3" lift, 33s rubbing
Discussion in '1st Gen. Tacomas (1995-2004)' started by genuine, Jan 27, 2014.
  1. Jan 27, 2014 at 9:35 AM
    genuine
    genuine [OP] Active Member
    Calgary, Alberta, Canada
    Bilstein 5100, AAL, Deckplate Mod, Magnaflow Cat-Back
    Hey,
    I purchased a 3" lift from Toytech (http://toyteclifts.3dcartstores.com/Ultimate-Tacoma-lift-with-Bilstein-shocks_p_394.html) that came with the Bilstein 5100s, AALs, diff drop etc. I saw some posts saying that 33s would fit without rubbing but mine rubbed immediately.
    I purchased 33x11.5 and they rubbed when I was turning (on the control arm) so I purchased the 1.25" spidertrax and installed them. They don't rub on the arms while turning but still rubbed on the front bumper and back of the front tire (picture included). I trimmed the front bumper but it still rubs in the back when turning / hitting bump when turning.
    I was under the impression that they shouldn't rub. Is my only option to cut some of the back wheel well? When the Bilsteins 5100s came they were already adjusted, can they be raised anymore (should they)?
    Thanks!
  2. Jan 27, 2014 at 9:44 AM
    Lumpskie
    Lumpskie Independent Thinker
    New Hampshire
    '96, 4x4, v6, manual hub
    Toytec 16" coilovers with Tundra Bilstein 5100s, Light Racing UCAs, Alcan Leafs with Orbit Eyes, 12" Bilstein 7100 short Bodies, ARB rear locker, 33x12.5 Duratracs, CBI sliders, Bushwacker fender flares, self made front bumper, M8000, Vision X 6.7" Hi/Lo Beam HIDs, full skids, Inchworm dual case setup - 15º clocking
    It looks like the 1.25" spacer may be a little too much. You might be able to keep it from rubbing with a slightly narrower spacer, but fine tuning that kind of thing can be tricky... especially when your tire is stuffed. So, a little more information would be handy. What is the backspace on your wheel? Are you rubbing on level ground?
    Overall, it might just be easier to trim as necessary and call it a day.
  3. Jan 27, 2014 at 9:56 AM
    genuine
    Ah gothca, It's the standard taco wheels, so I'm not to sure the depth. There's no harm in cutting the back?
  4. Jan 27, 2014 at 1:26 PM
    Lumpskie
    New Hampshire
  5. Jan 27, 2014 at 5:05 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    under the impression you wouldn't have to trim...
    well...
    that is lies..haha
    just hammer and cut man.
  6. Jan 27, 2014 at 6:56 PM
    Cali 03 Taco
    Cali 03 Taco Member
    Dublin, California
    03 Tacoma DC SR5
    No mods yet that's why Im signing up to talk to yall to see what to order.
    Man that sucks I'm installing my lift this weekend and I'm going with 285-75-R16 Duratrac's too. I hope to have better luck or switch to 255-85s but I imagine I'll still need to trim
  7. Jan 27, 2014 at 6:58 PM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    QFT
  8. Jan 27, 2014 at 7:09 PM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    This is why i wish people would stop saying their 33s or 285s don't rub, and with the right setup you won't rub. Anyone running 285s can easily make their tires rub, even on the street. You can go with smaller spacers and mess with the alignment and go for more caster but the easiest thing to do is just start cutting.
  9. Jan 27, 2014 at 7:10 PM
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    My 285 KM2's don't rub. But I don't wheel the Tacoma, and make sure to tell people that.
  10. Jan 27, 2014 at 8:14 PM
    tomtom
    tomtom Well-Known Member
    The Desert SW
    2012 FJ
    BFH the pinch weld if you haven't already.
    Shouldn't have to touch the cab mounts.
  11. Jan 27, 2014 at 8:25 PM
    rumpot
    rumpot Member
    I have the same lift with 4.5" bs wheels and terra grapplers 285/75/16 and i rub different, mine rubs the frame but am going to try the spidertrax this weekend.
    Regards
    Eric
  12. Jan 28, 2014 at 3:51 AM
    JDMcQ
    I had to cut off the pinch weld,dramatically reshape the firewall, run .75" spacers and dial in as much positive camber as possible to roll the wheel forward a bit. Finally got it to stop rubbing.
    If I had it to do over again, I would gone with the 255/85/16 option. Fewer headaches.
  13. Jan 28, 2014 at 7:45 AM
    genuine
    ugh, that's not encouraging hah..
    Yah I decided on 33's as I saw on the forum that it wouldn't rub... It does only rub in the back, so if I adjust to gain positive caster I might be able to save the rubbing? I'll just trim regardless to be in the clear.
    Thanks!
  14. Jan 28, 2014 at 8:04 AM
    tomtom
    The Desert SW
    2012 FJ
    It took me 20 minutes to get 285/75r16s to fit. Trimmed the plastic and beat the piss out of the pinch weld at the rear of the wheel well.
  15. Jan 28, 2014 at 8:09 PM
    TacoTaro
    TacoTaro Well-Known Member
    Los Angeles
    04 DC 4x4
    King Coilovers, Light Racing UCA, OME Dakar leafs w/ extra leaf and SB10" Bilstein 7100's and a U-bolt flip. 4.56's, eLocker rear, ARB front, Marlin rear bumper, ARB Bull Bar w/ Warn M8000. BAMF Sliders. Manual hub conversion with functioning ABS. Tundra front brakes. Manual hub conversion with functioning ABS. SCS F-5's w/ 255/85 Toyo MT's
    This...
    OP, did you bash the pinch weld down yet?
  16. Jan 28, 2014 at 8:11 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
  17. Jan 28, 2014 at 10:14 PM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    alot still need done
    i just bought my tacoma last month and found out i have 5 inch spacers in the back. i been looking around for new leaf springs that'll not break the bank on me. i plan to get a new bumper and winch to replace the stock one. its a 2000 sr5 tacoma. i dont do much hauling except 200-250 pounds of horse food on a rare occasion. and i live on a dirt road.
  18. Jan 29, 2014 at 4:13 AM
    JDMcQ
  19. Jan 29, 2014 at 6:16 AM
    PcBuilder14
    Brent
    Nor Cal
    Yeah, I keep it on my bookmarks bar for threads like these. I've used it many times haha
  20. Jan 29, 2014 at 6:44 AM
    JDMcQ
    I used it when I went to the 33's on my Tacoma. It helped immensely, though I had to do way more trimming than the article mentioned.
    Al trucks are a little bit different, some require more work than others. I would imagine that the "33's and no trimming " trucks are in the minority.
