3" King or 3" Fox suspension?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MoofTaco, Feb 12, 2017.
  1. Feb 13, 2017 at 4:40 AM
    TacoRD16
    TacoRD16 Well-Known Member
    Houston, TX
    2016 Tacoma TRD Off Road 4x4
    Fox 2.5 RR C/O Fox 2.0 RR Rear Dakar leaf Pack Headstong Brakeline Extension Bracket 16"Konig Countersteer wheels BFG's KO2 285/75r16 All-Pro UCA 1.25" All-Pro APEX Slidders Unided CB w/ Firestick II Lamin-X fog Lens 1" Diff Drop OME 1/2" CB Drip OME Mobtown 3/16" Skid plates: Front, Trans and Transfer case Relentless Hood Brackets AuxBeam Ditch Lights DBCustons Grill "Recolored" Matt Black Relentless High Lift Mount Softopper Diff Breather Mod Tail Gate Inserts HondoGarage Tablet Vent Mount Weather Tech Floor Liner
    All about the same performance. For the every day DD and once a month off roading I would go by 2 things: 1. Do a lot of studying with material of construction and combination of materials with corrosion (Cathodic Protection). 2. Give Maria @ HeadStrong Off-Road a call or PM to compare prices for the cheapest kit.
  2. Feb 13, 2017 at 4:43 AM
    BohlaaH
    BohlaaH Loading...
    ALEX
    Thunder Bay, Ontario
    2015 TRD Sport DCLB
    Rigid Industries Grille and 20' fitted LED bar 6" BDS Lift w/ FOX 2.5 (front) FOX 2.0 (rear) 35x12.5 TOYO M/T Open Country Tires Fuel Assault 18" Wheels OPT 7 LED 9003 Headlight Cut Cab Mount & Pinch Weld Trimmed Fender Flares 4.88 Yukon Gears ARB air locker Front & Rear Dent in Driver door... Relentless Fab CB antenna hood mounts Rigid Industries Dually "Amber" spot lights Adventure Offroad Fabrication Overhead Console OTTRAW Switch Mod
    Fox is better resistance against corrosion. That's why we run it up north. We have no choice but to go with fox if we don't want to replace seals every spring
  3. Feb 13, 2017 at 4:48 AM
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    Im a little biased being a mountain biker, but Fox from my experience is a bitch to deal with. They are slow to return stuff and arnt cheap. King, I have always been just a call away and are great with their components. All coilovers will rust with neglect, but if you search the here you will find some of the older fox threads that they used to rust out like crazy. I think one member even got FOX to send him a brand new set of coilovers because his rusted out in less than a year. I think Fox has made a new coating to hopefully fix this, but most places I have looked, fox seem to be the more expensive option?
    Im on my second set of kings with my LT front, and have no regrets!
    Coot
    0210 likes this.
  4. Feb 13, 2017 at 5:03 AM
    TacoRD16
    Houston, TX
    Same for the opposite reasoning lol. Live off the gulf coast so a lot of salt water for me. Still have to take precaution with cleaning afterwards but no rust yet with my Fox 2.5 set up.
    stevotivo12 and BohlaaH[QUOTED] like this.
  5. Feb 13, 2017 at 5:13 AM
    Brokinarrow
    Brokinarrow Well-Known Member
    Brian
    Garner, NC
    2017 Tacoma TRD Offroad
    Thangs and stuff
    i have a hard time trusting someone with a twilight picture.......
    Guerrilla likes this.
  6. Feb 13, 2017 at 5:42 AM
    desmodue
    desmodue Unsprung member
    2016 TRD OR AC
    Öhlins
  7. Feb 13, 2017 at 5:45 AM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    Pics? They got some nice stuff.
    Coot
  8. Feb 13, 2017 at 4:42 PM
    MeFryRice
    MeFryRice Well-Known Member
    Marietta, Ga
    '16 QS Tacoma DCOR4x4
    I literally tried everything to get the collars to turn. I applied WD-40 to the threads and used a cheater bar on the spanner wrench and it would not budge. We had to remove the front coilovers and use a spring compressor to release some of the tension for them adjust. I've installed and adjusted many coilover setups on my track cars and have never experienced something like it. I have since sold the FJ and the Fox suspension.
  9. Feb 13, 2017 at 5:20 PM
    Midknight
    Midknight Well-Known Member
    Western Canada
    2018 TRD Off-Road
    Wish I had the funds to have been in this "dilemma" lol
    Coot83 and whitedlite like this.
  10. Feb 13, 2017 at 6:15 PM
    TacoRD16
    Houston, TX
    You lifted the vehicle and release the clamping hex nut?
  11. Feb 13, 2017 at 7:12 PM
    MeFryRice
    Marietta, Ga
    Sure did. I even unbolted the sway bar to release any tension that may be caused. I know, this sounds crazy.
  12. Feb 13, 2017 at 7:14 PM
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Mine was a PITA too. Sprayed the hell out of it with lube..let it soak. Used the coilover wrench with a deadblow hammer, ended up spinning(not easy though)
  13. Feb 13, 2017 at 7:23 PM
    TacoRD16
    Houston, TX
    Wow never heard it being that difficult. I think I would have sold them if I couldnt adjust them on the vehicle.
  14. Feb 13, 2017 at 7:31 PM
    Guerrilla
    Guerrilla L(.)(.)K@G(.)(.)Dz
    D. Cooley
    Coast to Coast
    El' Black 13 DCSB 4x4
    Stuff
    :laughing:
  15. Feb 17, 2017 at 7:12 AM
    #35
    stevotivo12
    stevotivo12 Well-Known Member
    Stephen
    2016 Silver Tacoma TRD Sport MT
    Front hellwig sway bar,All pro sway bar end links, Fox 2.5 Resi Coilovers and Shocks, Fox 2.5 Hydraulic Bumpstops, Budbuilt Traction bar, Total Chaos UCAs w/ heim joints, Icon AAL, AFE Power Intake with dynamic scoop, URD spec U, URD short shifter, Flossy weighted shift knob, michelin tires, black badges, black tailgate letters, black grill with custom Diaz Fab Devil horn yota logo, retrofit/morimoto HID conversion, red interior LED lights, Pioneer head unit, kenwood excelon door speakers, 2 10" pioneer subs,
    If you like to drive your truck mainly on asphalt but want the capability to occasionally go offroad then get the fox suspension. I have it personally and am very happy with my purchase overall. Would buy again/recommend to friends. Fox gives better cornering and controls the weight of the truck better at speed, and King controls the truck better at low speed and keeps it nice and comfy offroad even over rough obstacles. Fox = Rally truck, King = Rock crawler truck, its your choice:burnrubber:
    TRKSMTH, MoofTaco[OP] and Brokinarrow like this.
