3 inch lift
Discussion in '3rd Gen. Tacomas (2016-2023)' started by be_fishin, Sep 11, 2017.
  1. Sep 11, 2017 at 1:59 AM
    be_fishin
    be_fishin [OP] Member
    Kalvin
    2017 gray Tacoma trd off-road
    None
    what's the best 3 inch lift can I get for a reasonable price? I don't want my lift to effect the smoothness of my ride and shock absorbtion.
  2. Sep 11, 2017 at 2:51 AM
    Halena Molokai
    Halena Molokai Well-Known Member
    Black 2016 TRD DCSB OR 4x4 MT6
    BFG KO2 265/70/17 Moto Metal 17x 9 -12mm ToyTec Boss 2.0 lift Kit Wet Okole, Ceramic tint 35% Bakflip F1 Flowmaster Exhaust Single in /Dual out with 3"stainless tips DashMat Covercraft Custom windshield shade Tilt Alarm Weatherbeater Mats Diode Dynamic LED upgrade to interior OEM Bed Mat OEM 5" Chrome Side Steps
    I would stick with a 2" lift and then add a tire size that will give you another inch for a total of three. If you want to keep the ride as close to stock I have no complaints with the Boss 2.0. on mines. $.02
  3. Sep 11, 2017 at 3:06 AM
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    what happens with 3" or above that a 2" will prevent?
  4. Sep 11, 2017 at 3:10 AM
    wirenut
    wirenut I like this place
    Andrew
    NH
    98’ T4R
    OME/5100 - 300lb 3.5” loft setup Prinsu 3/4 rack
    Theres probably 75 to 100 threads on this if you use the search option.
    rlx02, Mully, Rayien and 2 others like this.
  5. Sep 11, 2017 at 3:49 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Geometry happens.
    Hank Heel and swordfish like this.
  6. Sep 11, 2017 at 3:50 AM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    Charlotte (Cornelius) NC
    2020 Ford F'in Ranger
  7. Sep 11, 2017 at 4:43 AM
    BlkTaco47
    BlkTaco47 Unhinged
    so the issues many see with bearings, etc are less likely
    to be an issue with under 3"?
  8. Sep 11, 2017 at 4:59 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Staying as close to stock height is best as this will give you the most reliability and durability of all driveline components.
  9. Sep 11, 2017 at 5:00 AM
    7r41lbr34k3r
    7r41lbr34k3r Practitioner of the mechanical arts.
    Houston, TX
    '21 Tundra 1794 OR
    In theory, yes. Keeping the drive line angles closest to where they were designed to run will help with longevity sake. I don't think there's actual data out there to support it, though.
  10. Sep 11, 2017 at 8:27 AM
    alf
    alf Well-Known Member
    Alf
    Houston
    TRD OR 4x4
    Ome kit/ 888/ Dakar’s medium and 265/75s you’ll be good. Nice and comfy.
    Hobbs likes this.
  11. Sep 11, 2017 at 8:33 AM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    What? Seriously??
    JoeCOVA and ManBeast like this.
  12. Sep 11, 2017 at 8:44 AM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    It's definitely made up, not like we have a suspension subforum or anything helpful like that,
    Hobbs[QUOTED] and Hank Heel like this.
  13. Sep 11, 2017 at 8:46 AM
    Hobbs
    Yep…
    Why on earth would we even have a suspension sub-forum? or a search function?? :confused::facepalm:
    JoeCOVA[QUOTED] likes this.
  14. Sep 11, 2017 at 8:52 AM
    JoeCOVA
    Joe
    Colorado Springs
    Ya what do people think this is, the internet?
    Hobbs[QUOTED] likes this.
  15. Sep 11, 2017 at 8:53 AM
    Hobbs
    Yep…
    That's funny!
  16. Sep 11, 2017 at 9:01 AM
    Hobbs
    Yep…
  17. Sep 11, 2017 at 9:02 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
  18. Sep 11, 2017 at 9:02 AM
    DrFunker
    DrFunker Well-Known Member
    LIFTMAN! :cheers:
  19. Sep 11, 2017 at 9:15 AM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    99’ Bro-Coma’s Revenge 3RZ 345k+
    Stock
    Welcome to TW.
    Best cheap option is some Bilstien 5100's till you research on here and find out what you really want. Tons of info on here to help you out, just use the search button.
    Doggman likes this.
  20. Sep 11, 2017 at 9:59 AM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    Welcome to TW. I say lift it 3+ inches, cut, trim, BFH on pinch seams, re-gear, lockers, run 37s, plates, skids, sidebars, and hit the Hammers. Good luck.
    mikestaco17 likes this.
