3.4L supercharger
Discussion in '1st Gen. Tacomas (1995-2004)' started by CHMM, Sep 14, 2019.
  1. Oct 28, 2019 at 7:00 PM
    #681
    eon_blue
    Azusa, CA
    Luckily I haven't had to do that yet lol. I hear it's getting harder to find those guys nowadays due to the state really cracking down on them.
    CHMM[QUOTED][OP] likes this.
  2. Oct 28, 2019 at 7:25 PM
    #682
    Rldanie
    Rldanie Punisher78
    Colorado
    2002 Supercharged, 2” pulley, FIC, Methanol, Transgo Shift Kit
    Engine Performance upgrades: Supercharged (Magnuson) FIC/6 Champion Radiator Toyota Corolla thermostat 168° JBA Headers JBA cat back exhaust Upgraded fuel pump Volant Cold Air Intake With custom plexiglass cover TransGo Transmission A340F Valve Body upgrade B&M Transmission cooler Methanol Injection 2 inch pulley Future Plans Supra Injectors Light weight crankshaft pulley Leather seats Off-road upgrades 3” rough country lift 33x12.5” Dick Cepeks Other upgrades: JL Audio 12W6 Sub in custom box JL Audio C5 Mids and tweets all the way around Sound dampened whole cab Transmission temp sensor Gen Tex rear view mirror (temp and compass) Blue instrument panel, a/c control panel lights, shifter, ashtray, glove box. Blacked out badges Blackout bumpers and grill MariMoto Projectors with demon eyes LED Taillights Second generation leather steering wheel with audio controls Custom leather wrapped automatic transmission shifter 3rd gen 4 Runner key ring light (blue) 3rd gen 4 Runner hood scoop
    Methanol is up and running! It wasn’t spraying, not sure why because I primed it.
    Pulled all the hoses off and primed it into a bucket. Up and spraying now and AFRs drop when I prime.
    Thanks for everyone’s input and help!
    Learned a lot and the examples are helpful
    Special thanks to John for taking my calls and text and helping me though the ups and downs of all this!
    jubei, eon_blue, cruiserguy and 2 others like this.
  3. Oct 28, 2019 at 7:30 PM
    #683
    1997tacomav6
    Denver
    If the AFR is not changing with the methonal kit installed when the set points are hit it’s probably a delivery issue of methonal or the setting of the kit or plugged nozzle if it has 10,000 miles or so all depending on each setup of course
    cruiserguy and CHMM[OP] like this.
  4. Oct 28, 2019 at 7:31 PM
    #684
    CHMM
    CHMM [OP] GTO
    Gabe
    Castle Rock, Colorado
    2001 TRD Xtra Cab 4x4 Supercharged
    5100s SPC UCAs Energy bushings #70 spring clutch mod Supercharged
    That’s pretty awesome trouble shooting.
  5. Oct 28, 2019 at 7:43 PM
    #685
    CHMM
    CHMM [OP] GTO
    Gabe
    So say I keep the stock pulley. I install methanol at 4 PSI to spray. My AFR numbers with no methanol are ok. The methanol would save me gas as the ECU will adjust and not add gas. If the methanol plugs up, the ECU will adjust again and add gas. Does this make any sense?
  6. Oct 28, 2019 at 7:49 PM
    #686
    1997tacomav6
    Denver
    Methonal is for when your in boost and you need the added fuel to keep the AFR happy, it’s adding fuel.
    Regular driving down the road it’s not needed and is cheaper to not have it spraying,
    If you kept the stock pulley it would help out in the summer to keep everything cool and not have heat soaked issues
  7. Oct 29, 2019 at 5:16 AM
    #687
    CHMM
    CHMM [OP] GTO
    Gabe
    AFR gauge stuck at 22.4. Is it broken? I’m super frustrated. Just spent like $800 to put it in. About to take it off and call this project complete.
  8. Oct 29, 2019 at 5:23 AM
    #688
    1997tacomav6
    Denver
    Probably something simple, Thursday have them look at it,
  9. Oct 29, 2019 at 5:24 AM
    #689
    CHMM
    CHMM [OP] GTO
    Gabe
    man it’s turning into an Ford
  10. Oct 29, 2019 at 5:24 AM
    #690
    1997tacomav6
    Denver
    Labor of love :)
    I have had zero issues with mine
  11. Oct 29, 2019 at 5:49 AM
    #691
    Rldanie
    Rldanie Punisher78
    Colorado
    I feel your pain
    There is a solution
    John will help you through it
    CHMM[OP] likes this.
  12. Oct 29, 2019 at 5:56 AM
    #692
    Rldanie
    Rldanie Punisher78
    Colorado
    Try Calibrating it
    Unplug the sensor and turn on the innovate gauge
    It will read an error code in the upper left-hand corner O2 E2 I believe
    Wait 30 seconds And turn it back off
    Remove the sensor from the Exhaust pipe
    Plug it back in
    Turn the gauge back on and wait 30 seconds
    Reconnect your sensor and start of the engine
    See if that helps
  13. Oct 29, 2019 at 6:03 AM
    #693
    CHMM
    CHMM [OP] GTO
    Gabe
    Thanks.
  14. Oct 29, 2019 at 6:17 AM
    #694
    CHMM
    CHMM [OP] GTO
    Gabe
    I’ll have them look at it Thursday. It’s probably me power washing the undercarriage yesterday. It’s been cold. Who knows.
  15. Oct 29, 2019 at 7:07 AM
    #695
    CHMM
    CHMM [OP] GTO
    Gabe
    I think it’s a recalibration deal. That’s what other forums are saying. Where is that sensor? Is it behind the cat? Thanks
  16. Oct 29, 2019 at 7:36 AM
    #696
    1997tacomav6
    Denver
    It would be welded right infront of the 1st cat
    Pretty obvious, but I would just wait till Thursday incase there was some issues when it was installed and they can fix it
  17. Oct 29, 2019 at 7:38 AM
    #697
    CHMM
    CHMM [OP] GTO
    Gabe
    Ok.
    1997tacomav6[QUOTED] likes this.
  18. Oct 29, 2019 at 8:14 AM
    #698
    Rldanie
    Rldanie Punisher78
    Colorado
    I was just going to say that
    You paid them to install it
    They need to make sure it’s working
    1997tacomav6 and CHMM[OP] like this.
  19. Oct 29, 2019 at 8:17 AM
    #699
    Rldanie
    Rldanie Punisher78
    Colorado
    It is recommended to recalibrate every so often depending on application
    Racers recalibrate every race weekend
  20. Oct 29, 2019 at 8:17 AM
    #700
    CHMM
    CHMM [OP] GTO
    Gabe
    Yeah it’s only been a couple weeks. It should be a little more resilient.
