3.4L supercharger
Discussion in '1st Gen. Tacomas (1995-2004)' started by CHMM, Sep 14, 2019.
  1. Nov 22, 2019 at 3:53 PM
    #1161
    eon_blue
    Azusa, CA
    Also location plays a role, closer to sea level and/or in a hot climate more likely to ping
  2. Nov 22, 2019 at 3:56 PM
    #1162
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    Correct. But on these trucks it’s a timing issue. Not a actual detonation issue. If it was actually detonating we’d probably see more failures.
    eon_blue[QUOTED] likes this.
  3. Nov 22, 2019 at 3:58 PM
    #1163
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    Yeah, so it's going to suck building the truck in Colorado above 5000 ft and then taking trips down to sea level only to find out I'll be spending time tuning, changing pulleys, removing the belt ... :angrygirl:
  4. Nov 22, 2019 at 3:58 PM
    #1164
    eon_blue
    Azusa, CA
    that makes me feel a little better about it, it's true I haven't really read of many stories of boosted failures on here over the years. One comes to mind but I remember the guy saying he constantly floored it around town even though it pinged like crazy, one day on the highway he went to pass a semi and floored it despite pinging and threw a rod. Can't remember the guy's username but its on TW somewhere
    frenchee likes this.
  5. Nov 22, 2019 at 7:38 PM
    #1165
    CHMM
    CHMM [OP] GTO
    Gabe
    Castle Rock, Colorado
    2001 TRD Xtra Cab 4x4 Supercharged
    5100s SPC UCAs Energy bushings #70 spring clutch mod Supercharged
    So as I drove I’m trying different things. I’m cruising at 0 PSi and slowly upping the gas and it will got to 2 PSI and AFR goes to 13.8 from 14.8 and it’s sound good. If I push the gas a little more, it hits 12. It seems to be cooperating with me.
    eon_blue likes this.
  6. Nov 24, 2019 at 6:51 AM
    #1166
    Rldanie
    Rldanie Punisher78
    Colorado
    2002 Supercharged, 2” pulley, FIC, Methanol, Transgo Shift Kit
    Engine Performance upgrades: Supercharged (Magnuson) FIC/6 Champion Radiator Toyota Corolla thermostat 168° JBA Headers JBA cat back exhaust Upgraded fuel pump Volant Cold Air Intake With custom plexiglass cover TransGo Transmission A340F Valve Body upgrade B&M Transmission cooler Methanol Injection 2 inch pulley Future Plans Supra Injectors Light weight crankshaft pulley Leather seats Off-road upgrades 3” rough country lift 33x12.5” Dick Cepeks Other upgrades: JL Audio 12W6 Sub in custom box JL Audio C5 Mids and tweets all the way around Sound dampened whole cab Transmission temp sensor Gen Tex rear view mirror (temp and compass) Blue instrument panel, a/c control panel lights, shifter, ashtray, glove box. Blacked out badges Blackout bumpers and grill MariMoto Projectors with demon eyes LED Taillights Second generation leather steering wheel with audio controls Custom leather wrapped automatic transmission shifter 3rd gen 4 Runner key ring light (blue) 3rd gen 4 Runner hood scoop
    @BlackSportD
    I noticed that most people with a auto transmission don’t go past a 2.2 pulley
    Thoughts?
    Awesome “reverse mod” man!
  7. Nov 24, 2019 at 8:28 AM
    #1167
    Shortman5
    Supercharged TRD
    you’re really stuck on this pulley size thing. I hope you realize it’s possible to make more power with a bigger* pulley. The higher the boost the more HP it takes to drive the blower. Google how much HP it takes to drive a blower, you might be surprised.
    At the end of the day no matter what you do to the TRD S/C and the 190hp 5vz with no ECU tune available it will always be a sub 300hp truck.
    EDIT: Larger not smaller.
    Rldanie[QUOTED] likes this.
  8. Nov 24, 2019 at 9:03 AM
    #1168
    BlackSportD
    BlackSportD Well-Known Member
    Los Angeles
    Icon/TC Mid travel, TRD S/C, PNP Greddy EMU, 625cc injectors, 2.2 pulley, Hayden tranny cooler, AEM wideband, TRD boost gauge.
    Maybe because it makes the S/C just that much more itchy to boost sooner? I donno. I can imagine with more air to recerc plus that transition area for the bypass = a slightly more aggressive mid vaccum region for the bypass transition and the auto already loooves holding that tall gear and creating high load sub 2k rpm boost.
