3.4L supercharger
Discussion in '1st Gen. Tacomas (1995-2004)' started by CHMM, Sep 14, 2019.
  1. Aug 1, 2023 at 4:56 PM
    #4321
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Yes, this is normal while the heater circuit is being warmed up. After engine start it typically takes about 15-20 seconds to cycle through this then it'll start displaying the AFRs. On occasion mine will not switch to displaying the AFRs. However, it is not consistent. Sometimes it'll work correct.
    The newest kink is where it'll get stuck at a very low AFR reading like I mentioned a few posts back. After an engine restart, that was back to normal though. I suspect these two odd behaviors are linked in some way, just not certain how at this point.
  2. Aug 2, 2023 at 5:43 AM
    #4322
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    Fuel trims have been 10-15 negative lately so I checked my FP gauge and it’s sitting around 80psi. I figure the only way that’s going to happen is if the return line is blocked somehow. Has anyone had this happen so I know where to start looking?
  3. Aug 2, 2023 at 5:48 AM
    #4323
    1997tacomav6
    Denver
    Probably a bad fuel regulator coming off the rail in the back
  4. Aug 2, 2023 at 8:25 AM
    #4324
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
    Off the top of my head I can't tell you what I'm teed off of. I thought there was one place on the back of the blower but to be honest I haven't thought about it in years.
    As far as the faulty boost reading, it is indeed a transducer that takes the pressure and converts it into an electronic signal. I called Innovate tech and they said most likely the MAP sensor went bad and I can only assume it is due to excessive heat. I already ordered a new one so I'll swap them out and see if it works again.
    Ah, okay I see what you're saying. That's strange.
    I never look at my fuel trims anymore. Do you monitor them regularly or did you develop a symptom to point you in the direction to look at the fuel trims?
  5. Aug 2, 2023 at 9:04 AM
    #4325
    Shortman5
    Supercharged TRD
    I keep mine up but don’t worry too much about them. It’s just a diagnosis tool.
    But when it changed by a value of 8-10 points I looked into why that may be happening. That’s when I found that my fuel pressure was reading double what it should be.
    MatthewMay1[QUOTED] likes this.
  6. Aug 2, 2023 at 11:35 AM
    #4326
    unstpible
    unstpible Well-Known Member
    Derek
    Cedar City, Utah
    03 4x4 boosted V6 Auto 341k miles
    CX Racing Turbo kit. TransGo shift kit. All Pro Apex bumper and skids. Smittybilt XRC 9.5 winch. All Pro Upper control arm's. Bilstein 6112's with 600lb coils. Eimkeith's lower control arm reinforcement plates. Perry Parts bump stops. All Pro spindle gussets and alignment cam tabs. All Pro standard 3" leaf springs. Bilstein 5125's rear. Extended rear brake lines. Rear diff breather relocation. MagnaFlow catback with resonator. Bluetooth stereo. Memphis 6x9 door speakers. Diode Dynamics SS3 Pro Amber fog lights. Single piece headlights. aftermarket grille. Anzo taillights. LED 3rd brake light. 4runner sunglass holder and dome lights. Master Tailgaters rear view mirror with 3 directional cameras, G shock sensors, and anti theft system. Honda windshield washer nozzles. Stubby antenna. Scan Guage II. 2nd Gen Snowflake wheels powder coated black. Cooper Discoverer ST Maxx 235-75/16 Denso 210-0461 105 amp alternator. Speedytech7's big wire harness upgrade. Aeromotive 340 fuel pump. Haltech Elite 2500. Tacomaworld sticker. Tundra brakes with Adventure Taco's hardline kit
    I ordered a replacement MAP sensor for my PSB-1 the other day through Summit and ended up not needing it I've only had it for 3 days now. It was $95 after shipping and taxes. Just make sure you get the right one they have 2 listed on the website and neither of them say they work with the PSB-1. I can confirm the 15-0048 model is a correct fit for us
    I was going to send the new one I didn't use back but if you need it I can send it your way instead if you want. Send me a PM if interested otherwise ill send it back to summit
  7. Aug 2, 2023 at 2:07 PM
    #4327
    Sebz13
    Sebz13 appy polly loggies
    Shane
    Maui Hawaii
    03 Reg Cab, 99 3 Link SC ext cab.
    a dropped one and a high one
    So whats everyones engine running as supercharged for temperature?
