3.4L supercharger
Discussion in '1st Gen. Tacomas (1995-2004)' started by CHMM, Sep 14, 2019.
  1. Jun 14, 2023 at 11:00 AM
    #4301
    tkos
    tkos Well-Known Member
    Tommy
    Orange County, CA
    1996 Tacoma 4x4 3.4L
    I have been diligently reading this thread. So if the motor seems to run lean/ ping why not just add higher flow injectors instead of a 7th or Meth? Please forgive me if this is a dumb question. Just trying to learn.
    on page 50, and still reading. maybe it has been brought up and answered
  2. Jun 14, 2023 at 11:21 AM
    #4302
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    The short answer is the OEM ECU does not allow you to just add fuel or timing. It's main purpose is to give you the best possible fuel mileage. So any fueling changes you make the ECU will compensate by leaning out the mixture and pulling timing.
    To be able to over come this limitation you have to trick it into thinking it is still in charge and doing it job. This is where piggy back systems like the 7th injector or stand alone systems like the Haltech come into play.
  3. Jun 14, 2023 at 11:45 AM
    #4303
    tkos
    Tommy
    Orange County, CA
    @Digiratus Thanks. So there is no way to reprogram the stock ecu? I guess people would have done that by now if it was possible. I'm still trying to wrap my head around engine controls, etc. My truck is a 96 and came with a supercharger. It blew a valve, and I installed a rebuilt motor as a known good. When I put the new motor in I didn't install the SC, but Im getting the itch to put it back on (provided it is done correctly).
    I'm really trying to absorb everything I can to make it a reality.
  4. Jun 14, 2023 at 11:47 AM
    #4304
    eon_blue
    Azusa, CA
    I thought the 95.5/96 years couldn't run the supercharger because of their ECU, does yours have the 97 ecu swapped in?
  5. Jun 14, 2023 at 11:50 AM
    #4305
    tkos
    Tommy
    Orange County, CA
    @eon_blue After reading a bunch I have learned that the 95.5/96 ECU don't seem to be compatible, but that didn't stop the previous owner from trying. I have another ECU that came with my JDM motor that I rebuilt. Ill have to check it to see what year it is from. Even still is Toyota ECU incompatible with the SC. What would I have to do provided that the ECU is from a 97 and on Tacoma. Is this where the piggy back comes in? Im at sea level so I assume I have to run the Stock Pulley, What size is that?
  6. Jun 15, 2023 at 11:36 AM
    #4306
    Digiratus
    Roaming the PNW
    The RedHead
    I'm a little surprised that other supercharged '96 owners haven't commented here. Others have definitely done it.
    The stock size pulley is 2.37" in diameter.
    tkos[QUOTED] likes this.
  7. Jul 8, 2023 at 6:05 PM
    #4307
    Nano909
    Nano909 Stirrer Of Pots
    Xcab 3.4 4wd 5MT
    So has anyone successfully ran a heat exchanger on the 3.4?
  8. Jul 21, 2023 at 9:22 PM
    #4308
    Bo_04_taco_TRD Prerunner
    Bo_04_taco_TRD Prerunner Member
    2004 Gold Tacoma TRD Prerunner
    Fox 2.0 res and coils front. LED lights, K&N cold air, Engine chip performance, roof rack
    Hey guys,
    I installed a Magnuson supercharger on my 3.4, truck is running great, but wanted to add the extra benefit of a meth kit. Just bought the Snow 2.5 stage kit. My question is where do you get the accurate boost source from? There is a pressure sensor in the kit but does not say anything beyond install at accurate boost source. Point lost for Summit Racing instructions.
    Any help would be appreciated.
  9. Jul 31, 2023 at 4:42 PM
    #4309
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
    Long time no talk. Just chiming in to mention that it seems my Innovate PSB-1 MAP sensor went bad today. Boost reads 43.8PSI even with the engine shut off. I suspect it just got too hot and cooked itself in today's brutal 106º weather. Do we have any discount code for Innovate parts?
    Not sure about how it works with your meth kit, but my boost reading comes off the back of the blower and I have it teed off to send one line to my URD box and one line to my AFR/boost gauge.
  10. Jul 31, 2023 at 10:22 PM
    #4310
    Digiratus
    Roaming the PNW
    The RedHead
    Welcome back.
    I've been having some issues with my PSB-1 recently too. Mine is inconsistent on the AFR side. Sometimes getting the heater error but after running for a while it'll starting reading again. But on some start up sequences it'll be back to the heater error. Then this weekend going over Washington pass, the AFR reading was stuck on 10.0, even on the downhill side where vacuum was in the high -20s. Confirmed the AFRs were correct though with the Haltech software.
  11. Aug 1, 2023 at 4:15 AM
    #4311
    chrslefty
    chrslefty Well-Known Member
    chris
    Mesa az
    01 trd
    Stockish
    Is that to tune the 7th injector?
  12. Aug 1, 2023 at 7:27 AM
    #4312
    MatthewMay1
    Matthew
    Lone Star Republic
    I don't think I'm familiar with the heater error. What does the display show when it does this?
    Digiratus[QUOTED] likes this.
  13. Aug 1, 2023 at 9:57 AM
    #4313
    Digiratus
    Roaming the PNW
    The RedHead
    I can't remember the exact way it displays. I think it is: AFR HTR 01
    I get a photo of it the next time I see it.
  14. Aug 1, 2023 at 10:00 AM
    #4314
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    I believe it can, though it's underutilized in that role.
  15. Aug 1, 2023 at 10:11 AM
    #4315
    chrslefty
    chris
    Mesa az
    01 trd
    Stockish
    Could you please elaborate on what it dose.
  16. Aug 1, 2023 at 10:55 AM
    #4316
    treyus30
    Trey
    Mesa / AJ, AZ
  17. Aug 1, 2023 at 2:56 PM
    #4317
    MatthewMay1
    Matthew
    Lone Star Republic
    Is that not normal during the startup sequence?
  18. Aug 1, 2023 at 2:57 PM
    #4318
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    His was doing it while running and driving
  19. Aug 1, 2023 at 2:58 PM
    #4319
    MatthewMay1
    Matthew
    Lone Star Republic
    Ah
  20. Aug 1, 2023 at 3:48 PM
    #4320
    Matthewmay1, Do you know what you are T'd off of? I was told the fuel pressure regulator was a good spot. This is right on the back of the SC. Since posting, I have done this and get readings up to 5 PSI now. Seems to be working.
    For you guys getting erroneous PSI indications on your gauges, are they electronic. Meaning your are using a pressure transducer to send the signal. If so, I had the same issue with a Snow VC50 controller gauge combo and it was the two signal wires from the transducer. You have a short in one of them. I would run a test lead and bypass each cable until you identify which one. Hope that helps.