    This is me armchair tuning but I've read the trd blower is on the small side and going smaller pulley to make more boost is not a linear gain relationship. The s/c efficiency curve (or lack there of) is a more exponential one, so going smaller causes so much more heat you are fighting some serious diminishing returns.
    Everyone's S/C and VE is different, some people have the trd sc with no EMS and no problems, my 5vz is so pingy I expect on a cam shim/s and/or cylinder inspection that I have something seriously wrong so I can't imagine going to a smaller pulley. Or maybe my exhaust has an instruction or the cat is partially melted. In fact I might go back to stock or even underdrive.
    Rldanie[QUOTED] and LukeCC like this.
  9. Nov 24, 2019 at 9:16 AM
    #1169
    JasonLee
    15 TRD OffRoad
    rjf189 and CHMM[OP] like this.
  10. Nov 24, 2019 at 9:18 AM
    #1170
    Shortman5
    Supercharged TRD
    Probably not your cats. You would be getting other symptoms as well.
    it’s got to be the shitty transmission tune. Really banking on @OVTune here. I might just sell it all and get something else.
    BlackSportD[QUOTED] likes this.
  11. Nov 24, 2019 at 10:17 AM
    #1171
    Rldanie
    Rldanie Punisher78
    Colorado
    I am a little I guess
    I understand I am never going to get above 300hp...but I would like to get to 300 if I can.
  12. Nov 24, 2019 at 10:20 AM
    #1172
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    If you go twin charged you'll want the bigger pulley anyway, super easy to get boost creep and runaway with the SC pushing more than it has to. This SC is so puny anyway it'll just become a heat pump more than an air pump the farther you boost
  13. Nov 24, 2019 at 10:23 AM
    #1173
    Shortman5
    Supercharged TRD
    reading up on this twin charged thing Ive decided it wouldn’t be worth it at all. You’d just have a $3000 intake manifold you’d have to fuck with too much.
  14. Nov 24, 2019 at 10:24 AM
    #1174
    Speedytech7
    Yeah, single turbo is the way to go really. The SC just has the advantage of being an easy bolt on. That's about it.
  15. Nov 24, 2019 at 12:29 PM
    #1175
    CHMM
    CHMM [OP] GTO
    Gabe
    I hear you man. The thing is... you take a truck like ours, which is normally in the slow lane and then we supercharge it. Now we are in the fast lane with a stock pulley. No one thinks much of it. Then the BMW behind us tries to go around us up the hill on the freeway. You say F that-- go into boost. the BMW goes back behind you and drives behind wondering "WTF". What I'm trying to say is we have the element of surprise whenever we want. Now let's say the Raptor knows you're supercharged, he'll floor it too and kick our ass (Only John can take a Raptor). What I'm saying is It's a hell of a lot fun just to be supercharged and running good.
    1997tacomav6 and Rldanie[QUOTED] like this.
  16. Nov 24, 2019 at 1:01 PM
    #1176
    02hilux
    Planet: EARTH
    LMAO..... these Tacoma are still slow, even with the charger... sorry to burst your bubble about a fast supercharged Tacoma..
    JasonLee likes this.
  17. Nov 24, 2019 at 1:19 PM
    #1177
    CHMM
    CHMM [OP] GTO
    Gabe
    Its all relative It's fast or slow compared to what? a race car? Yes it's slower than a corvette or mustang. But it's faster stock than a 3rd gen Tacoma. What are you saying man?
  18. Nov 24, 2019 at 1:22 PM
    #1178
    Speedytech7
    That's the cool thing about these trucks. They're geared well, especially if they're a manual. Sure a 1996 Ford F250 V8 has more HP and TQ but I can run circles around one in my 96 4 banger taco or my 96 v6 taco
  19. Nov 24, 2019 at 1:27 PM
    #1179
    02hilux
    Planet: EARTH
    Im saying they're slow in general. As you mention, BMW saying WTF when trying to pass you up, are you comparing your truck to a E30?
  20. Nov 24, 2019 at 1:27 PM
    #1180
    CHMM
    CHMM [OP] GTO
    Gabe
    I'm with ya. Anything faster let's say a Vette or whatever cannot be off-roaded or driven in weather. S/C tacoma doesn't have that problem. A Raptor is fast but $$$$. Not to mention size and parking.
