3.4L TRD Supercharger rebuild
Discussion in '1st Gen. Tacomas (1995-2004)' started by SupraT, Mar 10, 2013.
  1. Jun 19, 2017 at 8:31 AM
    #441
    rctoy
    rctoy It's about to get real!!!
    konstantenos
    Pocatello Idaho
    First gen 4door monster in progress
    TRD super charger, URD fuel mods and 2.1 super grip pully, Headers, 2.5" glass pack, Dana 60 front 4 linked, 14bolt rears on chev 63's, 5.38 gears, ARB locker in the front, PSC full hydraulic steering, 18" SAW 2.5" triple rate coils overs, FOA 2.5 air bumps, B&M launch controls, B&M trans cooler, 4 alpine 6X8 type R's amped, Red led rock lights, CBI front and rear bumpers (my design) CBI sliders, 4 riggid dualys front 2 in the rear, custom track bar, ARB snorkle, warn VR8000 winch, Viair 480c twin compressers..
    anyone ever loose a few #'s of boost. I don't drive my crawler much but last time i got in it and poured the coals to it and noticed it was pushing a few #'s less than it normally does. still runs like a raped ape though.
  2. Jun 19, 2017 at 9:23 AM
    #442
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    How much are you seeing now?
  3. Jun 19, 2017 at 9:34 AM
    #443
    rctoy
    konstantenos
    Pocatello Idaho
    around 7 max but i used to run 9 at my elevation 4,400 feet.
  4. Jun 19, 2017 at 1:50 PM
    #444
    1997tacomav6
    Denver
    Can be a number of things, pulley slipping, pulley worn, measure the inside diameter, bad or worn belt,
    vacuum leak, a bad By-Pass Actuator, Intake gasket leaking under supercharger
  5. Jun 19, 2017 at 1:52 PM
    #445
    eon_blue
    Azusa, CA
    Could it also be the weather? I've heard that if you live where it get's really hot (Southern CA or the desert, for instance), it'll affect the performance of the blower. The s/c likes cold air. Don't know if that would account for a "few" psi of boost but might be part of it.
  6. Jun 19, 2017 at 1:54 PM
    #446
    1997tacomav6
    Denver
    Yup methanol injection kit will lower supercharger temps by 100 degrees, each boost pound adds 10 degress, 10 pounds can add 90 degrees
    eon_blue[QUOTED] likes this.
  7. Jun 19, 2017 at 1:56 PM
    #447
    eon_blue
    Azusa, CA
    Anyone in here with the URD 7th injector kit ever see a P0420 'Catalyst system efficiency below threshold' code pop up before? Got my 7th installed a month ago and last weekend that code popped up on me. First thought was that I'm probably running too rich now but I don't have an AFR gauge yet to confirm, have one on order though. Just curious if anyone else has had this happen
  8. Jun 19, 2017 at 2:18 PM
    #448
    TashcomerTexas
    Nope. A vacuum leak but not that.
    Would it happen to do with your truck being from cali?
  9. Jun 19, 2017 at 2:31 PM
    #449
    eon_blue
    Azusa, CA
    I don't think so, I've read that it's a pretty common code across the board but none of the accounts I've read of it happening to have been supercharged. In most N/A cases it's usually because a catalytic converter has gone bad, but they've been high mileage trucks (I'm only at 50k). I think I went from running super lean before adding the 7th injector to running super rich now that I have it on, and it's throwing off the AF/O2 sensor readings. Not really sure how I'm going to combat that though. URD makes an O2 sim that's really popular but that will definitely screw me on the smog test in CA (if the 7th injector doesn't do that already lol). Might have to look into calibrating the 7th.
  10. Jun 19, 2017 at 2:57 PM
    #450
    rctoy
    konstantenos
    Pocatello Idaho
    I had wondered if it was a belt problem so I changed it but it made no difference.
  11. Jun 19, 2017 at 3:25 PM
    #451
    TashcomerTexas
    Oh so it's not even tuned. Well there you go.
  12. Jun 19, 2017 at 3:30 PM
    #452
    eon_blue
    Azusa, CA
    I naively believed URD's claim that the "pre-loaded start up program is good for 99% of the trucks out there and almost never needs any additional tuning by the end user"...time to look into tuning it
  13. Jun 19, 2017 at 3:38 PM
    #453
    1997tacomav6
    Denver
  14. Jun 19, 2017 at 3:41 PM
    #454
    TashcomerTexas
    Definitely. Every truck with its supporting mods is going to be different, whether your truck is full on expo equipped with performance mods or 100% stock.
    I had mine tuned along with its install and absolutely no issues.
  15. Jun 19, 2017 at 3:58 PM
    #455
    eon_blue
    Azusa, CA
    Pardon my ignorance on the subject but how'd you'd go about tuning yours? I haven't done any research in how to tune it yet but I'll look into it.
  16. Jun 20, 2017 at 5:26 AM
    #456
    elnip
    elnip Well-Known Member
    LC,NM
    '98 Tacoma TRD S/C'd / /'16 T4R Trail
    Taco SC'd, fuel mods, Supra TT MAF, TRD Headers, Water Meth Injection, Tundra Brake upgrade Trail w/URD EL Headers. JFR EL Y-pipe, URD Hi Clearance cat back, KDMAX Tune, 4.56's
    You can't tune it without a Wideband to know where you are at for each change.
  17. Jun 20, 2017 at 9:09 AM
    #457
    TashcomerTexas
    Right, this ^ there's an old style DVI port iirc that you connect to.
  18. Jun 20, 2017 at 9:48 AM
    #458
    eon_blue
    Azusa, CA
    Got it, have one on order. Thanks guys.
    I reset the code again last night and after 60 miles of driving it's stayed off (when I reset it on the trail it came back on almost immediately). Looking like I need to tune this thing. Once I get my AFR gauge put on I'll tackle the tune.
  19. Jun 28, 2017 at 9:48 PM
    #459
    jsway9
    jsway9 Ninja
    Monterey CA
    2000 Toyota Tacoma 4x4 TRD SR5
    Front Relentless Bumper Rear Outdoor Logical Swing Out Front King Coilovers Rear Fox Shocks All Pro Expo. Leaf Springs
    Hey guys. Just bought a rebuilt S/C.
    My truck has 240k miles. Everything runs well. Should i just install it or should i consider rebuilding the engine? Also plan on running it with thr stock pulley and no 7th injector for a while.
  20. Jun 28, 2017 at 9:54 PM
    #460
    eon_blue
    Azusa, CA
    Use the money you were considering doing an engine rebuild with and get the URD 7th injector kit. Rebuilt motor or not, if you're one of the many with a 3.4l that runs lean with the s/c you're going to regret not having it.
    jsway9[QUOTED] likes this.
