3 inch Toy Tech Lift AND rear spring TSB????
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TOYOTA 09, Mar 7, 2011.
  1. Mar 7, 2011 at 4:29 AM
    TOYOTA 09
    TOYOTA 09 [OP] Kicking Ass Since 1981
    Maine
    2009 SR5 MT 4x4 Access Cab
    Preview 2009 SR5 4x4 MT Black Sand Pearl (Access Cab) SUSPENSION ToyTec 5100 Billstein Coil Overs (3" Lift) Fox 2.0 Remote Res Rear Shocks Total Chaos UCAs Full Dakar Leaf Pack w/Extra AAL TIRES & WHEELS BFG AT KOs 265/75/16 load range E American Rancing AR-23 Wheels Borla CAT back exhaust AFE cold air intake w/custom TRD clear cover Satoshi grill w/Grill Craft insert Hella 500 behind grill lights Rigid Industries Backup lights Interior Custom LEDs and Bed Lights Backup Cam Anytime MOD Leather armrest and rear seat MOD Weathertech floor liners Custom rear gear/dog platform Cobra CB and Garmin GPS Bed Mat UWS low pro tool box with Custom LED lights Diff breather MOD Custom painted engine cover Wet Okole seat covers
    I currently have a stock 4x4 Access Cab with the rear spring TSB. Right now the back sits a little higher than the front. I want to step up into the cool kid group (new tires, wheels, and 3 inch lift) :). My question is how would (what would) i need to do to get my 3 inch toy tech lift set up right. Would I need to take off the rear spring tsb, and use the toytech AAL? and set the 5100's to 2.5? or should i not even get the full 3 in leaf kit, and just buy the pre-assembled coils with 5100's?
    After all my research i think the following statement are true...right?
    1.) if you have the rear TSB and want to level out the truck set your front 5100's to 1.75.
    2.)If you want closer to factory rake: set the 5100's to .85....am i right with this?
    Can i just install the 5100's up front, set them at 2.5 AND put the toytech AAL on WITH the rear spring tsb AAL? Has anyone done this?
    I guess my main question is: I will be using the toytech 3 inch lift kit to lift my truck, I have the rear TSB...what is the best way to bo about doing this.
    PS: I'm looking for as cose to 3'' of lift as possible without needing UCA's
    I know there are a lot of questions above, but would love for someone to help out.
    thanks guys!!!
  2. Mar 7, 2011 at 4:36 AM
    dgr540
    dgr540 I've got the FUNK
    Friendswood, TX
    2013 Wrangler Unlimited
    XDs Trail grappler 35x12.5x18 Winch 8K lbs Front bumper 4in Lift
    Toytec offers a 1.5" AAL that most use with their TSB leaf.
  3. Mar 7, 2011 at 4:42 AM
    TOYOTA 09
    Maine
    great! Thanks man! So what should i set the fronts at?
    And if anyone has this setup now...i'd love to hear feedback on how the ride is?
    ALSO..looks like ToyTec is running a sale on 3 inch lift kits w/radflow suspension:
    same price as the 5100 set up.....is one better than the other?
  4. Mar 7, 2011 at 10:13 AM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    lots of choices out there
  5. Mar 7, 2011 at 10:17 AM
    pudge151
    Sean
    Connecticut
    i think from my reaseach on lifts and toytech and OME you can do
    good - better - or best-
  6. Mar 8, 2011 at 4:35 AM
    TOYOTA 09
    Maine
    so you think the OME 3 inch kit is better than the ToyTec?
  7. Mar 8, 2011 at 4:58 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Up for debate... you'll get mixed reviews depending on who you ask.
  8. Mar 8, 2011 at 5:19 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    You need to measure the difference front vs. rear and go from there. It sounds like you really want a 3" lift so why not just get a good set of coilovers so you can set it to your liking whether you plan on going up to a 3" lift later or not. You may be happy with it set at 2.5 with your TSB.
  9. Mar 8, 2011 at 5:50 AM
    Dewman4
    Dewman4 Well-Known Member
    Andy
    Haymarket, VA
    2011 Tacoma TRD Sport
    black badges, aFe intake
    I am going to ask a stupid question here but what does TSB stand for?