    If I push my truck into the wind on the highway it will hover around 199ish, in stopped hot middle of the day traffic ive seen it get to 203, dropping quickly with idle up, but pounding the truck up my mountain she is bouncing at 199 to 201. I feel this is too hot. Previous owner installed an electric fan and I have yanked that out and replaced it with an OEM fan, and Towing kit fan clutch, I feel the temp is much more consistent but I am still a little uneasy as its getting this high.
  8. Aug 2, 2023 at 2:14 PM
    #4328
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    If you're maxing out at 201-205 you're a-ok. I get worried after cresting 210 but you wont even start to near doing damage until 225-230 or so.
    unstpible and Sebz13[QUOTED] like this.
  9. Aug 2, 2023 at 2:19 PM
    #4329
    Sebz13
    Shane
    Maui Hawaii
    Good to know, I feel better now, its hot as shit right now so I was a little wary of driving the truck because its been back on my mind. I will carry on.
  10. Aug 2, 2023 at 2:23 PM
    #4330
    Digiratus
    Roaming the PNW
    The RedHead
    You likely have a 190° t-stat installed. That is typical for oem/stock config.
    For my SC I am running a 170° t-stat with the jiggle valve at the 6 o'clock position with OEM fan/shroud. It typically runs between 159° and 165° depending on conditions.
  11. Aug 2, 2023 at 2:45 PM
    #4331
    Sebz13
    Shane
    Maui Hawaii
    should I get the one that @1997tacomav6 has I believe from a corolla?
  12. Aug 2, 2023 at 5:54 PM
    #4332
    Digiratus
    Roaming the PNW
    The RedHead
    Sebz13[QUOTED] likes this.
  13. Aug 2, 2023 at 10:10 PM
    #4333
    Sebz13
    Shane
    Maui Hawaii
    I drove around all day hard and actually realized I’ve kinda been lugging the engine, I kept the RPMS higher and broke 201 once, I think it’s my paranoia more than anything. I do want to get a new radiator eventually cause I damaged some fins pulling the shitty electric fan out and when I do I’ll swap to the other thermostat
  14. Aug 2, 2023 at 10:26 PM
    #4334
    TacoMac156
    TacoMac156 Member
    2002 IMPULSE red tacoma 3.4 4x4 5spd
    Bilstein 5100 Deck plate mod URD short shift Magna flow cat back exhaust
    Correct me if I'm wrong, but the little jiggle dongle should be at 12 o clock, no? I was under the impression that was to allow air bubbles to escape.
    I will be swapping to a 170 and koyo aluminum radiator this month on my N/a truck. Hoping to drop 10-15 degrees from 190-195
  15. Aug 2, 2023 at 10:45 PM
    #4335
    Digiratus
    Roaming the PNW
    The RedHead
    It's counterintuitive isn't it. I didn't believe it either until I tried it for myself. It's also well documented here on TW.
    Setting the jiggle valve at 6 o'clock will net you ~10°F. So a standard 190° t-stat will run at 180°-185° instead of 190°-195°.
    BlackSportD likes this.
  16. Aug 3, 2023 at 8:00 AM
    #4336
    BlackSportD
    BlackSportD Well-Known Member
    Los Angeles
    Icon/TC Mid travel, TRD S/C, PNP Greddy EMU, 625cc injectors, 2.2 pulley, Hayden tranny cooler, AEM wideband, TRD boost gauge.
    Wow, I never knew of the jiggle valve. Had put in a 180 I believe but OBD showed OEM temps. I really don't want to open stuff up again but now I really want to verify the jiggle valve... alignment.
  17. Aug 6, 2023 at 4:40 PM
    #4337
    BlackSportD
    Los Angeles
    Tick tock, tick tock
    1997tacomav6[QUOTED] likes this.
  18. Aug 6, 2023 at 6:13 PM
    #4338
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
  19. Aug 6, 2023 at 7:32 PM
    #4339
    1997tacomav6
    Denver
    Got an email 3 days ago saying things were running behind schedule because of some adjustments that were needed in the mill process.
    So I'm guessing another month at least or so,
    Possibly 2 months at the most
  20. Aug 6, 2023 at 7:44 PM
    #4340
    Shortman5
    Supercharged TRD
    Really interested to see how this goes.
