3.4L supercharger
Discussion in '1st Gen. Tacomas (1995-2004)' started by CHMM, Sep 14, 2019.
  1. Sep 21, 2023 at 11:30 AM
    #4421
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    I haven't seen those Bosch injectors before. What model year is your truck?
  2. Sep 21, 2023 at 11:33 AM
    #4422
    ridah4824
    ridah4824 Member
  3. Sep 21, 2023 at 12:30 PM
    #4423
    Digiratus
    Roaming the PNW
    The RedHead
    That product page is a bit confusing to me. In the fitment section it says '95-'98 for the 3.4L applications. Yet up above it says all '96-'04s. Your OEM ECU will be able to automatically adjust to differences between stock injectors and aftermarket ones, but I have been told the adjustment range is limited to something like a 10% variance in volume and flow rate.
  4. Sep 21, 2023 at 1:49 PM
    #4424
    unstpible
    unstpible Well-Known Member
    Derek
    Cedar City, Utah
    03 4x4 boosted V6 Auto 341k miles
    CX Racing Turbo kit. TransGo shift kit. All Pro Apex bumper and skids. Smittybilt XRC 9.5 winch. All Pro Upper control arm's. Bilstein 6112's with 600lb coils. Eimkeith's lower control arm reinforcement plates. Perry Parts bump stops. All Pro spindle gussets and alignment cam tabs. All Pro standard 3" leaf springs. Bilstein 5125's rear. Extended rear brake lines. Rear diff breather relocation. MagnaFlow catback with resonator. Bluetooth stereo. Memphis 6x9 door speakers. Diode Dynamics SS3 Pro Amber fog lights. Single piece headlights. aftermarket grille. Anzo taillights. LED 3rd brake light. 4runner sunglass holder and dome lights. Master Tailgaters rear view mirror with 3 directional cameras, G shock sensors, and anti theft system. Honda windshield washer nozzles. Stubby antenna. Scan Guage II. 2nd Gen Snowflake wheels powder coated black. Cooper Discoverer ST Maxx 235-75/16 Denso 210-0461 105 amp alternator. Speedytech7's big wire harness upgrade. Aeromotive 340 fuel pump. Haltech Elite 2500. Tacomaworld sticker. Tundra brakes with Adventure Taco's hardline kit
    Are you able to run a boost referenced vacuum line to the stock FPR? It's working for me, my fuel setup is stock except for the Aeromotive 340 pump. I don't think my injectors have ever been touched and probably won't be unless I go full Haltech.
    @ridah4824 how old is your timing belt and water pump?
    SUMOTNK likes this.
  5. Sep 21, 2023 at 2:02 PM
    #4425
    unstpible
    Derek
    Cedar City, Utah
    I'm still pretty low on boost (3.6 psi) and with an inner cooler the extra fueling might not be needed as much since the intake temperatures are a bit lower that a SC setup would be.
  6. Sep 21, 2023 at 3:48 PM
    #4426
    ridah4824
    ridah4824 Member
    I was confused by that too, but I confirmed with motorwest that they should work and be plug and play/no tuning (at least for my 2003, so I suggest confirming with motorwest yourself if you choose to run them). I guess I'll find out in a few weeks when I get everything in and installed.
    The stock FPR has a vacuum line to it that gets attached to the supercharger right after the throttle body once you install it, so that should change the fuel pressures enough hopefully. I'm 99% sure this is also the line that magnusen suggests teeing into if you run a boost gauge.
    As for my timing belt and water pump, I did those around this time last year, so they only have about 10-15k on them.
    SUMOTNK and unstpible[QUOTED] like this.
  7. Sep 21, 2023 at 9:07 PM
    #4427
    unstpible
    Derek
    Cedar City, Utah
    The T into the stock FPR for the boost guage is how I have it for my 03 as well :thumbsup:
    Do you have a plan for one way check valves on the fuel Evap System?
    Good to hear on the timing belt :thumbsup:
    I'm interested to see how those Injectors work out for you and how the progress goes.
    :fingerscrossed::thumbsup::thumbsup:
  8. Sep 22, 2023 at 12:21 AM
    #4428
    TacoMac156
    TacoMac156 Member
    2002 IMPULSE red tacoma 3.4 4x4 5spd
    Bilstein 5100 Deck plate mod URD short shift Magna flow cat back exhaust
    I have confirmed that as well with Martin, the stock injectors that they provide flow at 252cc and will work fine with the new s/c. They ask that you mention it in your order sheet that you mention it is for a supercharger application tho.
