3" Lift after TSB.
Discussion in 'Suspension' started by mikenredding, Jan 26, 2008.
  1. Jan 26, 2008 at 2:38 AM
    mikenredding
    mikenredding [OP] Member
    2005 sr5 tacoma access cab 4x4
    Hi, I have a question. I'm getting the Toyota TSB done soon and then I plan on installing a 3"lift kit. My question is what size tires can I run with my stock rim which is 16" from my 2005 tacoma 4x4? I'm thinking of running 275/70/16 but am not sure how big of a tire that is in inches high.
    thanks
  2. Jan 26, 2008 at 6:14 AM
    surfponto
    surfponto Well-Known Member
    Bob
    Leucadia (Sunny San Diego)
    2007 Tacoma 4x4 SR5 2.7 ltr
    ATC Bobcat slide in camper 8 Dakar leaf springs in back
    What kind of lift are oyu going with? I just got the green light to lift our Tacoma also.:D
  3. Jan 26, 2008 at 1:38 PM
    mikenredding
    It's a Pro comp lift kit on ebay for about $169. The guy makes them for pro comp. It uses a 3inch aluminum spacer on the front and leaf springs on the back. The front spacer doesn't require a shock compressor to install.
  4. Jan 26, 2008 at 6:04 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    the leaf spring for the back will completely negate the springs that just got put on ur truck w/ the tsb
  5. Jan 27, 2008 at 12:28 AM
    mikenredding
    won't adding a lift kit leaf after the TSB just raise the rear end 1.5 to 2 inches?
  6. Jan 27, 2008 at 5:41 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Wow.... anybody have this lift?
    Does their knuckles come in contact with the coils?
    If I rememer correctly, having a spacer that big above your coil assembly causes your knuckles to be too close to the coils and possibly cause contact.
  7. Jan 27, 2008 at 8:28 AM
    mikenredding
    I was told, when I called and was asking if I needed a spring compressor and was told no by the manufacturer. I was also told that you still have to take the front spring assembly off and the 3" spacer bolts to the top plate of the spring and does'nt preload the spring like most other kits due thereby not having as stiff a ride in the front end. Now as far as binding with something I'm not sure as I have'nt installed the kit yet.. I am having the TSB done 1st so I don't run into any warranty issues like them not wanting to install the TSB cause of having a lift in.......
  8. Jan 27, 2008 at 6:44 PM
    The_Hodge
    SC
    everything i've seen online about lifting the rear after the tsb says to use blocks if u need any extra
