Matthew
    Montana
    2001 Red Tacoma TRD SR5
    Anyone know what the rough lead times are on a new Magnuson unit? I know they were out of rotor packs for awhile and waiting on a shipment from Eaton.
  19. Jun 22, 2022 at 9:00 PM
    #4079
    ChargedSHOTaco
    ChargedSHOTaco Well-Known Member
    This right here sums it up. Once you have the Haltech, you can move on to the next upgrade. Unlike the URD 7th kit where you are chasing something that isn’t possible.
    I wasted a lot of time on the URD 7th, I’m just glad I was able to sell it for a good price when I got rid of it. :rofl:
  20. Jun 23, 2022 at 10:12 AM
    #4080
    Milor
    shaun
    I realized after I asked about the Haltech that when it showed under you stereo that it was in open loop. Like I commented in that video, The Tacoma is way cooler and way more reliable than a super heavy dodge with 700hp. Everyone I know with dodges have so many problems with cheaply made parts falling apart. your right none of those dodges will make it as long as your taco, and no way that platform could be worked daily like your truck. In my eyes The only good dodges were the ones with cummins paired with the manual trans. The Haltech is on my bucket list. So tired of my Truck driving and shifting perfect only when the stars align.
