3.4L supercharger
Discussion in '1st Gen. Tacomas (1995-2004)' started by CHMM, Sep 14, 2019.
  1. Oct 24, 2019 at 9:46 PM
    #601
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    35lbf and 18lbf is what the a/c bracket to block and compressor to bracket torque to. That should be good.
    1997tacomav6[QUOTED] likes this.
  2. Oct 24, 2019 at 9:50 PM
    #602
    1997tacomav6
    Denver
    Still have not gotten it back yet, he said if I did 25 or 50 would be a lot cheaper than 2 or 3.
    I had him do round cuts on the top and bottom so it will look more like a factory piece tho
    and had to have it sandblasted because of the old paint and surface rust.
    Hopefully I know tomorrow
  3. Oct 24, 2019 at 9:59 PM
    #603
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    Worst case, please trace it on some cardboard or paper before you install it and post some photos!
  4. Oct 24, 2019 at 10:04 PM
    #604
    1997tacomav6
    Denver
    Will see what this guy says,
    The base of the bracket that attaches to the block has a pressed step back with a 90 degree bend in the steel and then a metal spacer welded.
    If it wasn’t for this it would be easy to just make one.
  5. Oct 24, 2019 at 10:12 PM
    #605
    JasonLee
    15 TRD OffRoad
    Yeah, I saw that step in the earlier photos. I wish a flat piece with a washer on the back up near the supercharger would work, but that the bend allows most of the plate to be closer to the rear of the vehicle is to clear the belt.
  6. Oct 24, 2019 at 10:32 PM
    #606
    mechanicjon
    Jon
    Scottsdale Arizona
    How far does it step back?
  7. Oct 24, 2019 at 10:41 PM
    #607
    mechanicjon
    Jon
    Scottsdale Arizona
    I was wrong 12 on top bolt 18 on bottom. From the install manual.
  8. Oct 25, 2019 at 11:45 AM
    #608
    Daddo
    Daddo Well-Known Member
    Paul
    2004 Doublecab Tacoma 4wd
    Full Total Chaos Long Travel
    I think this a good idea to support the snout. I was going to fab one up but checked and my TRD Supercharger 2015 era. does not have the upper bolt hole machined into it.
    1997tacomav6 likes this.
  9. Oct 25, 2019 at 11:48 AM
    #609
    JasonLee
    15 TRD OffRoad
    Interesting. Drill and tap?
    mechanicjon likes this.
  10. Oct 25, 2019 at 11:53 AM
    #610
    CHMM
    CHMM [OP] GTO
    Gabe
    Castle Rock, Colorado
    2001 TRD Xtra Cab 4x4 Supercharged
    5100s SPC UCAs Energy bushings #70 spring clutch mod Supercharged
    I see you’re running the 2.2 pulley. I have that on standby with stock pulley currently installed. Did you upgrade the belt? Did you upgrade the fuel system? How awesome is it?
  11. Oct 25, 2019 at 12:02 PM
    #611
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    @Daddo
    I am curious about that cross brace. Does it connect the two shock towers? Any pictures of how it is mounted?
  12. Oct 25, 2019 at 12:12 PM
    #612
    Daddo
    Paul
    Stock belt, 7th injector. 34s so I was hoping for more but I'm happy. Headers and Methanol in the future.
    CHMM[QUOTED][OP] likes this.
  13. Oct 25, 2019 at 12:24 PM
    #613
    Daddo
    Paul
    Cross brace is mounted to the shock towers through the fenders. Steve at Dirt Designs did the install.
    austinmtb and Digiratus[QUOTED] like this.
  14. Oct 25, 2019 at 12:28 PM
    #614
    Digiratus
    Roaming the PNW
    The RedHead
    Do you have any wider shots that show that secondary hoop? Where does the bottom of that mount?
  15. Oct 25, 2019 at 12:36 PM
    #615
    Daddo
    Paul
    The secondary hoop is just a TC secondary shock hoop. The cross brace was custom.IMG_0817.jpgIMG_0819.jpg
    mechanicjon and SR-71A like this.
  16. Oct 25, 2019 at 1:35 PM
    #616
    JasonLee
    15 TRD OffRoad
    Is that a fiberglass hood? I wonder if the OEM metal one would clear the tube as is.
  17. Oct 25, 2019 at 2:02 PM
    #617
    Daddo
    Paul
    It is a glass hood. The reinforcing brace on the stock would have had to be notched but will work..they have done it many times.
    JasonLee[QUOTED] likes this.
  18. Oct 25, 2019 at 2:12 PM
    #618
    1997tacomav6
    Denver
    So I have the threaded hole available and it’s the 1st gen TRD and the menber I got the bracket
    had the black TRD supercharger and there was a support hole for the bracket.
    So I guess some models have it and some don’t depending when they were made.
    Looks like the Magnuson does not have the hole but has the stub there sticking out if someone wanted to tap and die a bolt hole.
  19. Oct 25, 2019 at 2:54 PM
    #619
    JasonLee
    15 TRD OffRoad
    Seems that I'll have to fix the new supercharger in the mill when I get it and face that nub, mill a hole and tap it.
  20. Oct 25, 2019 at 4:43 PM
    #620
    1997tacomav6
    Denver
    Got the bracket back today,
    Bracket was cut and both ends were nicely rounded to look like a factory bracket.
    Good news and bad news tho,
    If I wanted a few made identical to the one I had cut it will cost 100.00 a pop.
    Has to be setup on a jig and laser cut.
    I paid 100.00 for my used bracket with the bolts and metal tube support tube
    plus 85.00 to sandblast and cut the line and round the edges.
    So I’m into the prototype for 185.00
    But if I wanted 25 orders made it would cost around guessing 40.00 -50.00 tax or so just for the bracket which would be a deal.
    So would I be able to find 25 buyers at 75.00 a bracket plus shipping to make it worth my time?
    I need to put a few coats of paint and see how it looks installed
    cruiserguy and CHMM[OP] like this.
