3.4L supercharger
Discussion in '1st Gen. Tacomas (1995-2004)' started by CHMM, Sep 14, 2019.
  1. Nov 9, 2019 at 7:55 PM
    #981
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    You may need one. Some people do while others seem to get by without. I’d bet that most just swapped it out.
    DO NOT get a Walbro. They’re garbage and make a shiton on noise. Super loud screaching noise that I spent an extra $100 and going through the PITA process of changing the pump again for.
    Rldanie[QUOTED] and Speedytech7 like this.
  2. Nov 9, 2019 at 7:56 PM
    #982
    Rldanie
    Rldanie Punisher78
    Colorado
    2002 Supercharged, 2” pulley, FIC, Methanol, Transgo Shift Kit
    Engine Performance upgrades: Supercharged (Magnuson) FIC/6 Champion Radiator Toyota Corolla thermostat 168° JBA Headers JBA cat back exhaust Upgraded fuel pump Volant Cold Air Intake With custom plexiglass cover TransGo Transmission A340F Valve Body upgrade B&M Transmission cooler Methanol Injection 2 inch pulley Future Plans Supra Injectors Light weight crankshaft pulley Leather seats Off-road upgrades 3” rough country lift 33x12.5” Dick Cepeks Other upgrades: JL Audio 12W6 Sub in custom box JL Audio C5 Mids and tweets all the way around Sound dampened whole cab Transmission temp sensor Gen Tex rear view mirror (temp and compass) Blue instrument panel, a/c control panel lights, shifter, ashtray, glove box. Blacked out badges Blackout bumpers and grill MariMoto Projectors with demon eyes LED Taillights Second generation leather steering wheel with audio controls Custom leather wrapped automatic transmission shifter 3rd gen 4 Runner key ring light (blue) 3rd gen 4 Runner hood scoop
    AEM?
  3. Nov 9, 2019 at 7:57 PM
    #983
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Or Aeromotive
  4. Nov 9, 2019 at 7:57 PM
    #984
    Shortman5
    Supercharged TRD
    Should work fine. I got a Deatchwerks. I may have spelled that wrong but it’s a strange spelling to begin with. So I just go with that.
    Rldanie[QUOTED] likes this.
  5. Nov 9, 2019 at 8:00 PM
    #985
    Rldanie
    Rldanie Punisher78
    Colorado
    Going to start by putting my stock pulley back on
    Cleaning up my air sensor on my intake ...... John discovered that it was very dirty
    And adding a new fuel pump
    I’ll check my AFR from there
    Going to take me a little while to come up with the money for the FIC and boom slang.
    Thanks!
    CHMM[OP] and 1997tacomav6 like this.
  6. Nov 9, 2019 at 8:06 PM
    #986
    Shortman5
    Supercharged TRD
    Drive with O/D off in town. And leave ECT power on. consider something like a Borla Pro XS to reduce back pressure. Those things may help reduce the ping.
  7. Nov 9, 2019 at 8:17 PM
    #987
    CHMM
    CHMM [OP] GTO
    Gabe
    Castle Rock, Colorado
    2001 TRD Xtra Cab 4x4 Supercharged
    5100s SPC UCAs Energy bushings #70 spring clutch mod Supercharged
    That’s what I have back in. I do octane booster for insurance every other tank and sea foam and alternate. It makes me feel good I guess and allows a little more freedom in driving style and gears. The wife is starting to like driving it and asking to go for drives. I don’t have to worry as much LOL.
  8. Nov 9, 2019 at 8:22 PM
    #988
    eon_blue
    Azusa, CA
    If you're going to use octane boosters, there are only a couple worth buying...the ones you get at most auto stores and gas stations do pretty much nothing (can take a dozen of them just to increase the octane rating by 1 point).
    Torco is the brand I've heard recommended the most, but there are a couple others more readily available online
    https://www.thedrive.com/reviews/28072/best-octane-boosters
    CHMM[QUOTED][OP] likes this.
  9. Nov 9, 2019 at 8:27 PM
    #989
    CHMM
    CHMM [OP] GTO
    Gabe
    I would go slow. We were expecting 4 psi at this altitude (6000 feet) and got up to 7 on a stock pulley. Each truck is different. Auto tranny is different than MT. There will be stupid check engine lights. It’s always been easy like a hose was too old, hose came loose etc... the MAF is the brain. The newer the better on the MAF. I think It’s important to work out all the kinks before upgrading pulleys etc,,, you will look forward To driving.
    1997tacomav6 likes this.
  10. Nov 9, 2019 at 8:29 PM
    #990
    Shortman5
    Supercharged TRD
    These guys make good stuff. Pricey but good.
    https://www.vpracingfuels.com/madditives/
    CHMM[OP] and eon_blue[QUOTED] like this.
  11. Nov 9, 2019 at 8:30 PM
    #991
    CHMM
    CHMM [OP] GTO
    Gabe
    The most benefit I’ve gotten is from the sea foam. It’s smooths it all out and less noises. You are correct with the boosters. I’m not feeling anything.
    eon_blue[QUOTED] likes this.
  12. Nov 9, 2019 at 8:33 PM
    #992
    Shortman5
    Supercharged TRD
    I filled up once and my truck was pinging like crazy. Like super loud. I was worried I did something to my motor it was so bad. I bought that VP stuff from autozone and it cleans it right up.
    I got bad gas, or someone put 87 in the 93 tank.
  13. Nov 9, 2019 at 8:35 PM
    #993
    eon_blue
    Azusa, CA
    I'm always a bit afraid of that happening. One time in 3 years I accidentally hit 87 by mistake when filling up...after a few gallons I realized what I had done and restarted the pump with 91, just drove conservatively until the next tank
    CHMM[OP] likes this.
  14. Nov 9, 2019 at 8:37 PM
    #994
    CHMM
    CHMM [OP] GTO
    Gabe
    That’s
    that’s awesome to know as an option when it’s 100 degrees out
  15. Nov 9, 2019 at 9:04 PM
    #995
    jdmstuff
    jdmstuff Well-Known Member
    Derrick
    Torrance, CA and Las Vegas, NV
    '18 TRD OR DCSB AT, '08 TRD Sport DCSB AT, '03 TRD 3.4l 4x4 MT Supercharged
    Thanks for the advice. I was planning on just bolting it on for now and running it as is for a while. I'm about to hit 100k on the odo and have an MT. I see some of you are running IK22 plugs. Should I just throw those in while I'm at it? I've been running 91 in the tank since I bought the truck in early July.
  16. Nov 9, 2019 at 9:09 PM
    #996
    eon_blue
    Azusa, CA
    I wouldn't put the ik22 spark plugs in until you install the supercharger.
  17. Nov 9, 2019 at 9:11 PM
    #997
    CHMM
    CHMM [OP] GTO
    Gabe
    I run those plugs. It’s what everyone recommended and the ones I had wee were 18 year old. Those plugs work better. I wound up doing the Timing belt and water pump (18 years old) drive belts. Etc...I did the thermostat too. I am not planning on selling this truck so it didn’t matter.
  18. Nov 9, 2019 at 9:17 PM
    #998
    CHMM
    CHMM [OP] GTO
    Gabe
    I would get the AFR gauge. It will help you drive the truck and know your boost and AFR. Also, John (1997Tacoma) has run a S/C for years and years. He’s pretty much seen and done it all. He’s an awesome resource for questions, advice and help. His truck is amazing
    Rldanie and 1997tacomav6 like this.
  19. Nov 9, 2019 at 9:22 PM
    #999
    BlackSportD
    BlackSportD Well-Known Member
    Los Angeles
    Icon/TC Mid travel, TRD S/C, PNP Greddy EMU, 625cc injectors, 2.2 pulley, Hayden tranny cooler, AEM wideband, TRD boost gauge.
    If our type of supercharger is too eager to go into boost maybe your diaphragm in the bypass is leaking, bad vacuum line to it, vacuum leaks in general or you have some kind of drag be it trans, rear diff, heavier rims etc making you have to throttle more while driving.
    The supercharger bypass is really simple. Vacuum in the manifold due to closed throttle, bypass enabled to recirculate charge air. Start to open up the throttle to leave a red light, get on freeway etc and vacuum drops in the manifold and the bypass will start to close up, forcing supercharged air into the engine.
    If your blower is super eager to boost, I would check the bypass setup.
  20. Nov 9, 2019 at 9:24 PM
    #1000
    eon_blue
    Azusa, CA
    Yeah you definitely have to run 2 step cooler spark plugs with the supercharger (Ik22)...if you don't you'll get spark knock which sounds a lot like pinging and it will hinder performance.
