3.4L supercharger
Discussion in '1st Gen. Tacomas (1995-2004)' started by CHMM, Sep 14, 2019.
  1. Dec 2, 2019 at 7:51 PM
    #1281
    eon_blue
    Azusa, CA
    When I first got my truck I thought it sounded like a dying cat, took some time for it to grow on me
    CHMM[QUOTED][OP] and otis24 like this.
  2. Dec 2, 2019 at 7:54 PM
    #1282
    CHMM
    CHMM [OP] GTO
    Gabe
    Castle Rock, Colorado
    2001 TRD Xtra Cab 4x4 Supercharged
    5100s SPC UCAs Energy bushings #70 spring clutch mod Supercharged
    It’s the bad ass cool guy sound.
    eon_blue[QUOTED] likes this.
  3. Dec 2, 2019 at 7:55 PM
    #1283
    kigmob
    kigmob Well-Known Member
    James
    New Orleans
    97 TRD S/C 4x4 V6 5spd
    ICON/TC TRD Supercharger URD 2.2 and 7th
    So I think my supercharger is shot. This morning the whine at cold idle sounded a bit more noticeable. Drove to work fine. Got in my truck to leave work and after about 5 minutes of driving starting getting a very loud knocking. Almost like the engine fan was hitting something. It would sort of go in and out. Pulled over and let the truck idle while it wasn’t making the very loud sound and I could hear some unusual rattle noises from the SC. I got in my truck and was going back it up some and it started knocking loud again so I shut it off to prevent any further damage. Got it towed home. When I got home I took the belt off and rotated the SC by hand. No noises but the force to spin it was inconsistent. Not very difficult, just not consistent. Felt like some light binding. Anyways I will have to do some more investigating this weekend. I’ve kept up with the maintenance other than a rebuild which I was planning on doing soon (literally in the next few months).
  4. Dec 2, 2019 at 7:58 PM
    #1284
    CHMM
    CHMM [OP] GTO
    Gabe
    Sorry man. How many miles on the S/C?
    1997tacomav6 likes this.
  5. Dec 2, 2019 at 8:23 PM
    #1285
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
    Ah, okay that clears it up for me. Thank you.
  6. Dec 2, 2019 at 8:24 PM
    #1286
    1997tacomav6
    Denver
    Depending on pulley size it’s normal to have to have the rebuilt at 150,000 -200,000 with stock pulley.
    Did you have to remove the headers to get the starter out?
    If your going to have it rebuilt nows the time to have it ported if you wanted
  7. Dec 2, 2019 at 8:30 PM
    #1287
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    We do things like this all the time at my work... Machinist
    Anywho, it's not easy when the endmill has to be so physically long, lots of chatter leads to a rough cut. Not saying it couldn't be smoothed and improved but it would be quite a few passes and tool changes and to physically reach the outlet section it would be a different story. I'm not even sure if the live tooling on a mill could do that. I think I'd sooner section the entire blower housing and weld it back together after the work is done.
    My point being it's cost prohibitive, good gains for an undersized supercharger for sure. But not gains I'd think most would be willing to pay for.
  8. Dec 2, 2019 at 8:37 PM
    #1288
    kigmob
    James
    New Orleans
    I believe I was approaching 150k. I did have to loosen some of the flanges on the headers to get enough clearance for the starter.
  9. Dec 2, 2019 at 9:23 PM
    #1289
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    Makes sense. I was told by Steig that he’s done blowers like this before and I believe someone on here with a 4.0l has had it done. But no telling how he did it.
    EDIT: mentioned inlet only.
    I’m still not convinced porting on a M62 makes more power anyway.
  10. Dec 2, 2019 at 9:24 PM
    #1290
    eon_blue
    Azusa, CA
    150k on the supercharger is a good run but yeah, it sounds like it's time for rebuild
  11. Dec 2, 2019 at 11:00 PM
    #1291
    1997tacomav6
    Denver
    Inlet only probably not, the grey supercharger has lots of potential if running a smaller pulley to open up the air way porting the 3 sections and is not that expensive, I think is was 350.00 for me
  12. Dec 3, 2019 at 10:07 AM
    #1292
    CHMM
    CHMM [OP] GTO
    Gabe
    150k Miles is good.
  13. Dec 3, 2019 at 10:10 AM
    #1293
    eon_blue
    Azusa, CA
    TRD used to say a rebuild was due around 90k - 100k but I think that's a pretty conservative estimate, if you're on the stock pulley and keep up with maintenance you can probably go quite a bit longer than that.
    CHMM[QUOTED][OP] likes this.
  14. Dec 3, 2019 at 10:18 AM
    #1294
    1997tacomav6
    Denver
    Typically the nose bearing goes out 1st, I had one rebuilt that was up to 175,000 or so.
    With the smaller pulley spinning faster for me 2” it needs it sooner each time, no big deal.
    I can take the supercharger off in 30 minutes or less and install it in a few hours or so
    CHMM[OP] and eon_blue[QUOTED] like this.
  15. Dec 3, 2019 at 2:28 PM
    #1295
    CHMM
    CHMM [OP] GTO
    Gabe
    Well I just drove a 2018 1794 Tundra. And it was ok. It’s a friend’s truck. It was on E so I filled it up. $75 for 87. And that’s why I’m not a fan. I’ll stick to my $38 and 91.
    MatthewMay1 likes this.
  16. Dec 3, 2019 at 2:44 PM
    #1296
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    To fill my main tank and my 2nd tank from empty is usually around 32 gallons...that'll get me about 480 highway miles at 15mpg or 320 off road miles at 10mpg. In CA right now that's around $115. I usually have to do it in 2 fills because the pump hits the card max.
    I'm so glad my truck isn't my daily driver. Between my truck, daily #1 and daily #2 I still average about 30mpg.
    Edit...I forgot my point. I don't really care about the truck's mgps. I care about it's range in that regard. So if the super charger uses more fuel it's not the end of the world. I'll just have less range for remote off road excursions.
    cruiserguy and JasonLee like this.
  17. Dec 3, 2019 at 2:49 PM
    #1297
    eon_blue
    Azusa, CA
    Costs me $60 to fill up my 04 with 91 out here :boom:
    opteron likes this.
  18. Dec 3, 2019 at 4:19 PM
    #1298
    1997tacomav6
    Denver
    Headers came in today for the supercharger it'll be interesting to see how much horsepower gain there actually is, I will definitely find out once they're up and running
  19. Dec 3, 2019 at 4:49 PM
    #1299
    CHMM
    CHMM [OP] GTO
    Gabe
    I gotta hear em 100%.
  20. Dec 3, 2019 at 4:52 PM
    #1300
    CHMM
    CHMM [OP] GTO
    Gabe
    I hear ya man. I don’t care about gas mileage one bit. It’s worth it. On an N/A engine, I do though. There’s a certain point where I get pissed. $75 for a tank of naturally aspirated Boring Miles will do it.
    1997tacomav6 and otis24[QUOTED] like this.
