3.4l Timing Belt
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacomaEli, Nov 18, 2019.
  1. Nov 18, 2019 at 8:58 AM
    TacomaEli
    TacomaEli [OP] Well-Known Member
    Eli
    Roanoke, Virginia
    2000 Tacoma XtraCab SR5 TRD 3.4L Auto
    Planning on getting my timing belt and water pump done soon. Wondering what else I should replace while I'm getting that done. Seals/Gaskets? Tensioners?
    GQ7227 likes this.
  2. Nov 18, 2019 at 9:21 AM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Hey, this is a great job to do. Whether you're doing it yourself, or having a shop do it, here's a post that outlines all the parts you'll need, as well as a step-by-step guide on the work itself.
    If you're just after the list of parts, then you'll want...to pick up:
    1. Most of the parts you need in a kit on eBay. There are several of them, but I went for the 100% OEM parts kit from aircabinman.
    2. The crank pulley bolt, which Toyota says is a single-use bolt given the 217 ft-lbs of torque it's under while in service. (90119-16006)
    3. Two gallons of red coolant concentrate, to refill the radiator when it's reinstalled. (00272-1LLAC)
    4. Six gallons of distilled water - again, for the radiator.
  3. Nov 18, 2019 at 9:33 AM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    Picture above is complete.
    Also been mentioned by others to do the idlers for accessory belts and the fan bearing as yours is now 20 yrs. old. and it's had a couple pounds hanging on it that long.
    OneWheelPeel likes this.
  4. Nov 18, 2019 at 9:37 AM
    Taco critter
    Taco critter #mall crawler , patw and ,ttc#0247
    Douglassville /oley, pa
    02 tacoma 4x4 full mall crawler
    Ome 3inch ,rims ,cold air intake ,,4 crawler body lift ,cb in ashtray mod,leds, jet maf,Satoshi grille,led roof bar,yakama roof basket ,smittybilt parts,spare tire mount in hitch ,rago fabrication parts, winch bumper ,winch ,285s on wagon wheels ,traction boards ,hi lift jack,wet oaklies,smittybilt ,bamf bedrack,loads more,TOO MUCH SHIT TO LIST
    Good luck,been working on the wifes 4r 3.4 since friday ,cant get that dam timing belt on
  5. Nov 18, 2019 at 9:42 AM
    OneWheelPeel
    OneWheelPeel Well-Known Member
    +1 to the above and
    Tensioner bearing - Press out the old and insert the new.
    there are some small water hoses off the water pump jacket as well that I'd recommend changing if in bad shape.
    Heres the bearing ive had for 3 years now:
    https://www.amazon.com/gp/product/B002BBGFJQ/ref=as_li_tl?ie=UTF8
  6. Nov 18, 2019 at 9:48 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    I found that once you get the marks lined up, get a small spring clamp to hold the belt's teeth in place while you do the other pulleys.
  7. Nov 18, 2019 at 11:54 AM
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    Partsgeek sells a complete Aisin kit with everything you need, water pump, belt, idler pulleys, etc. When I had mine done, I had the mechanic throw all the old parts in a box for me. They were the exact same parts that come on the truck from toyota. Same names stamped on the bearings, with same part numbers.
  8. Nov 18, 2019 at 1:11 PM
    Actionjackson
    Actionjackson Well-Known Member
    Jack
    MA
    2004 Tacoma
    How about new oil cooler coolant hoses. I changed mine at the timing belt service. Your right there any way.
  9. Nov 18, 2019 at 3:08 PM
    04tacoma trd
    04tacoma trd Well-Known Member
    +1 to the above. I recently did the 'full monty' to mine. Oil cooler hoses, radiator hoses, idlers, everything that came off that moves was replaced. A few months before that I did the valve cover gasket replacement - same deal, replaced everything - spark plugs, spark plug wires, etc. etc. Finally - watch the Timmy the Toyotaman videos and just slowly go through the steps.
    Dalandser likes this.