    I also emailed five o about larger injectors and was also told that stock/cleaned injectors should be fine. I will worry about larger injectors when I start getting into the rabbit hole with smaller pully and standalone.
    unstpible likes this.
  9. Oct 9, 2023 at 10:02 PM
    #4429
    robblacktpre03
    robblacktpre03 03 Tacoma Restore time
    Rob
    San Francisco, CA
    03 black pre runner
    k&n air filter, throttle body spacer, all pro UCA, 07 gun metal TRD FJ rims, blacked out interior trim
    Just installed my supercharger/ doug thorley exhaust. Getting a p0171 code. I've cleaned the maf and don't notice a vacuum leaked. Any advice out there. Don't have my afr installed yet
    1997tacomav6 likes this.
  10. Oct 10, 2023 at 6:23 AM
    #4430
    1997tacomav6
    Denver
    P0171 means having trouble with a dirty or faulty mass airflow (MAF) sensor, or a vacuum leak downstream of the MAF sensor (perhaps in the PCV line or in the valve itself). Of course, this code can also signify a bad O2 sensor.
    I would look again at vacuum leaks or exhaust leak.
    ANY VACUUM leak will mess everything up
  11. Oct 10, 2023 at 8:56 AM
    #4431
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    I'm betting there's a vacuum leak since it came up after installing all that. The smallest leak can trip that code, can be a pain to track down. I had it once and it ended up being a small leak on the back of the supercharger where the EGR port is capped off (before I had the 7th injector there)
    If it's not an obvious leak I would run a smoke machine through the system to try and pinpoint it. Or at least rule it out. But with headers and a sc getting installed I'm betting a small leak is the most likely culprit for that code
    04Pre_Runner and 1997tacomav6 like this.
  12. Oct 10, 2023 at 9:31 AM
    #4432
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Dalandser likes this.
  13. Oct 10, 2023 at 9:34 AM
    #4433
    mechanicjon
    Jon
    Scottsdale Arizona
    Do you have the complete exhaust system hooked up, not open headers?
  14. Oct 10, 2023 at 12:50 PM
    #4434
    robblacktpre03
    Rob
    San Francisco, CA
    03 black pre runner
    Yes, it's all hooked up
  15. Oct 11, 2023 at 12:37 AM
    #4435
    03tacodude
    03tacodude Active Member
    03 Taco on Tons & 40's
    Hate to thread jack, but got a quick question. I read a decent amount of this particular post (till about page 50).
    Was wondering if anyone has done a write up or video on 7th injector installation. Plz leave links if anyone has any leads to this.
    Figured I would ask here before posting a new thread. Thanks!
  16. Oct 11, 2023 at 2:13 AM
    #4436
    ChargedSHOTaco
    ChargedSHOTaco Well-Known Member
    Seriously, the 7th injector is garbage. I had the 7th injector for over 10 years and I was always trying to “fix” the tune on that thing. The stock ECU is constantly adjusting against the changes made by the 7th injector tune, so I never got it to run as consistent and good as it is running now with the Haltech. The addition of just the Haltech felt like it added another 30hp when compared to the 7th injector setup, with the same injectors and fuel pump.
    Go for the Haltech and never look back. Tuning the Haltech is also much more intuitive.
  17. Oct 11, 2023 at 9:37 AM
    #4437
    03tacodude
    Okay I appreciate the honesty. What’s a good asking price for the unit? It’s used and I’m missing the fuel pump, but everything else is complete.
    Any good links to snag a haltech? I’m not in a super rush to install this thing, but maybe I could snag on next month on BF.
  18. Oct 11, 2023 at 10:36 AM
    #4438
    ChargedSHOTaco
    I’d say you can still get in the $500-700 range for the 7th injector kit, as they are still quite a bit of people that choose to go that route despite the better, although higher priced option out there.
    If you are new to stand alone ECUs don’t let that scare you away from trying to put everything together yourself, the resources are out there, and on this forum to help you figure it out. As with anything, there is an effort needed to learn how the Haltech works, but once you understand it, it becomes much much easier to use.
    1997tacomav6 and Speedytech7 like this.
  19. Oct 11, 2023 at 10:50 AM
    #4439
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    I got my Haltech on last years SNP black friday sale.
    There's definitely a learning curve to start, but it's worth it in the end like everyone says.
  20. Oct 11, 2023 at 2:14 PM
    #4440
    03tacodude
    Also when you say your were always trying to “fix” the tune. What do you mean by that?
    I bought this package thinking I would good to go with the 7th inj. But it is sounding I’m wrong lol.
    Would it be any benefit to run the 7th inj? What was so bad about it?
