3.4L TRD Supercharger rebuild
Discussion in '1st Gen. Tacomas (1995-2004)' started by SupraT, Mar 10, 2013.
  1. Jul 14, 2016 at 8:10 AM
    #361
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    How much boost are you seeing?
  2. Jul 14, 2016 at 3:03 PM
    #362
    1997tacomav6
    Denver
    Wow, that's no good, When I shipped mine, I bought a thick mattress foam pad and wrapped the charger 3 times around and taped it up for safe shipping with peanuts around that and double boxed it.
    Did you replace the fuel filter?
    I'm in Denver, so I'm a mile high, so the 2.1 pulley puts out 8 to 9 pounds on my pillar guage.
    If I was at sea level I guess it would be more?
    Just curious, what number does the 2.1 and 2.2 put out boost wise at sea level??
  3. Jul 14, 2016 at 3:05 PM
    #363
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    2.2 at sea level is about 7-8
  4. Jul 14, 2016 at 3:11 PM
    #364
    anthony250f
    Anthony
    San Diego, CA
    2.1 I saw 9 and 2.2 I have 8
    I did replace the fuel filter.
    I used so much packing paper and tape and double box and everything
  5. Jul 14, 2016 at 3:38 PM
    #365
    1997tacomav6
    Denver
    Ouch, you can't use packing paper, the paper will not protect the charger at all, paper just compacts.
    With the weight of the charger there is no cushion effect.make sure you use layers of foam or a hard foam and last option would be a ton of thick bubble wrap and wrap it like 4 or 5 timesand use double wall boxes
  6. Jul 14, 2016 at 3:39 PM
    #366
    TMFF
    TMFF Well-Known Member
    Tim
    Thornton, CO
    01/02 DCLB
    Stuff and junk and things...
    I see 9-10 here in Denver and at 12,000 it's only about 6 psi, with a 2.1. The last time I was at 2500' on a cool day I saw 11 psi.
  7. Jul 14, 2016 at 3:40 PM
    #367
    TashcomerTexas
    A little late for that, don't you think?
  8. Jul 14, 2016 at 4:24 PM
    #368
    anthony250f
    Anthony
    San Diego, CA
    Didn't mean paper. It was the big green air bubble wrap that ups sells. Tons of it. Literally wrapped the charger
  9. Jul 18, 2016 at 9:12 PM
    #369
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    lol what? no you do not use any bubble wrap for heavy items. you need to use dense foam or expanding foam. bubble wrap is for light things only.
  10. Jul 18, 2016 at 9:21 PM
    #370
    anthony250f
    Anthony
    San Diego, CA
    Too late for that hahaha. The shop is pushing ups to pay for the repair and powdercoat
  11. Jul 18, 2016 at 9:27 PM
    #371
    paranoid56
    San Diego
    14 double cab taco
    i know, but i hate seeing misinformation out there lol
  12. Jul 19, 2016 at 3:08 PM
    #372
    elnip
    elnip Well-Known Member
    LC,NM
    '98 Tacoma TRD S/C'd / /'16 T4R Trail
    Taco SC'd, fuel mods, Supra TT MAF, TRD Headers, Water Meth Injection, Tundra Brake upgrade Trail w/URD EL Headers. JFR EL Y-pipe, URD Hi Clearance cat back, KDMAX Tune, 4.56's
    Very interesting.....I'm using the Supra injectors that are probably the old style 4 hole, been in there for years so that is a total guess.
    I went to the Denso site you linked and searched for '04 injectors but nothing came up.
    Would you have a part # for the ones you are running? Any specs?
    tx_shooter likes this.
  13. Jul 19, 2016 at 3:24 PM
    #373
    anthony250f
    Anthony
    San Diego, CA
    I have heard from a few people that the 04 injectors WILL NOT work on older trucks. But it worked fine for me!
  14. Jul 19, 2016 at 3:26 PM
    #374
    elnip
    LC,NM
    Hmmm, don't see why they would not work.... do you have a part #?
  15. Jul 19, 2016 at 3:41 PM
    #375
    eon_blue
    Azusa, CA
    Question for you guys since we're talking about the best way(s) to get optimum performance out of the 3.4l supercharger....
    I assume you all are running better than stock spark plugs? At the time I got mine replaced, I wasn't aware that I should be running a colder set and I'm fairly certain that the dealer just put the regular copper ones in.
    I was told on another thread here that the Denso 5304 Iridium plugs are the way to go, I ordered them last week...just waiting on a good time to get them installed. I'm getting what I think is some pretty gnarly spark knock at times presumably due to copper plugs, anyone running these Densos?
    https://www.amazon.com/gp/product/B000M6UR82/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
  16. Jul 19, 2016 at 4:03 PM
    #376
    anthony250f
    Anthony
    San Diego, CA
    Ate those two step colder? I have ik24s
  17. Jul 19, 2016 at 4:19 PM
    #377
    eon_blue
    Azusa, CA
    I'm not sure, I did read that they are the ones recommended by Toyota for TRD s/c 3.4l motors. I'm excited to get them put in and see if it helps with better performance and getting rid of some pinging
  18. Jul 19, 2016 at 4:45 PM
    #378
    anthony250f
    Anthony
    San Diego, CA
    Do you have the 7th injector?
    Ik20=1 step colder
    Ik22=2 step colder
    Ik24=3 steps
  19. Jul 19, 2016 at 4:50 PM
    #379
    eon_blue
    Azusa, CA
    Nope, not yet. It's on the never-ending long list of things I need/want :sadviolin:
    I know that's probably the primary source of the pinging I'm getting, but I've read that spark knock sounds almost identical to pinging (pre-detonation) so I'm hoping the better spark plugs will at least help with it some.
  20. Jul 19, 2016 at 5:11 PM
    #380
    anthony250f
    Anthony
    San Diego, CA
    Worth a try. Stock pulley though right??
    eon_blue[QUOTED] likes this.
