3.4L supercharger
Discussion in '1st Gen. Tacomas (1995-2004)' started by CHMM, Sep 14, 2019.
  1. Nov 14, 2019 at 9:59 AM
    #1081
    Rldanie
    Rldanie Punisher78
    Colorado
    2002 Supercharged, 2” pulley, FIC, Methanol, Transgo Shift Kit
    Engine Performance upgrades: Supercharged (Magnuson) FIC/6 Champion Radiator Toyota Corolla thermostat 168° JBA Headers JBA cat back exhaust Upgraded fuel pump Volant Cold Air Intake With custom plexiglass cover TransGo Transmission A340F Valve Body upgrade B&M Transmission cooler Methanol Injection 2 inch pulley Future Plans Supra Injectors Light weight crankshaft pulley Leather seats Off-road upgrades 3” rough country lift 33x12.5” Dick Cepeks Other upgrades: JL Audio 12W6 Sub in custom box JL Audio C5 Mids and tweets all the way around Sound dampened whole cab Transmission temp sensor Gen Tex rear view mirror (temp and compass) Blue instrument panel, a/c control panel lights, shifter, ashtray, glove box. Blacked out badges Blackout bumpers and grill MariMoto Projectors with demon eyes LED Taillights Second generation leather steering wheel with audio controls Custom leather wrapped automatic transmission shifter 3rd gen 4 Runner key ring light (blue) 3rd gen 4 Runner hood scoop
    Not yet
    Working on it tonight
  2. Nov 14, 2019 at 7:12 PM
    #1082
    Rldanie
    Rldanie Punisher78
    Colorado
    Put the stock pulley back on, spraying at 5 psi (Just to clean things at this point)
    Running about 13 AFR at 6.5 psi boost WOT
    Stays at 14.7 at anything less than WOT ...ALL boost levels.
    Cleaned the Air sensor and added a bottle of sea foam at fill up.
    Next step: upgrade fuel pump
    Ordered some Supra injectors
    Saving up for FIC-6 and harness
  3. Nov 14, 2019 at 7:22 PM
    #1083
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    Just so we’re clear on a few things. Those injectors won’t help without something to tune them. In fact they probably won’t work well at all without something to tune them. That will compromise driving even in vacuum. You’re better off getting the FIC first to tune closed loop.
    the only reason people install larger injectors with the S/C is to keep it from leaning out at WOT high RPM. Which is what the 7th is for. To add just a little bit of fuel to keep the injectors from maxing out.
    it’s possible you’re leaning out but you can spray more meth to fix that. In open loop the computer won’t fight to keep the AFR like in closed loop. You’re looking for 11.5AFR WOT around 5000rpm.
  4. Nov 14, 2019 at 7:32 PM
    #1084
    Rldanie
    Rldanie Punisher78
    Colorado
    Good feedback
    John has advised me of the same for the AFR 11 to 12
    I’ve found it takes 5-8 seconds of 3/4 to WOT for the ECU to give up and go open loop with the auto transmission..thoughts?
    Just bought the Supra injectors because they were remans and there were only 5 sets left.
    I will take pictures and post . Looking for feedback to make sure they’re legit
    The big purchase is my harness from boom sling $499
    Going to focus on a new fuel pump and CC1998 radiator until I can get the fund together for the FIC.
    Transgo has made my trunk much more fun to drive...thanks for the help on that.
    How come you have stayed away from the 2” pulley?
  5. Nov 14, 2019 at 7:42 PM
    #1085
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    Weird. My 2003 auto takes less than 1 second to go to open loop with WOT. And I'm sure in reality it is less since the ScanGauge is showing status over the super slow ODB II data protocol our trucks have.
    Rldanie[QUOTED] likes this.
  6. Nov 14, 2019 at 7:47 PM
    #1086
    Rldanie
    Rldanie Punisher78
    Colorado
    Maybe
    I’m basing it off of my AFR dropping to low 12s. I don’t have a scan gauge
    The drop is really apparent and the increase in hp is too
  7. Nov 14, 2019 at 7:50 PM
    #1087
    eon_blue
    Azusa, CA
    If I mash the pedal WOT it'll go into open loop right away and AFRs quickly drop into low 12s/high 11s, but 3/4 throttle does take a few seconds to see any AFR change regardless of boost.
