3 inch lift and 31s?
Discussion in '1st Gen. Tacomas (1995-2004)' started by DaytonLax14, Aug 14, 2010.
  1. Nov 13, 2012 at 10:38 AM
    #81
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    No. Your choices are Type A which is 4.5" BS or Type B which is 4" BS
  2. Nov 13, 2012 at 10:41 AM
    #82
    husty
    husty D's Yota
    North Dakota
    95 tacoma 31.10.5s stock15 rims
    Just 31x10.50s on factory rims, just installed a 3 inch lift. Going to put fender flares on and 33x10.50s with black steelies soon
    did u have an 8 inch on at anytime and if so did they rub.
  3. Nov 13, 2012 at 10:43 AM
    #83
    husty
    husty D's Yota
    North Dakota
    so mayb i should go with 33x10.50 then i think they won't rub.
  4. Nov 13, 2012 at 10:45 AM
    #84
    Blackdawg
    Monte
    Wyoming/St. Louis
    You will have less issues with a 10.5" wide tire yes.
  5. Nov 13, 2012 at 10:53 AM
    #85
    husty
    husty D's Yota
    North Dakota
    Hey thanks for that info and no i don't go offroading much just lifted the truck for more cleaence for snow here in north dakota. might do some mudding sometime in the near future tho. Bfgs ats a good tire to go with you think.
  6. Nov 13, 2012 at 10:58 AM
    #86
    Blackdawg
    Monte
    Wyoming/St. Louis
    Can't go wrong with BFGs. Best tire makers out there IMPO
  7. Nov 13, 2012 at 11:03 AM
    #87
    husty
    husty D's Yota
    North Dakota
    thanks man, hey do u know of anyone that wood have a set of 4 fender flares to sell or get rid of. just putting a feeler out there.
  8. Nov 13, 2012 at 11:08 AM
    #88
    Madjik_Man
    Colorado Front Range
    Can't be. Heavier tires, more friction, etc... really?
    And forgive my hesitance in believing someone who rejoices at 12 mpg.
    :p
    That's what I'm hoping. Truthfully I usually get 100 mile per 1/4 hashmark, and right now I'm just slightly above the half tank mark and I have 150 miles on the tripometer.
    That's pretty drastic even for winter gas blend... although checking fuelly.com I was getting about 19 - 20 mpg during this time last year.
    I'm a bit nervous that the weight of the sliders is fucking with my gas mileage but the first full fill up and tank I ran with the sliders on, I got the usually 22.8 mpg. So I don't know. All I do know is it's freaking my OCD out :(
  9. Nov 13, 2012 at 11:09 AM
    #89
    Madjik_Man
    The BFG 33 x 10.5s would be awesome for your needs IMO
  10. Nov 13, 2012 at 11:10 AM
    #90
    Madjik_Man
  11. Nov 13, 2012 at 11:24 AM
    #91
    husty
    husty D's Yota
    North Dakota
  12. Nov 13, 2012 at 11:24 AM
    #92
    Blackdawg
    Monte
    Wyoming/St. Louis
    I actually think I have my old ones still somewhere..maybe
    Lol 150 at half is amazing for me haha I have never seen 100 at 1/4.
    But yes they would be some change but not much. 1-2mpg I bet.
    I doubt the solder are effecting it that much. Only 150lbs max..
  13. Nov 13, 2012 at 11:40 AM
    #93
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Check out the Warden A/T retreads from Treadwright:
    https://www.treadwright.com/p-9-31-10-50r15-warden-a-t.aspx
    Very similar tread patern, you can pick your own tire carcus (you can choose BFG AT), and its only $94 per tire + shipping and mount/ballance.
    If you wait, looks like there may be a GB: http://www.tacomaworld.com/forum/group-buys/239873-treadwright-gb.html
  14. Nov 13, 2012 at 6:05 PM
    #94
    husty
    husty D's Yota
    North Dakota
    hey blackdawg u think u could check to c if u have the fender flares,let me no and if u want to sell them figure out a price with shipping and if its not to pricey i'll take them off your hands.
  15. Nov 13, 2012 at 6:08 PM
    #95
    husty
    husty D's Yota
    North Dakota
    i also tried a rim/tire 33x12,50 -15 from a friend it fit but it was tight.rubbed alittle bit at turn without no weight in the truck. I think if u have a little weight in the cab they'll rub for sure.
  16. Nov 13, 2012 at 8:10 PM
    #96
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea ill see if. Still have them.
  17. Nov 14, 2012 at 10:46 AM
    #97
    ARkansasTAco521
    ARkansasTAco521 Well-Known Member
    Nick
    North West Arkansas
    98 tacoma Reg Cab
    Pro Comp 3in lift, steel wheels, Bushwacker fender flares, in progress
    31 with 3in lift
  18. Nov 14, 2012 at 11:52 AM
    #98
    Ice Horse
    Ice Horse Stalking horse
    Lauren
    Florida
    Two 1998’s and a 2025. All TRD Offroads.
    ADS Racing Shocks 2.5" Extended Travel Coilovers with Reservoirs, 3 inch All Pro rear suspension kit, factory E-locker, Trail Gear sliders and front stinger bumper, CBI Offroad rear tube bumper, XRC8 Winch, 33 inch BFG KM2's, 16 inch Ivan Stewart Wheels, Uniden CB radio, flip up license plate, white tail lights, LED front signals, Tundra front brake upgrade, new radio, rock lights, sub woofer, remote start, satoshi grille with Prius emblem, Rigid DOT/SAE Fog Lights, 12" Light Bar
    I can't remember so hopefully the others have helped you with answering that. Mine will rub the frame slightly at a full turn. And for some odd reason every now and then my truck somehow gets into a funky position when offroading and will rub the lower bolt head that's closest to the cab on my drivers side rear fender. It did rip off a mudflap one time but mostly it's just fooking up my bolt and making my fender flare look funky. Only does it on the one side though for some reason. Easy solution? Just take the flare off. But I don't want to. I just need to find a low profile bolt.
    I should throw in that the front wheels are 16 inch TRD Ivan Stewart's...which most of you should know anyway...if not...SHAME! :D
  19. Nov 17, 2012 at 8:11 PM
    #99
    willie64
    willie64 Willie64
    willie64
    BEND OR
    (slowly becoming less than) Stock '03 3.4L 4x4 TRD SR5
    144 watt led lights on front 36 watts x2 led on the back, cb, Kenwood ham, icon 3" lift, 285/75/16 Fierce Attitude tires, JoeZilla sliders, 4x innovation rear bumper, ARB front bumper. Snorkel. On the workbench: more stuff I can't afford.
    recently did the toytec ultimate 3" lift w/ 2" AAL. Put on 285/75/16 tires. Wheels have 4.5" BS and a little rubbing on the frame @ full lock and on the UCA's. I bought 1.5" spacers to solve Px, may be a little too much on the spacers..... still haven't put them on (soon). Looking forward to a little trim:D! Haven't had the opportunity to fully flex everything out yet to see what all needs to be 'adjusted'.
  20. Nov 17, 2012 at 10:36 PM
    #100
    hillbilly taco
    hillbilly taco Well-Known Member
    tommy
    WEST VIRGINA
    09 standard cab 4x4
    3 INCH LIFT 285/75/16 TIRES CUSTOM GRAPHICS ROLL BAR
    X2 Check em out.They are a very good high quality tire Getum once and youll be sold on them for good.I love my guardogs from Tredwright.
