3.4L TRD Supercharger rebuild
Discussion in '1st Gen. Tacomas (1995-2004)' started by SupraT, Mar 10, 2013.
  1. Oct 30, 2019 at 4:26 PM
    #821
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    dont think so. I spun it by hand. Seemed to roll just fine. I’m wondering if it something to do with the bypass valve or the restrictor jet in the hose.
    It’s odd that it will only make a noise coming off of boost intermittently.
  2. Oct 30, 2019 at 4:47 PM
    #822
    1997tacomav6
    Denver
    Remove the restrictor jet and see what happens then.
    Bypass valve have a leak that’s making noise in the diaphragm ?
    EGR backing plate leaking and causing a sound there?
    Definitely sounds odd
  3. Oct 31, 2019 at 4:07 PM
    #823
    Shortman5
    Supercharged TRD
    Well. It’s a strong possibility it’s the rotor pack. I was under the hood and gave it a good rev and it made the noise pretty loud. But only once. Any rev after that sounded like it has since installing new. maybe the rotors are slipping out of spec sometimes and contacting.
    Pulling the rotor pack out this weekend to inspect.
    1997tacomav6 likes this.
  4. Nov 1, 2019 at 2:09 PM
    #824
    waikoloataco
    waikoloataco Well-Known Member
    $$$$$ANYBODY GOT A 2GEN BLACK 3.4 TRD SUPERCHARGER THEY MIGHT BE SELLING??
    GAUGES, URD COMPONENTS IS A PLUS
    NEED ONE ASAP. LET ME KNOW IM IN SOCAL $$$$
  5. Nov 9, 2019 at 8:04 AM
    #825
    jruiz555
    jruiz555 Well-Known Member
    what do you do about the flaking coating on the rotors them self? do you remove it all together or send it out to get re coated?
  6. Nov 9, 2019 at 8:49 AM
    #826
    1997tacomav6
    Denver
    Send them out to be recoated, the coating creates a better seal and heat protection.
  7. Nov 12, 2019 at 7:20 PM
    #827
    Shortman5
    Supercharged TRD
    Anybody that had used a hammer and socket how much force does it take to tap the bearings out?
    I’m wondering how stupid it would be to tap them out with the housing installed.
    If anyone has used a bearing puller how much grief did they give you?
    Also, speaking with HighSpeedLab they mentioned that the needle bearings are recessed a bit to a spec. Did anyone follow this?
    EDIT: Sorry Wrong SupraT(TT)
  8. Nov 13, 2019 at 6:44 AM
    #828
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    No worries, not the first time that has happened :) lol.
    My PoS is supercharged too, but it's a 2.7 - I can't help much there regarding the 3.4
  9. May 9, 2020 at 7:21 AM
    #829
    Timmah!
    Timmah! Well-Known Member
    TIM
  10. May 13, 2020 at 9:52 AM
    #830
    TacoBike
    TacoBike The Researcher
    Mason
    Shingle Springs, California
    2000 3.4 Ext Cab TRD 4x4 with original SC
    ARP head studs Supercharger FIC6 AFR gauge painted fenders audio install
    When reinstalling the rotors, do you have to time them and shim them to spec? If so, how does one do that? (this is for a 2nd gen sc that was pulled apart when it was perfectly fine and bearings were untouched)
  11. Jun 24, 2020 at 8:27 AM
    #831
    1997tacomav6
    Denver
    I have the grey unit too,
    How did you end up removing the needle bearings?
    Press or blind puller?
    How did you install the needle bearings?
    Do you press the needle bearings until flush in the back or?
    Or freeze method?
  12. Jun 28, 2020 at 10:36 AM
    #832
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    I pressed them out with my shop press and pressed the new ones in flush
    1997tacomav6[QUOTED] likes this.
  13. Jul 11, 2020 at 5:53 AM
    #833
    98tacoma3rz
    98tacoma3rz Well-Known Member
    lancaster, pa
    2002 Double Cab Trd
    Does anyone know where I can find this bolt? Or what the specs of it are? Bought a used SC and is missing. Thanks
  14. Jul 11, 2020 at 10:29 AM
    #834
    eon_blue
    Azusa, CA
    Try calling Magnuson they might sell it separately or tell you where to find it
  15. Jul 11, 2020 at 1:38 PM
    #835
    BlackPearl
    BlackPearl Well-Known Member
    Alex
    Toyota Tacoma TRD
    3” lift. Sway a ways 2.5 on 285 75 16 and much more
  16. Jul 11, 2020 at 1:59 PM
    #836
    1997tacomav6
    Denver
  17. Jul 13, 2020 at 1:57 AM
    #837
    98tacoma3rz
    lancaster, pa
    2002 Double Cab Trd
  18. Jul 18, 2020 at 12:52 PM
    #838
    98tacoma3rz
    lancaster, pa
    2002 Double Cab Trd
    So I’m guessing this is not good. What would cause the coating to peel off? Just from use? Can this be rebuilt? Cost? Thanks!!C3CCBAFE-ACFA-4913-AF91-33E653C6BFEB.jpgC3CCBAFE-ACFA-4913-AF91-33E653C6BFEB.jpg9B71D5C1-688A-4FE6-83FB-8EA4144DCE40.jpg C3CCBAFE-ACFA-4913-AF91-33E653C6BFEB.jpg 9B71D5C1-688A-4FE6-83FB-8EA4144DCE40.jpg
  19. Jul 18, 2020 at 12:59 PM
    #839
    1997tacomav6
    Denver
    That’s the thermal heat coacting that is applied to the rotors.
    It’s extra protection from heat and also helps seal in the rotor gap to the side wall.
    The coating just wears from time.
    You can have the rotors recoated maybe 200 or so depending
  20. Jul 18, 2020 at 1:09 PM
    #840
    98tacoma3rz
    lancaster, pa
    2002 Double Cab Trd
    Would it run crappy like this? Bought this used and previous owner said it ran great. Also anyone you’d recommend? High speed labs? Thanks
