3.5L V6 or 4.0 V6 more reliable?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jamesmanee, Feb 1, 2023.
  1. Feb 1, 2023 at 8:16 AM
    jamesmanee
    jamesmanee [OP] New Member
    James
    2010 Tacoma Base Standard Cab 4 Cylinder 2.7L
    Hi Im currently in a second gen 2010 standard cab. Wanting to upgrade to a 2015 2nd gen v6 or a 2016+ 3rd gen v6. Would you say the 4.0 v6 is the more reliable motor?
  2. Feb 1, 2023 at 8:18 AM
    Horseshoez
    Horseshoez Well-Known Member
    Dale
    Maryland
    Probably a valid question, however, my prediction is this thread will turn into an almost instant dumpster fire.
    The above said, my son's 4.0 had the timing chain jump a tooth after about 170,000 miles and the fix ain't cheap as you need to pull the motor to get at the chain.
  3. Feb 1, 2023 at 8:19 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Today is as good as any for a holy war. :laughing:
    nikonNUT, 6MTPro, The Burbs and 62 others like this.
  4. Feb 1, 2023 at 8:20 AM
    Pwakchop
    Pwakchop Well-Known Member
    Nate
    Georgia
    2021 Cement DCSB TRD Sport
    Whole lotta' momentum
    Watched.
    50Buck likes this.
  5. Feb 1, 2023 at 8:20 AM
    Tacospike
    Two Trucks
    4.0 has been out longer, so? If reliable is meaning more time of testing.
  6. Feb 1, 2023 at 8:21 AM
    jackn7
    jackn7 Old Man Tan Taco
    Art
    So Cal
    2008 DCLB 4x4
    Just some stuff...
    Posted in the 3rd gen section. This should be good!
    GilbertOz, Kolter45, woods_24 and 5 others like this.
  7. Feb 1, 2023 at 8:24 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    welcome!
    annnndddd, here we go
    FIGHT!
    gsubioguy, alwaysHI, jackn7 and 3 others like this.
  8. Feb 1, 2023 at 8:25 AM
    Tacospike
    Two Trucks
  9. Feb 1, 2023 at 8:28 AM
    2GRFKS
    2GRFKS 2nd gen Tacoma is the worst gen
    The 3.5 was originally designed for small rv generators. The 4.0 has often been used as an Auxiliary Power Unit on the Airbus A380.
    Judging from that, I would say the 4.0 is more reliable.
    source : 2nd gen forum
    neverstuck, Irons, Kolter45 and 24 others like this.
  10. Feb 1, 2023 at 8:28 AM
    wj3v
    wj3v Active Member
    2022 TRD Sport
    I have put over 200,00 miles on my 3.5 camry with no issues.
    JDKred and Junkhead like this.
  11. Feb 1, 2023 at 8:29 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Bypassing your question entirely, the 4.0 drivetrain is more of a "truck" drivetrain. More down low torque. The 3.5 is more of a minivan or crossover drivetrain with an extra overdrive gear. Need to rev it out more to get up in the power. Doesnt mean one is worse than the other, just something to consider.
    Also, look into the P11EE issues. In the grand scheme of things, not that many being reported but still more and more have been popping up on here lately
    https://www.tacomaworld.com/threads...-failed-leak-down-test-only-16k-miles.773172/
    https://www.tacomaworld.com/threads/2gr-fks-engine-problem-failure.774579/
    JDKred likes this.
  12. Feb 1, 2023 at 8:29 AM
    maxmk8
    maxmk8 Well-Known Member
    2022 Electric Lime M/T Taco
    Both will work flawlessly until about 150-200k miles. Then it’s going to be a crapshoot. The 3.5 being a little more complex will likely to lose out. However maintenance is key. Some Toyota enthusiasts here don’t change the oil until the warranty is done
    Irons likes this.
  13. Feb 1, 2023 at 8:30 AM
    22Coma6MT
    22Coma6MT Well-Known Member
    2022 TRD Sport AC 6MT
    if the two engines were options for the current gen tacoma, i suspect most would choose the 4.0.
    the same could be said for the tundra. if the past and current engines were options, most would choose the 5.7 V8 rather than the turbo V6. heck, most would choose the prior gen tundra over the current gen.
    rmepilot, Auzea, StuckinOhio and 6 others like this.
  14. Feb 1, 2023 at 8:31 AM
    tonestar
    tonestar Well-Known Member
    Anthony
    NY
    2015 Taco 4x4 V6
    The 3.5s never had “years to avoid” the 4.0s had head gasket issues early on.
    3.5 will win long term
    Gfenza89, Yotalicious, VanGo3 and 2 others like this.
  15. Feb 1, 2023 at 8:32 AM
    SR-71A
    Zack
    Southern Maine
    wut....? What kind of small RV needs almost two hundred of kilowatts or power?
  16. Feb 1, 2023 at 8:34 AM
    maxmk8
    16-17s have way more front timing cover + coolant cross over leaks
  17. Feb 1, 2023 at 8:35 AM
    Tacospike
    Two Trucks
    Find a Tundra / Lexus 4.6L V8.
  18. Feb 1, 2023 at 8:37 AM
    Tacoma Rant
    Tacoma Rant I can’t be good all the time.
    Wisconsin
    2023 Tacoma TRD Sport Electric lime
    I thought the 3.5 came out of the Lexus suv line. I only have 210 miles on mine but it’s smooth as silk.
  19. Feb 1, 2023 at 8:43 AM
    Sierrahunter
    Sierrahunter Well-Known Member
    2022 SR5 Double Cab Long Bed 4x4
    I really enjoyed my 4.0. Had it for 17 years and put 270k miles on it. But I replaced the head gasket at around 220k. That was expensive. It never ran quite the same after that. I now have the 3.5, and I like it as well. The thing I don’t like about the third generation is all the sensors and electronics. It feels like I’m less connected to the road if that makes sense.
    Not an issue with the engine, but because of all the electronics, the 3rd generation trucks are touchy. For example, the truck will shut down when there is a short in the tail light. People have trouble with simple mods causing problems. And I’m tired of the truck flashing the big red “BRAKE!” warning when driving windy mountain roads. But these are issues with all newer vehicles, not just the Tacoma.
    GilbertOz, VanGo3 and 1776Taco like this.
  20. Feb 1, 2023 at 8:43 AM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    Maintenance, abuse, and climate will play a much bigger part than craftsmanship reliability at time of manufacture. You are looking at used engines with unknown maintenance schedules and driving habits. ALMOST any engine is reliable if it is properly maintained and not abused.
    Deeohji, GilbertOz, usmc2msu and 7 others like this.
