3.4L supercharger
Discussion in '1st Gen. Tacomas (1995-2004)' started by CHMM, Sep 14, 2019.
  1. Sep 19, 2019 at 6:45 PM
    #121
    CHMM
    CHMM [OP] GTO
    Gabe
    Castle Rock, Colorado
    2001 TRD Xtra Cab 4x4 Supercharged
    5100s SPC UCAs Energy bushings #70 spring clutch mod Supercharged
    Have you guys seen Blue Devil engine cool? Reduces coolant temp 25 degrees. Is that any good?
  2. Sep 19, 2019 at 7:05 PM
    #122
    1997tacomav6
    Denver
    Advance auto parts has a 170 thermostat for 15.00 is what I put in.
    04yota[QUOTED] and CHMM[OP] like this.
  3. Sep 19, 2019 at 7:13 PM
    #123
    CHMM
    CHMM [OP] GTO
    Gabe
    I’ll pick one up.
  4. Sep 19, 2019 at 7:13 PM
    #124
    1997tacomav6
    Denver
    I’ve heard of some other products similar but they do not work with antifreeze.
    Not sure about this product
    04yota likes this.
  5. Sep 19, 2019 at 7:14 PM
    #125
    CHMM
    CHMM [OP] GTO
    Gabe
    I was reading on altitude and supercharger a. Is it true that every thousand feet is a loss of 0.5 psi of boost. So at 6k feet your lose 3?
  6. Sep 19, 2019 at 7:15 PM
    #126
    eon_blue
    Azusa, CA
    Yep, air gets thinner the higher you go which makes it harder to produce boost. Less power in general for any engine the higher elevation you are. On the plus side though, you're less likely to run lean at higher elevation and the air is generally cooler which helps overall
    c0climber and 1997tacomav6 like this.
  7. Sep 19, 2019 at 7:17 PM
    #127
    1997tacomav6
    Denver
    Yup, close to that, the stock pulley puts out 4 pounds in Denver
    yup, that’s why we need a smaller pulley here in Denver to get more boost.
    The 2.2 pulley is a safe pulley to use here in Denver with out mods and should get you 6-7 pounds of boost
    c0climber and CHMM[QUOTED][OP] like this.
  8. Sep 19, 2019 at 7:17 PM
    #128
    eon_blue
    Azusa, CA
    I would be wary of adding anything to the coolant, a lot of times stuff like that will gunk up your radiator and cooling system long term.
  9. Sep 19, 2019 at 7:19 PM
    #129
    Rldanie
    Rldanie Punisher78
    Colorado
    2002 Supercharged, 2” pulley, FIC, Methanol, Transgo Shift Kit
    Engine Performance upgrades: Supercharged (Magnuson) FIC/6 Champion Radiator Toyota Corolla thermostat 168° JBA Headers JBA cat back exhaust Upgraded fuel pump Volant Cold Air Intake With custom plexiglass cover TransGo Transmission A340F Valve Body upgrade B&M Transmission cooler Methanol Injection 2 inch pulley Future Plans Supra Injectors Light weight crankshaft pulley Leather seats Off-road upgrades 3” rough country lift 33x12.5” Dick Cepeks Other upgrades: JL Audio 12W6 Sub in custom box JL Audio C5 Mids and tweets all the way around Sound dampened whole cab Transmission temp sensor Gen Tex rear view mirror (temp and compass) Blue instrument panel, a/c control panel lights, shifter, ashtray, glove box. Blacked out badges Blackout bumpers and grill MariMoto Projectors with demon eyes LED Taillights Second generation leather steering wheel with audio controls Custom leather wrapped automatic transmission shifter 3rd gen 4 Runner key ring light (blue) 3rd gen 4 Runner hood scoop
    I bought one too
    Not installed yet
  10. Sep 20, 2019 at 12:50 PM
    #130
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    Ok, so here's my current plan then:
    Phase 1:
    Supercharger kit with stock pulley
    Gates belt
    1 step cooler spark plugs (Denso 5310 IK22 Iridium Power Plug)
    AFR (Innovate PSB-1) to start learning how the truck behaves before further upgrades/additional boost
    Phase 2:
    Auto trans shift kit
    Headers
    Cat-back exhaust
    Maybe new cat if it got messed up from previous owner burning coolant through it for unknown mileage - need to figure out how to test, passed strict CARB emissions, so unlikely to be bad.
    Phase 3:
    Gates belt
    Meth
    Phase 4:
    Smaller pulley
    1997tacomav6[QUOTED] likes this.
  11. Sep 20, 2019 at 1:10 PM
    #131
    CHMM
    CHMM [OP] GTO
    Gabe
    Just talked to a buddy that had a 6 pound S/C and always read 4 PSI on his gauge in Denver.
    John, would 4 PSI be a nice boost in power relatively speaking?
  12. Sep 20, 2019 at 1:13 PM
    #132
    eon_blue
    Azusa, CA
    Sounds like a good reason to start out with a smaller pulley to me :evil:
  13. Sep 20, 2019 at 1:22 PM
    #133
    CHMM
    CHMM [OP] GTO
    Gabe
    LOL. It does. But I like to go step by step. It’s how I roll. I wanna see how it is fully stock. It’s my daily driver.
    eon_blue[QUOTED] likes this.
  14. Sep 20, 2019 at 1:26 PM
    #134
    CHMM
    CHMM [OP] GTO
    Gabe
    If I don't notice any power gain with 4 PSI, we’ll go smaller. But my buddy said 4 PSI was good/noticeable. I’ll report back.
  15. Sep 20, 2019 at 1:28 PM
    #135
    eon_blue
    Azusa, CA
    It will definitely be noticeable, there are some low boost supercharger kits that LCEngineering sells for other Toyota engines that only put up 4psi. It's a modest number but it will definitely add some pep to a stock engine.
    CHMM[QUOTED][OP] likes this.
  16. Sep 20, 2019 at 1:31 PM
    #136
    CHMM
    CHMM [OP] GTO
    Gabe
    That’s all I need. I just want it to be kinda like my 1990 5.0 Mustang. Torque and power at the low RPMS. Handles like crap but goes fast in a straight line.
    otis24 likes this.
  17. Sep 20, 2019 at 1:33 PM
    #137
    eon_blue
    Azusa, CA
    Just beware that boost is a rabbit hole in it's own right...might feel satisfied with it at first but soon it'll be 'normal' and you're going to want more lol. It's fun though my wallet hates me
  18. Sep 20, 2019 at 2:18 PM
    #138
    1997tacomav6
    Denver
    X2
    Rldanie likes this.
  19. Sep 20, 2019 at 2:19 PM
    #139
    Rldanie
    Rldanie Punisher78
    Colorado
    I’m pretty much doing the same thing
    Beware-The headers are a pain
    I’ll let you know how the TransGo upgrade goes
    I plan on taking pics.
    Don’t forget a Transmission cooler!
    opteron and 1997tacomav6 like this.
  20. Sep 20, 2019 at 2:20 PM
    #140
    1997tacomav6
    Denver
    Stock pulley you can start with and you will feel the extra power.
    Then get a 2.2 if you want. As you probably will be ok with no ping or just a little.
    That should get you to 6 pounds
