3.4L supercharger
Discussion in '1st Gen. Tacomas (1995-2004)' started by CHMM, Sep 14, 2019.
  1. Aug 28, 2023 at 10:17 PM
    #4361
    unstpible
    unstpible Well-Known Member
    Derek
    Cedar City, Utah
    03 4x4 boosted V6 Auto 341k miles
    CX Racing Turbo kit. TransGo shift kit. All Pro Apex bumper and skids. Smittybilt XRC 9.5 winch. All Pro Upper control arm's. Bilstein 6112's with 600lb coils. Eimkeith's lower control arm reinforcement plates. Perry Parts bump stops. All Pro spindle gussets and alignment cam tabs. All Pro standard 3" leaf springs. Bilstein 5125's rear. Extended rear brake lines. Rear diff breather relocation. MagnaFlow catback with resonator. Bluetooth stereo. Memphis 6x9 door speakers. Diode Dynamics SS3 Pro Amber fog lights. Single piece headlights. aftermarket grille. Anzo taillights. LED 3rd brake light. 4runner sunglass holder and dome lights. Master Tailgaters rear view mirror with 3 directional cameras, G shock sensors, and anti theft system. Honda windshield washer nozzles. Stubby antenna. Scan Guage II. 2nd Gen Snowflake wheels powder coated black. Cooper Discoverer ST Maxx 235-75/16 Denso 210-0461 105 amp alternator. Speedytech7's big wire harness upgrade. Aeromotive 340 fuel pump. Haltech Elite 2500. Tacomaworld sticker. Tundra brakes with Adventure Taco's hardline kit
    It's my understanding that the ECU isn't going to run other injectors unless you were able to get a tune for it somehow. I've seen talk about the 03's and 04's being tuneable to a small degree.
    I would also check the drivers side ball flange on the DT Headers for an exhaust leak. it's a common spot for a leak and can cause a false lean consition making it runs rich (my DT Headers did the same thing before the turbo kit went on and ironically I still have a leak in the same spot causing the same false lean conditions).
    BrownMike and Digiratus like this.
  2. Aug 29, 2023 at 11:22 AM
    #4362
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    Only going up to 250 shouldn't cause it to get so rich it dies. You can get over 40% compensation from the factory ECU (provided it has time to learn, otherwise 20% short term)
    unstpible[QUOTED] likes this.
  3. Aug 29, 2023 at 11:23 AM
    #4363
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    It doesn't learn in open loop though so it might not even get through warm up
    unstpible likes this.
  4. Aug 31, 2023 at 12:02 PM
    #4364
    1997tacomav6
    Denver
  5. Sep 4, 2023 at 12:42 AM
    #4365
    Laxtoy
    Laxtoy Dog is my backseat driver
    Maltby, WA
    99 3.4l 5 speed 4WD 2023 Limited DCLB 4WD
    Fox 2.5 DSC resi CO's w/ 700lb King Coils, Camburg uca's, T-100 rear leafs, 13WL Tundra brakes, 1" 4crawler body lift, 295/75/16 Hankook MT, Ruff Stuff u bolt flip, 10" Fox LSC resi shocks turned back on custom mounts, home built rear high clearance bumper with dual swing outs, Diode Dynamics SSC2 Pro rear floods, Skid Row front and transfer case skid, home built transmission skid, Mercerfab sliders, home built front bumper, Badlands Apex 12k winch with synth line, 4.56's, ARB rear locker, home built rack with CVT Mt. Shasta, eBay snorkel, Sierra LEDs 20" dual amber/white light bar, Diode Dynamics SS3 Max amber fogs, Mini D2S projector retrofit, Blue Sea ML-ACR, dual Odyssey PC1200's, 100 watt solar panel, 20 plate heat exchanger/home built shower kit
    So I’m about half way through the 219 pages of this thread and need to ask a fairly simple question I think.
    I bought a 2000 Tacoma that was in pieces since the guy gave up in the middle of doing a frame swap. The truck sat in the weather for 3 years so biggest issue is rusty fasteners/steel and oxidation on the aluminum of the engine, transmission, tcase- all of which can be refurbished with some sweat.
    It has 90k miles, body is close to perfect, same drivetrain as my 340k mile 99 that’s falling apart, plan is to take the best parts of both - wheels/tires, diffs, suspension, frame, skids, bumpers, etc from the 99, engine, trans, tcase, body from the 2000, basically make 2 trucks again, sell the one with all the wear (or turn it into a crawler if I can get it past my wife), keep the good truck.
    Getting to my point, the 2000 came with a factory installed black supercharger, which sat out in the weather mounted to the engine, exterior is very weathered.
    Finally got around to tearing into it, and the interior appears to be in excellent condition, plans to refinish the exterior.
    I have a rebuild kit for the snout and was going to buy double sealed cup bearings for the rotors in case I go meth. Have a press, I’m confident I can do the work myself. Well aware can’t take the rotors/timing gears apart, no intention to do so.
    My question is in regards to the rotors themselves. They're in near perfect condition, but have a few spots the coating is starting to flake off.
