3" lift installed this weekend. Now Shutters Slightly
Discussion in 'Suspension' started by trailmaster308, Feb 2, 2009.
  1. Feb 4, 2009 at 6:33 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
  2. Feb 4, 2009 at 7:48 AM
    ComaTosin
    ComaTosin The Not So New guy
    Drew
    Atlanta, GA
    06 SR5 PreRunner
    see my sig
  3. Feb 4, 2009 at 8:01 AM
    Alaskaflyer
    Alaskaflyer My other ride Hovers
    Cape Cod, MA
    08 Prerunner DC TRD Off Road
    OME 885 AAL, 2.5* shim, Light Racing UCA's. BFG AT KO 285/75/16, Spidertrax spacers, OME Shocks up front, Bilstein 5100 Shocks in back.
    I'm thinkin 2" wide. I would measure the width of your leaf pack to be sure.
  4. Feb 4, 2009 at 9:23 AM
    trailmaster308
    trailmaster308 [OP] Well-Known Member
    Louisiana
    PreRunner 3" Toytec Adj Coilovers 2" AAL
    Well last night I ordered the carrier bearing drop kit from Toytec. After the install I will let everyone know if I see a difference. The shutter is not bad. Just a small shutter from around 10 - 20 mph. Once past that everything is fine.
  5. Feb 4, 2009 at 9:29 AM
    ComaTosin
    Drew
    Atlanta, GA
    06 SR5 PreRunner
    see my sig
    interested to know.....
  6. Feb 4, 2009 at 9:31 AM
    blackbetty28
    blackbetty28 Active Member
    missouri
    07' black double cab,TRD off-road
    3 inch daystar leveling kit, trail cutter r/t 33's
    i have the same problem
  7. Feb 4, 2009 at 12:03 PM
    Toytec Lifts
    Toytec Lifts Toyota Suspension specialist
    Rocky Mountains
    Toyota's are awesome
    No, No.
    Well sell a m, its just listed under the 1st gen tacomas.
    We have found that the 3 works well with the newer taco's.
    But both application fit.
  8. Feb 4, 2009 at 1:13 PM
    trailmaster308
    Louisiana
    Do the shims have a hole in them where the centering bolt goes? When doing my AAL's this weekend I noticed a hole in the axle where the centering bolt goes.
  9. Feb 4, 2009 at 1:22 PM
    Toytec Lifts
    Rocky Mountains
  10. Feb 4, 2009 at 8:32 PM
    billas333
    billas333 They Still Love To Hate Me! - T.O.
    Joel
    NorCal
    2008 4x4 Tacoma Sport
    Mods so far: Tube steps from toyota, Bed extender from toyota, Spare Tire lock, Sound System Makeover, Tacoma All-Weather heavy duty rubber floor mats. Rear TSB, Icon Coilovers w/ TC UCA's and 3inch rear block with rear 5100 bilstein shocks, Black Headlights, Grillcraft black grill, Devil Horns from Andres, Black Headlights, Chrome Liquid Metal Gatlins Wheels, 285/70R17 Nitto Tera Grapplers, Wet Okole Seat Covers! Seat Belt Chime Mod, Flowmaster 50 series dual exhaust, Debadged tailgate, TRD Decals, HID hi/low + fogs.
    Ok so I read through this thread and I am a victim of TDLV. (Taco driveline vibes) So anyways I have the rear TSB and a 1 inch block in the rear. I say this because from what I read is that the vibes are only coming from trucks with a rear lift. So ultimately what is the solution we have come up with to cure TDLV??
    just a shim under the block? or carrier bearing drop and shim?
  11. Feb 5, 2009 at 7:38 AM
    trailmaster308
    Louisiana
    I can't answer that, but I can tell you that I currently have no carrier bearing drop or shim. I ordered the CB drop and will install it this Sunday. If that doesn't work I will order the shims and install those.
    Will let you know what I find.
  12. Feb 5, 2009 at 12:22 PM
    josh3972000
    josh3972000 Well-Known Member
    kentucky
    02 dbl cab TRD
    Im no mechanic but I did have vibes until I installed degree shims, I have 2.5 lift in the front and no diff drop. the vibes I got came from the rear, and the shims cured this.
  13. Feb 5, 2009 at 2:25 PM
    trailmaster308
    Louisiana
    Would do that in a heartbeat no matter what the cost. However, I am an idiot and bought a pre-runner and its not a flang - flang. So I am SOL. :mad:
  14. Feb 5, 2009 at 2:52 PM
    Toytec Lifts
    Rocky Mountains
    this shim actually goes right under the leaf pack on the axle. It rotates the axle to help correct the angle of your drive line.
  15. Feb 5, 2009 at 5:22 PM
    #35
    billas333
    Joel
    NorCal
    Ok so i have a rear one inch block under my leaf pack so i would place the shim under the block right? what degree would i need i see toku had 4* shims before his fab tech lift
  16. Feb 5, 2009 at 5:25 PM
    #36
    Alaskaflyer
    Cape Cod, MA
    I plan on installing a 2* shim when I do mine. I hear that a 3* shim will work as well.
  17. Feb 5, 2009 at 6:24 PM
    #37
    trailmaster308
    Louisiana
    yes shim under block. not sure what degree u want.
  18. Feb 7, 2009 at 5:43 AM
    #38
    trailmaster308
    Louisiana
    Ok installed the carrier bearing last night. Couldn't wait on my buddy. And it only took 5 minutes.
    I can notice a small difference in the vibrations. They are better but not perfect. I am going to order the shims. It just feels that the vehicle is begging for the shims and all will be right :)
    The carrier bearing drop by itself did help though.
  19. Feb 8, 2009 at 11:19 AM
    #39
    Toytec Lifts
    Rocky Mountains
    We believe that the 3* works great for your vehicle.
    but we do sell the 2.5.
  20. Feb 16, 2009 at 8:29 PM
    #40
    billas333
    Joel
    NorCal
    Any word on your situation with the shims and CB drop?
