3.4L supercharger
Discussion in '1st Gen. Tacomas (1995-2004)' started by CHMM, Sep 14, 2019.
  1. Nov 9, 2019 at 10:04 PM
    #1001
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    What gear ratio are you running? Have you re-geared?
  2. Nov 9, 2019 at 10:10 PM
    #1002
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    I want to but no. I’m going to smaller lighter tires first. I have some 17” wheels that are 21lbs a piece with 255s might get 265/75s instead though. After that I’d like to get 4:56. 4:88 would be cool to try.
    Digiratus[QUOTED] likes this.
  3. Nov 9, 2019 at 11:21 PM
    #1003
    Digiratus
    Roaming the PNW
    The RedHead
    It seems like all this talk about open loop closed loop and when that transition occurs, the impact it has on the way the MP62 behaves with the ECU on the 5VZ-FE is all about the load on the motor and mitigating that impact.
    This has a very familiar feel to it. Being NA, this is exactly what many of us were dealing with as our rigs got heavier and our tires got bigger.
    Re-gearing changed that playing field dramatically.
  4. Nov 9, 2019 at 11:37 PM
    #1004
    Shortman5
    Supercharged TRD
    yeah. I’m sure tire size and weight play a big role. Maybe even the single biggest issue with people that have pingy motors with the S/C. Everyone looking in the wrong direction for the fix.
    The new wheel setup is close to 15lb lighter per corner. And I could even go to a 265/70 which would be 1/2 shorter than the 255s. I’m curious how much difference 1/2” would make weight being the same.
    CHMM[OP] and 1997tacomav6 like this.
  5. Nov 9, 2019 at 11:39 PM
    #1005
    eon_blue
    Azusa, CA
    When I bought my truck though it was completely stock minus the supercharger and the closed loop ping was terrible, worse than it is now (though now I have the 7th injector)
    That being said I can see how regearing could help now that I do have a bunch of added weight along with the 7th injector...admittedly I hadn't thought of that until now that it was brought up.
    I think the big issue early on was not only the closed loop ping but also open loop, though it was still very much an issue in closed loop when it was all stock (supercharger, no lift, no armor, 31s, etc)
  6. Nov 10, 2019 at 12:15 AM
    #1006
    Digiratus
    Roaming the PNW
    The RedHead
    Re-gearing is a very expensive fix
    Are you still on stock 4.10 gearing?
  7. Nov 10, 2019 at 12:49 AM
    #1007
    eon_blue
    Azusa, CA
    Yep, still 4.10
  8. Nov 10, 2019 at 4:14 AM
    #1008
    1997tacomav6
    Denver
    @Rldanie
    Didnt think of this but like said below maybe his going into boost early when in overdrive is also because of his dam BIG HEAVY rock crawling type tires and rims.
    I don’t know but I’m thinking his tires and rims are very very heavy compared to a stock tire and rims. Maybe it’s a combination of thing working here with the smaller pulley (that boosts sooner), in overdrive, that lugs more on a hill), tire size and weight(wheel ratio changed) and running lean in boost (not getting full power).
    What size tires and rims and weight are these coming in at each?
    Potential combined issues causing the problem,
    1) the larger tire size possibly Affecting the drive train ratio (more power needed)
    2) the added weight of the larger tires and rims per corner. (more power needed)
    3) auto transmission in overdrive causing the engine to lug. (more power needed)
    4) 2” pulley will trip the supercharger into boost sooner under load
    5) MAF is running lean at 14 under boost so engine running short on power
    6) MAF really dirty and 18 years old
    7) All of this potentially will make the truck run hotter too.
    8) An engine that runs lean will raise the engine temperature too ( run hotter)
    and Ryan was saying in boost his temperature was going higher to 200 degrees. Out of boost it came down.
    So his load is completely different than mine even tho the engine setup is similar with a different end result.
    The new wheel setup is close to 15lb lighter per corner. And I could even go to a 265/70 which would be 1/2 shorter than the 255s. I’m curious how much difference 1/2” would make weight being the same.”
    CHMM[OP] and Rldanie like this.
  9. Nov 10, 2019 at 7:49 AM
    #1009
    CHMM
    CHMM [OP] GTO
    Gabe
    Castle Rock, Colorado
    2001 TRD Xtra Cab 4x4 Supercharged
    5100s SPC UCAs Energy bushings #70 spring clutch mod Supercharged
    it makes a big difference. Tire size, weight and width. On mine I went from 265 to 245 (skinnier). Easier to roll, better off road. They are 41 pounds which isn’t too bad for an LT tire.
    1997tacomav6 likes this.
  10. Nov 10, 2019 at 8:11 AM
    #1010
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    I'll be able to tell you what going from 265/70r16 to 265/75r16 is around the middle of January. I'm running 4:30 gears.
  11. Nov 10, 2019 at 8:27 AM
    #1011
    Shortman5
    Supercharged TRD
    yep, still stock. How much is a regear?
  12. Nov 10, 2019 at 8:40 AM
    #1012
    CHMM
    CHMM [OP] GTO
    Gabe
    My buddy did his third gen for $2300. The 3rd gen is famous for gear hunting even in stock wheels. Mine did that especially up a hill. It’s geared too tall from the factory. Huge difference for him and more power after re-gear.
  13. Nov 10, 2019 at 9:10 AM
    #1013
    Shortman5
    Supercharged TRD
    Damn that’s high.
  14. Nov 10, 2019 at 9:12 AM
    #1014
    Shortman5
    Supercharged TRD
    Is 4:30 stock for a trim?
  15. Nov 10, 2019 at 9:25 AM
    #1015
    Digiratus
    Roaming the PNW
    The RedHead
  16. Nov 10, 2019 at 9:28 AM
    #1016
    anewman9
    anewman9 Well-Known Member
    Austin
    ATX
    1997 Tacoma Ext
    ARB Bumpers. Warn Winch Bilstein 3in lift. kargo Master Roof rack. K&N CAI. Mickey Thompson Classic II
    Any of these laying around FS?
  17. Nov 10, 2019 at 9:35 AM
    #1017
    mechanicjon
    Jon
    Scottsdale Arizona
    4runner 3rds.
  18. Nov 10, 2019 at 9:37 AM
    #1018
    Shortman5
    Supercharged TRD
    Buy new with a warranty.
  19. Nov 10, 2019 at 9:38 AM
    #1019
    mechanicjon
    Jon
    Scottsdale Arizona
    A 4:30 front fell in my lap and a TW member wanted to trade his 4:30 elocker for a 4:10.
    Cost me $80 in shipping. To good to pass up.
    cruiserguy likes this.
  20. Nov 10, 2019 at 9:38 AM
    #1020
    Shortman5
    Supercharged TRD
    Cool, I’ll take a look around. Maybe they come with a E locker.