    Would the advice be I send it off to Jon Bond or The High Speed Lab to be serviced and have the rotors recoated or would you guys just run it?
    If the advice was to service it, do you recommend one place vs the other?
  6. Sep 4, 2023 at 2:11 AM
    #4366
    1997tacomav6
    Denver
    If its just some flakes I would just run it.
    If your super picky get them recoated by Jon Bond NOT HSL. HSL works is NOT the best, my rotors were peeling a year after my rebuild, I DON'T recommend them.. Plenty of others here have had the same experience and waiting times up to 6 months
    Laxtoy[QUOTED] likes this.
  7. Sep 4, 2023 at 10:14 AM
    #4367
    DUCKSHOT
    DUCKSHOT Well-Known Member
    TX
    01' Tacoma PreRunner
    So I'm standing at the edge of the rabbit hole. Read all 219 pages!
    Anyone in the Houston, TX area that is willing to take me for a ride so I can see what these Supercharger's can do?
  8. Sep 4, 2023 at 11:40 AM
    #4368
    Laxtoy
    Maltby, WA
    Thank you, your opinion matters, definitely makes matters easier
    A bit off topic, but is it typical for these things to smell like baby poop/dirty feet/strong blue cheese when you open them up?
    The odor when I cracked it open was unpleasant to say the least
    1997tacomav6[QUOTED] likes this.
  9. Sep 4, 2023 at 12:43 PM
    #4369
    04Pre_Runner
    Andrew
    2004 DC Tacoma SR5 4WD V6
    Yup. The TVS1320 for the 4.0 I worked on was the same. It's the supercharger oil.
    1997tacomav6 likes this.
  10. Sep 4, 2023 at 2:36 PM
    #4370
    1997tacomav6
    Denver
    Yup :)
  11. Sep 4, 2023 at 4:23 PM
    #4371
    Laxtoy
    Maltby, WA
    It sat for 3 years, wasn’t sure lol
  12. Sep 5, 2023 at 8:01 AM
    #4372
    DUCKSHOT
    TX
    Can anyone make any recommendations to get the most out of the new SC and still pass emissions in Texas.
    From what I understand, using a Haltech 2500 and Meth kit is out of the question.
    Called a local shop recommended by Thomas at Haltech in Houston, but they have never done anything with a 1st Gen. Sounds like all I can do is bolt it on, 7th Injector if it pings and thats what I get.
  13. Sep 5, 2023 at 9:45 AM
    #4373
    eon_blue
    Azusa, CA
    I read in another thread on FB that Magnuson is saying the 7th will be 'unnecessary' with this one, but that's what they said about the last generation of supercharger too at first and we all know how that turned out.
    If your smog restrictions are like ours in CA, you basically can't modify it at all unless whatever modification you're doing is CARB certified. The URD 7th injector is not. That being said, I added the 7th injector to my TRD blower and have passed smog 3 times with it on. It's not really that obvious that it's there unless they are actively looking for it.
    Depends on your smog station/worker too, some of them are real particular about combing over everything.
  14. Sep 5, 2023 at 11:05 AM
    #4374
    1997tacomav6
    Denver
    Haltech is not going to pass emissions, you can uninstall the Haltech and plug the stock ECU in to pass as an option as long as you’re using the stock injectors if u want and that takes about 15 minutes
  15. Sep 5, 2023 at 7:29 PM
    #4375
    Austintaco
    Austintaco Well-Known Member
    Patrick
    Austin,TX
    03 DC TRD with some stuff
    King coilovers, Tundra brakes, All pro Expo springs, Timbrens, ARB bumper, All Pro Sliders and Rear bumper, Landcruiser wheels, sold my Flippac, regeared to 4.88’s, ARB front Locker
  16. Sep 6, 2023 at 2:23 PM
    #4376
    DUCKSHOT
    TX
    I spoke with Gabe later on and he said the same thing. Did not know I would have to put the stock plugs back in. From what understand about this setup, it will be worth it.
  17. Sep 6, 2023 at 2:30 PM
    #4377
    DUCKSHOT
    TX
    That's a good idea, thanks, I didn't know about this.
    I do live in one of the counties required for the emissions testing. My parents still live in the county so that will work out perfectly for me.
    I'll still try plugging the stock ECU back in and hope that works.
  18. Sep 6, 2023 at 2:46 PM
    #4378
    tacoman2001$
    tacoman2001$ Well-Known Member
    I bet you could sneak a water meth kit through inspects if it is really tidy. What gives stuff away is brand names. Obviously, Haltech won't pass but like others said if you're willing to switch back to the stock pulley and swap the stock ecu back over you can switch back every time you need to be tested.
  19. Sep 6, 2023 at 4:47 PM
    #4379
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    You shouldn't have to swap plugs. Larger injectors will be a problem when swapping back to the OEM ecu though.
    Digiratus and Speedytech7 like this.
  20. Sep 6, 2023 at 6:02 PM
    #4380
    tacoman2001$
    I'm not sure if this has been covered but has anyone run a 2" pulley? I see Pulley boys offers a 2" but I've never seen anyone run one. Est. 13.5 Psi seems doable with meth and 93 Maybe a 7th injector.