    CHMM[OP] and Rldanie like this.
  8. Nov 14, 2019 at 7:51 PM
    #1088
    JasonLee
    15 TRD OffRoad
    So ... to extrapolate.... I wonder if the TPS sensor is reading full sweep. My ScanGauge shows my open throttle TPS reading is ~17 and my WOT is only like ~87...
    Maybe @Rldanie should check their TPS sensor values.
  9. Nov 14, 2019 at 7:52 PM
    #1089
    Rldanie
    Rldanie Punisher78
    Colorado
    I’ll test this a little more
    Maybe I just need to learn how to drive...lol
  10. Nov 14, 2019 at 7:53 PM
    #1090
    Rldanie
    Rldanie Punisher78
    Colorado
    You just lost me TPS?
  11. Nov 14, 2019 at 7:55 PM
    #1091
    eon_blue
    Azusa, CA
    The delay in going from closed loop to open loop is normal in anything but WOT. It's the ECU doing it's thing trying to keep the AFRs at 14.7 until it finally gives in and switches to open loop. I can't find it but awhile ago I found a chart on another forum someone posted that had the # of seconds it takes to go from open to closed loop based on throttle input. Seemed to make sense based on my experience anyway.
    The only time it'll instantly go from closed to open loop is during WOT.
    CHMM[OP] and 1997tacomav6 like this.
  12. Nov 14, 2019 at 8:00 PM
    #1092
    1997tacomav6
    Denver
    He actually has pretty large tires that might change those numbers?
    Rldanie likes this.
  13. Nov 14, 2019 at 8:00 PM
    #1093
    JasonLee
    15 TRD OffRoad
    Throttle Position sensor. I'm not sure how your 2002 is configured as the 2003-2004 have the partial throttle by wire with a TPS (Throttle Position Sensor) combined with an APPS (Accelerator Pedal Position Sensor).
  14. Nov 14, 2019 at 8:01 PM
    #1094
    JasonLee
    15 TRD OffRoad
    That's one thing that is missing from this thread is all of the variables. Wheel weight, tire weight, tire diameter, axle gearing, truck weight ... None of us are comparing the same thing, making this less than scientific.
  15. Nov 14, 2019 at 8:01 PM
    #1095
    Rldanie
    Rldanie Punisher78
    Colorado
    33”x 12.5 “
    1997tacomav6[QUOTED] likes this.
  16. Nov 14, 2019 at 8:11 PM
    #1096
    1997tacomav6
    Denver
    increasing tire diameter decreases RPM's to achieve the same speed which will is why the rpms
    are low in overdrive too
  17. Nov 15, 2019 at 4:02 AM
    #1097
    CHMM
    CHMM [OP] GTO
    Gabe
    Castle Rock, Colorado
    2001 TRD Xtra Cab 4x4 Supercharged
    5100s SPC UCAs Energy bushings #70 spring clutch mod Supercharged
    When they did my supercharger install, they automatically did the thermostat and radiator cap. They kept it at 0.9 KPa. Your cap looked original. I would replace it for $5.
  18. Nov 15, 2019 at 4:06 AM
    #1098
    CHMM
    CHMM [OP] GTO
    Gabe
    Yup. That’s what I do. I hit 2500 RPMs and floor it. Or just cruise nice. Half throttle options are to press it fast half way and most of the time that will open loop it. But it has to be a fast throttle press.
    Rldanie likes this.
  19. Nov 15, 2019 at 4:08 AM
    #1099
    CHMM
    CHMM [OP] GTO
    Gabe
    Try pressing it fast. I’m also experimenting with WOT and how far I can pull back and keep the 11-12 AFR.
  20. Nov 15, 2019 at 4:09 AM
    #1100
    CHMM
    CHMM [OP] GTO
    Gabe
    Supra injectors? You have a link?
