3.4L supercharger
Discussion in '1st Gen. Tacomas (1995-2004)' started by CHMM, Sep 14, 2019.
  1. Oct 29, 2019 at 8:18 AM
    #701
    CHMM
    CHMM [OP] GTO
    Gabe
    Castle Rock, Colorado
    2001 TRD Xtra Cab 4x4 Supercharged
    5100s SPC UCAs Energy bushings #70 spring clutch mod Supercharged
    Recal could fix it but then again....
  2. Oct 29, 2019 at 8:20 AM
    #702
    Rldanie
    Rldanie Punisher78
    Colorado
    2002 Supercharged, 2” pulley, FIC, Methanol, Transgo Shift Kit
    Engine Performance upgrades: Supercharged (Magnuson) FIC/6 Champion Radiator Toyota Corolla thermostat 168° JBA Headers JBA cat back exhaust Upgraded fuel pump Volant Cold Air Intake With custom plexiglass cover TransGo Transmission A340F Valve Body upgrade B&M Transmission cooler Methanol Injection 2 inch pulley Future Plans Supra Injectors Light weight crankshaft pulley Leather seats Off-road upgrades 3” rough country lift 33x12.5” Dick Cepeks Other upgrades: JL Audio 12W6 Sub in custom box JL Audio C5 Mids and tweets all the way around Sound dampened whole cab Transmission temp sensor Gen Tex rear view mirror (temp and compass) Blue instrument panel, a/c control panel lights, shifter, ashtray, glove box. Blacked out badges Blackout bumpers and grill MariMoto Projectors with demon eyes LED Taillights Second generation leather steering wheel with audio controls Custom leather wrapped automatic transmission shifter 3rd gen 4 Runner key ring light (blue) 3rd gen 4 Runner hood scoop
    Did you get a new muffler since this change?
  3. Oct 29, 2019 at 8:29 AM
    #703
    CHMM
    CHMM [OP] GTO
    Gabe
    I did but it was working fine for a week after.
  4. Oct 29, 2019 at 8:39 AM
    #704
    CHMM
    CHMM [OP] GTO
    Gabe
    I’m gonna do what John said. Also bringing some safety glasses on Thursday and going in to get some hands on with the methanol and AFR system. I need to know where and what and how.
    cruiserguy likes this.
  5. Oct 29, 2019 at 9:51 AM
    #705
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    I recommend reading the manual for the gauge. You’d learn about the recalibration and other things about it.
    CHMM[OP] likes this.
  6. Oct 29, 2019 at 12:15 PM
    #706
    CHMM
    CHMM [OP] GTO
    Gabe
    It’s just might be something up with the install like John said.
  7. Oct 29, 2019 at 12:17 PM
    #707
    CHMM
    CHMM [OP] GTO
    Gabe
    It’s also 10 degrees out LOL
    otis24 likes this.
  8. Oct 29, 2019 at 12:29 PM
    #708
    eon_blue
    Azusa, CA
    Which gauge did you get again @CHMM? Was it the AEM one at the bottom or the boost + AFR gauge that John has?
    Reason I ask is because the AEM gauges come with Bosch branded sensors for the Wideband O2...and a lot of people don't like Bosch sensors saying they don't hold up that well. Mine has so far *knock on wood* but something to consider, might be a bad sensor that came with the gauge
  9. Oct 29, 2019 at 12:32 PM
    #709
    CHMM
    CHMM [OP] GTO
    Gabe
    I have the one John has. That’s a good point. Everything else is good. We have a winter weather alert and still managed to safely hit 7 PSI.
  10. Oct 29, 2019 at 12:34 PM
    #710
    eon_blue
    Azusa, CA
    I'm not sure what brand O2 sensor those kits come with...I know a lot of guys with the AEM AFR gauge ditch the Bosch sensors for Denso ones instead. If/when mine goes kaput one day I'll end up doing the same
  11. Oct 29, 2019 at 12:44 PM
    #711
    CHMM
    CHMM [OP] GTO
    Gabe
    Is that sensor tapped in during install? Or is it from factory?
  12. Oct 29, 2019 at 12:55 PM
    #712
    eon_blue
    Azusa, CA
    Its the sensor that comes with the kit, gets installed in front of the cat/after the headers. They drill a hole for it there, weld in a bung and then thread that sensor into it. If the sensor is bad you just have to take it out and put a new one in, and connect it to the wiring harness for the AFR sensor. Would be just like replacing one of your factory O2 sensors except easier since the wiring is more accessible
  13. Oct 29, 2019 at 1:00 PM
    #713
    CHMM
    CHMM [OP] GTO
    Gabe
    Ok I see it. Thanks
    eon_blue[QUOTED] likes this.
  14. Oct 29, 2019 at 1:10 PM
    #714
    CHMM
    CHMM [OP] GTO
    Gabe
    Truck runs awesome. That’s all I care about.
    eon_blue likes this.
  15. Oct 29, 2019 at 1:14 PM
    #715
    eon_blue
    Azusa, CA
    Either that sensor needs replacing or maybe the wiring for it got knocked loose/partially disconnected, I bet it's an easy solution to get the AFR gauge running right again.
  16. Oct 29, 2019 at 1:18 PM
    #716
    CHMM
    CHMM [OP] GTO
    Gabe
    Yeah. Thanks man. I just looked under there in the garage and got soaked from snow melt on the garage floor. I held it there looking till it got pretty cold. LOL.
  17. Oct 29, 2019 at 1:26 PM
    #717
    CHMM
    CHMM [OP] GTO
    Gabe
    Aside from my tantrum this morning.... sorry.
    otis24 and cruiserguy like this.
  18. Oct 29, 2019 at 7:43 PM
    #718
    kigmob
    kigmob Well-Known Member
    James
    New Orleans
    97 TRD S/C 4x4 V6 5spd
    ICON/TC TRD Supercharger URD 2.2 and 7th
    Do you not have the closed loop enrichment built into your 7th injector controller? If so, You should be able to set at what psi of boost the enrichment begins. I have mine set to 1 psi. So anytime I hit boost the afr starts to slowly drop then if I remember correctly, at around 4 psi and 3k rpms is when the 7th is firing. The closed loop enrichment does not use the 7th for the extra fuel, instead I believe the controller intercepts the MAF signal and tricks the ecu to add more fuel while sending a false 14.7 afr to the ECU so it won’t fight it. Atleast that’s how it is for me.
  19. Oct 29, 2019 at 7:48 PM
    #719
    eon_blue
    Azusa, CA
    I haven't messed with tuning it yet but I really need to. I just don't have the right kind of laptop for it...I think I have the software though that someone sent me awhile back. I'll have to reach out to you about this... I really need to do this. Having it spray at 1 psi would really help eliminate the pinging I still get under certain conditions
  20. Oct 29, 2019 at 7:50 PM
    #720
    CHMM
    CHMM [OP] GTO
    Gabe
