3.4L supercharger
Discussion in '1st Gen. Tacomas (1995-2004)' started by CHMM, Sep 14, 2019.
  1. Oct 9, 2019 at 2:19 PM
    #421
    eon_blue
    Azusa, CA
    Holy crap that is a really cheap OEM MAF sensor...that one the spare or the one you put in? I'd be afraid of it not being legit at that price but hopefully it was!
  2. Oct 9, 2019 at 2:23 PM
    #422
    1997tacomav6
    Denver
    UPDATE, I THINK THESE ARE FAKE, MY TRUCK COULD NOT GO OVER 4000rpms
    WITHOUT BUCKING AND STUMBLING.
    SO I PUT MY OLD ONE BACK IN AND ITS RUNNING FINE.
    The picture posted is the old sensor that came out now in the new box,
    It came sealed in the box and fixed my problem, I did buy one from this person two years ago tho and is the one that failed.
    Same one. So it lasted 70k miles.
    You can see this person has sold 628 of these sensors with no negatives on them,
    So should be ok
    CHMM[OP] and eon_blue[QUOTED] like this.
  3. Oct 9, 2019 at 3:10 PM
    #423
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    unstpible and Tuke like this.
  4. Oct 10, 2019 at 10:01 AM
    #424
    CHMM
    CHMM [OP] GTO
    Gabe
    Castle Rock, Colorado
    2001 TRD Xtra Cab 4x4 Supercharged
    5100s SPC UCAs Energy bushings #70 spring clutch mod Supercharged
    Well. I guess my truck sat for a while and had some rodent chewin up hoses. Check engine light came on from a hole in the PCV hose. $30 part. Go figure. Taped up for now until the part arrives this afternoon. Non S/C related. But just a heads up for you guys.
  5. Oct 10, 2019 at 10:02 AM
    #425
    CHMM
    CHMM [OP] GTO
    Gabe
    Rabbit holes and rabbits on hoses. LOL.
  6. Oct 10, 2019 at 10:22 AM
    #426
    Anthony250
    Anthony250 Ex Fabricator
    Anthony
    Rialto CA
    99 Tacoma LT Prerunner
    LSK Race Kit, King Shocks, Methods, Glassworks, Baja Designs, Built by myself.
    Question do you guys with the 7th kit and supercharger of course, run the cooler thermostat?
  7. Oct 10, 2019 at 10:52 AM
    #427
    JasonLee
    15 TRD OffRoad
    Without stating my opinion, what's your reasoning for wanting one?
  8. Oct 10, 2019 at 12:32 PM
    #428
    CHMM
    CHMM [OP] GTO
    Gabe
    I don’t. I’m running all stock. Aside from the rodents eating my truck, it’s running like my 2018 did. Except for the “I’m confused which of the six gears should be in . “
    1997tacomav6 likes this.
  9. Oct 10, 2019 at 1:25 PM
    #429
    1997tacomav6
    Denver
    Running a cooler thermostat in summer in particular you will get more power because of the lower temperature.
    Heat and superchargers dont mix.
    I run a 175 thermostat which keeps my temperature at 175-180, But thats because I have
    a much better radiator than stock.
    I don't know how much cooler the stock radiator will run with the lower thermostat in summer tho.
    There is quite a bit difference in power tho with the lower temperature 175 stat and supercharger
    CHMM[OP] likes this.
  10. Oct 10, 2019 at 1:27 PM
    #430
    eon_blue
    Azusa, CA
    Well having a manual trans certainly helps with that lol...yours is manual right? Unless I'm remembering wrong
  11. Oct 10, 2019 at 1:31 PM
    #431
    CHMM
    CHMM [OP] GTO
    Gabe
    So two check engine lights in a month. One from the throttle position sensor and one from a hole in the PCV hose. Moving forward with methanol/2.2 pulley.
    It’s enough to notice. When cold, it’s runs so fast. When hot, it’s sluggish.
    It is manual. But it’s something else with the third gen. My buddy is re-gearing. The 3rd gen constantly is downshifting and upshifting up a hill. Going up the mountains, it goes 60 mph at 5000 rpms then shifts and a second later down shifts. It’s pretty bad. It makes passengers sick. My wife wouldn’t ride with me anymore. We had to take her car.
    1997tacomav6[QUOTED] likes this.
  12. Oct 10, 2019 at 1:40 PM
    #432
    eon_blue
    Azusa, CA
    I just meant as far as the gear hunting goes, no need to worry about an auto trans gear hunting if you have a manual
  13. Oct 10, 2019 at 1:51 PM
    #433
    CHMM
    CHMM [OP] GTO
    Gabe
    yeah I hear ya.
  14. Oct 10, 2019 at 1:59 PM
    #434
    JasonLee
    15 TRD OffRoad
    This is where I disagree... maybe it's just my comprehension of what you wrote.
    Here's a much better written explanation that I could write up, but basically all that the lower temp thermostat does is allow your cooling system to pump/flow through the radiator at a lower temperature. Below the temperature rating of your thermostat, the coolant is not circulating in order to allow your engine to warm up to a proper operating temperature faster.
    http://www.tuneruniversity.com/blog/2012/04/low-temp-thermostats-whats-the-advantage/
    Your INSANELY good radiator is what allows you to have a much better cooling system, which gets you those lower temps with the lower thermostat.
    So in summary, with the stock cooling system, it is unlikely that changing to a cooler thermostat will do anything since it will not allow you to cool that low anyway.
  15. Oct 10, 2019 at 2:21 PM
    #435
    1997tacomav6
    Denver
  16. Oct 10, 2019 at 2:38 PM
    #436
    Anthony250
    Anthony
    Rialto CA
    Hmm Intresting points, I live In socal so sunny warm weather all time, and running a full aluminum radiator already. Not sure if I should put one in now think i will
  17. Oct 10, 2019 at 2:45 PM
    #437
    TacoTron
    TacoTron Tacotronn
    Anthony
    Denver, CO
    07 Toyota Tacoma
    Yes sir but they are brand new
  18. Oct 10, 2019 at 4:25 PM
    #438
    1997tacomav6
    Denver
    If you get your temperature from 190-200 to 175-180 you will definitely feel a difference.
    Less chance for heat soaking too
  19. Oct 10, 2019 at 5:28 PM
    #439
    CHMM
    CHMM [OP] GTO
    Gabe
    Hey John, what’s the make and model on that radiator you have? I saw it was larger and aluminum.
  20. Oct 10, 2019 at 5:58 PM
    #440
    JasonLee
    15 TRD OffRoad
    unstpible likes this.