  10. Mar 8, 2011 at 6:23 AM
    Burns
    Burns Excellent Member
    17 DCSB Off-Road
    Bilstein 5100's @ 2.0", Wheelers 1.5" AAL, 265/75/16 Firestone Destination AT2's
  11. Mar 8, 2011 at 7:16 AM
    KevLot17
    KevLot17 Well-Known Member
    Kevin
    Pennsylvania
    '10 Blacked Out TRD Sport
    Debadged, Toytec Ultimate Lift, Banks Monster Exhaust, AFE Pro Dry filter, Black Grillecraft grille, Flat Black background headlights, Red Blinkers and markers with alternating turn signal mod, Krypton Bulbs 6000K Headlights and Fogs, Fog Light anytime Mod, LED interior lights with map light mod, AVS Black Taillight Covers, Tinted Windows, WeatherTech Digital floor liners.
  12. Mar 8, 2011 at 7:20 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Yes. To add, Any lift 2.5" or higher, and your going to need aftermarket UCA's to get the alignment in check.
  13. Mar 8, 2011 at 4:52 PM
    TOYOTA 09
    Maine
    Okay, so YES i am looking to get as close to three inches as possible. Suggestions for UCA's?
  14. Mar 8, 2011 at 4:58 PM
    TOYOTA 09
    Maine
    Chris..why do you think it is better? am i correct in saying that the OME kits with the correct springs will be better than MAXING out the 5100's at 2.5?
  15. Mar 8, 2011 at 5:00 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The OME shocks are valved a little softer than the 5100's.
  16. Mar 8, 2011 at 5:25 PM
    BlueSteel
    BlueSteel Well-Known Member
    James
    The Woodlands, TX
    09 Magnetic Grey Doublecab TRD Sport Debadged
    Camburg 4" Spindles, Icon CB 2.5 adjustables front and rear, Total Chaos Upper/Lower CAs, Alcan 5" Rear Leafs, Timbren Bumpstops, 5" SS Brakelines, 295/70/18 Nitto Trail Grapplers on 18" KMC Monsters, Grill Craft Black Mesh Upper, Predator Running Boards, All Pro Rear Bumper and Hitch, Wet Okole Covers, Toyota Roof Rack, Limo Tint, TRD CAI, TRD Exhaust, Weathertech Mats, Redline Hood Struts, Red Top Odyssey battery, BDF Light Bar, Foglight anytime Mod, Lo Pro QT Truxedo Tonneau cover, Rocky Mount Bike Pegs.
    I have the Toytec Ultimate with a set of Light Racing UCA's and a 1.5" Toytec AAL w/TSB. I am about .5" higher in the rear..looks really good. I didn't adjust the CO's and just left them the way they came from Toytec. I am sitting around 2.75" higher and running 285/65/18's with some slight trimming (nothing major).
    I would go with a set of Light Racing because they are excellent quality and are around $450.00 without a discount.
    I am looking into some spindles right now because the 3" kit can ride a little rough.
  17. Mar 9, 2011 at 5:33 AM
    PAlittlematty
    PAlittlematty "the soulless ginger"
    Beech Creek, PA
    I miss my taco
    OME Lift, 885 Coils, 13MM Top Spacer, Dakar Leafs, DSM UCAs, Homeroshi Flush Mount Grille, WeatherTech Digifit Mats, Bestop Super Top, Toyota Bed Extender, Clevice Receiver 1990 SR5 3.slow SAS 5” Leafs, high pinion diff, 37” PBRs, MC rear, AP front bumpers, 5.29s, locked
    Ok so there's many threads about lifts n the endless possibilities of parts combos. Here's what I'm lookin at. I do moderate wheelin. Central PA has old logging roads that are washed and some rocky/rutted sections to crawl around on. I was looking at the OME nitros and 885s because I'm gonna get skids from ATO soon as my suspensions done. Correct me if I'm wrong, but ill need an 1.5" AAL in the rear to level it with the front. I'm gonna have skids and sliders so this is the reason for the 885s. Id like to run a 285/75/16s. Am I better off to use the OME setup or go with coilovers? I don't wanna hafta tear my shocks off periodically to have them rebuilt though.
  18. Mar 9, 2011 at 6:33 AM
    Burns
    17 DCSB Off-Road
    Toyota, technical same shit in this case. :rolleyes:
