3.4L supercharger
Discussion in '1st Gen. Tacomas (1995-2004)' started by CHMM, Sep 14, 2019.
  1. Jan 7, 2020 at 9:09 AM
    #1621
    CHMM
    CHMM [OP] GTO
    Gabe
    Castle Rock, Colorado
    2001 TRD Xtra Cab 4x4 Supercharged
    5100s SPC UCAs Energy bushings #70 spring clutch mod Supercharged
    I called them to trouble shoot. They had me disconnect the Map sensor hose. But nothing changed. They are shipping me a new boost sensor.
  2. Jan 9, 2020 at 3:54 PM
    #1622
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
    My package arrived today full of seals for the top end of the engine. Getting closer to having everything I need for this instal!
    otis24 likes this.
  3. Jan 9, 2020 at 6:07 PM
    #1623
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    I sent my super charger off to The High Speed Lab for a full rebuild. I bought it used last year. The rotors are cooked so it’s getting a new set along with a getting the bore recoated, full rebuild and a new bypass valve and whatever else they find.
    CHMM[OP] and 1997tacomav6 like this.
  4. Jan 11, 2020 at 6:52 AM
    #1624
    otis24
    Mark
    California
    Will do. Thanks!
  5. Jan 11, 2020 at 5:18 PM
    #1625
    jruiz555
    jruiz555 Well-Known Member
    Need a bit of info, im up in big bear right now 7k elevation and boost wont go past 1 psi. 2 months ago in would get about 9 to 10 psi at sea level and recent before i hit the climb i was getting about 6psi max but not consistent. I have about 60k on the motor, and 5 k on the new SC.
    I am using a scan tool OBDll to read psi boost from the ecu.
    Specs. Running URD 7th injector, 2.2 pulley, methanol injection.
  6. Jan 11, 2020 at 5:24 PM
    #1626
    eon_blue
    Azusa, CA
    Do you feel like the boost has actually stopped building? Or is it just the scanner saying there's a problem?
    Reason I ask is because if I try reading boost via my scanner it rarely gives me a reliable reading. The boost gauge is always accurate because it's connected to the boost port on the supercharger.
    Do have a boost gauge hooked up? I don't really know if the ECU is capable of reading the supercharger boost stove it's not connected to the supercharger in any way...I could be wrong though
  7. Jan 11, 2020 at 5:28 PM
    #1627
    jruiz555
    So it still pulls a bit, but i am wondering why before i would get a good 9 to 10 from the scanner tool. I removed my last boost gauge because it wasnt accurate but i might need to plug one back in. I read that these motors dont have a map sensor but it uses the MAF sensor with an algorithm to calculate vacuum/ boost can someone confirm?. Always at high elevations i get little to no psi reading on a scan tool
  8. Jan 11, 2020 at 5:35 PM
    #1628
    eon_blue
    Azusa, CA
    Well it's definitely normal to lose a certain amount of boost per every couple thousand feet of altitude you gain...but this is definitely beyond the normal amount in your case. I go up to Big Bear often and never notice more than a couple lbs lost
    I would try hooking up a boost gauge to confirm, maybe pick up a cheap one somewhere for testing purposes since your other one might be no good.
  9. Jan 11, 2020 at 6:21 PM
    #1629
    Milor
    Milor Well-Known Member
    shaun
    03 Tacoma sr5 .TrD offroad 5spd..
    supercharged 2" pulley 6 puck clutch
    I was losing boost almost just like you said. It was due to a bad bank 1 02 sensor .. and it was hard to figure out because I wasn't gettin a check engine light at all. sensor was working barely in spec not to throw a light but completly messing up fueling and timing
  10. Jan 11, 2020 at 6:53 PM
    #1630
    jruiz555
    Sounds good i will be getting one soon
  11. Jan 11, 2020 at 7:10 PM
    #1631
    1997tacomav6
    Denver
    Yea, just get an inexpensive vacuum boost gauge to see what’s going on and connect it to the supercharger.
    That will tell you everything.
    Going from 5000 feet to 8000 feet in the mountains I loose 1 pound of boost and going to 10,000 feet I can loose 2 pounds of boost.
    If your feeling a power drop you will know your actually loosing boost
    eon_blue likes this.
  12. Jan 11, 2020 at 8:04 PM
    #1632
    1997tacomav6
    Denver
    If you have a vacuum leak in the boost gauge or hose or a vacuum that connects to the supercharger YOU WILL loose boost BTW,
  13. Jan 12, 2020 at 7:54 AM
    #1633
    jruiz555
    I have a leak tester at home i will discconect the port and see if it holds a pressure
  14. Jan 12, 2020 at 9:37 AM
    #1634
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    Boost via a scanner is the most inaccurate way to measure. It’s just a estimation through OBD2. You need something measuring vacuum from the manifold.
    mechanicjon likes this.
  15. Jan 12, 2020 at 10:45 AM
    #1635
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Can confirm. Our trucks don't have any way to measure boost or vacuum. There's no map sensor. The computer uses an algorithm to (guess) determine the readings. Not accurate at all.
    1997tacomav6 likes this.
  16. Jan 13, 2020 at 12:23 PM
    #1636
    CHMM
    CHMM [OP] GTO
    Gabe
    You called it. It was the sensor. Innovate sent me a new one. I installed it. We are good to go.
  17. Jan 13, 2020 at 12:23 PM
    #1637
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
  18. Jan 13, 2020 at 9:12 PM
    #1638
    mechanicjon
    Jon
    Scottsdale Arizona
    Lurker.... whatcha doing?
    Dalandser[QUOTED] likes this.
  19. Jan 13, 2020 at 10:25 PM
    #1639
    eon_blue
    Azusa, CA
    He done got himself boosted
  20. Jan 14, 2020 at 7:35 AM
    #1640
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Paying attention to FIC 6 info - found this image on the T4R site.
    gamefreakgc-albums-engine-performance+mo_538b564e9d255aa68a6f9a89d7600fe26b09eae4.jpg
    Might try to find a spare harness to use if I can get one for cheap. Just running the stock pulley and pump but my sc came with a snow meth kit I'll install over time. How's your boost pursuit?
