3" lift options??
Discussion in 'Suspension' started by adamw, Jan 31, 2011.
  1. Feb 2, 2011 at 9:23 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    maybe a 1/4" spacer for the drivers side to compensate the Taco Lean...I used one...
  2. Feb 3, 2011 at 1:25 PM
    Coloradomx24
    Coloradomx24 Well-Known Member
    Colorado
    2015 Dbl Cab L/B Sport
    I have a really stupid question :crapstorm: but give me a break...I'm a girl haha.
    I had a 3 inch revtec spacer lift installed just because my tires were rubbing and I was on a budget at the time. Now that I have saved up I was looking at a suspension lift.
    Looking at some trucks with 3 inch suspension lifts look taller than my truck. Is a 3 inch suspension lift taller then a 3 inch spacer lift?
    Thanks!!! :deadhorse:
  3. Feb 3, 2011 at 6:37 PM
    705 Taco
    705 Taco Zombie Killer!
    Dean
    Barrie ON / St. Petersburg FL
    2016 TRD OR AC
    --Stock 2016. --------------------------------------------------------------------------------------------- 2011 had 6 inch ProComp lift, Eibach coils on 5100 Bilsteins at zero, 1/4 inch Toytec spacer on drivers side, rear TSB, 1.5 inch Deaver AAL, ProComp blocks and rear shocks, 8000 lb Warn winch on a Trans4mer grill guard, 33 inch BFG AT's, 18x9 XD Monsters, PIAA headlights, PIAA driving lights, Pyro's blue LED gauges, LED strip below tailgate, Armor Lid hard tonno, Hidden Hitch, Dee Zee bed mat, Tint, XM, Garmin GPS, Ultra Gauge
    No 3 inches is 3 inches no matter how you get it. A spacer lift is technically a suspension lift. Suspension lifts usually have a new taller coil spring and strut or a coilover assembly (high quality adjustable shock and spring sold as a set). Spacers achieve lift just by making the factory strut longer.
  4. Feb 3, 2011 at 8:13 PM
    Coloradomx24
    Colorado
    Good to know. I still think I want the Toytec ultimate lift kit for a better ride then the revtec spacers. I would like to go taller than 3 inches but cant really afford the 6 inch. Would it be dumb to run a 3 inch toytec with a 1-2 inch body. I'll have avid sliders that will cover my frame up some from the body lift.
    Sorry Im clueless :)
  5. Feb 4, 2011 at 5:11 AM
    705 Taco
    Dean
    2016 TRD OR AC
    You can put a body lift with a suspension lift. Some guys on here have a 3 inch susp and 3 inch body. Maybe they can chime in on this. I personally don't like the look of a body lift but thats a personal thing. And you're not clueless.:)
  6. Feb 4, 2011 at 9:26 AM
    thegreatest
    thegreatest Well-Known Member
    J Money
    07 PreRunner Off-Road
    Got that 3" lift bwaaaaaa!
    @Colorado
    Are your spacers 2" or 3"? Did you do anything in the rear?
  7. Feb 4, 2011 at 10:34 AM
    705 Taco
    Dean
    2016 TRD OR AC
    2.25 inch spacer up front and 1 inch diff drop. Rear is stock.
  8. Feb 4, 2011 at 10:49 AM
    udy2554
    udy2554 NORTHERN RED-NECK
    Naples, NY
    '06 Tacoma TRD Sport
    Toytec ULK, Light Racing UCA's, OME Dakar rear leaves, ARB Bumper with XRC8 winch, Good Year Duratracs 285/70/17's on 17x9" Level 8 Strike 6's. Leer cap in the winter. Pioneer Double Din with BT, iPod, etc. Boston Acoustic components in all 4 doors with a Sony amp, powered 8" sub. Ultra gauge, Tom Tom...
    I am very happy with my Toytec ULK. The adjustability lets me allow for the bumper/winch weight. The ride is awesome. I also did the Light Racing UCA's for alignment reasons, and the booted ball joint, I'm in the salt belt! In the rear I went with the OME Dakar springs instead of an AAL for the extra cargo weight. Lots of wood hauling and camping gear.
    Before the bumper/winch:
    After:
    Good luck with your decisions!
  9. Feb 4, 2011 at 1:46 PM
    toyo freak
    toyo freak Another Toyota Enthusiast
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    5100s at 2.5, Wheeler 3 leaf progressive AAL, Weathertech liners, yellow wire mod, toyota OEM bed mat, cup holder mod, afe pro dry s air filter, UWS low pro toolbox, Escort radar detector
    NICE !! 285s?
  10. Feb 4, 2011 at 2:00 PM
    udy2554
    Naples, NY
    Yup, 285's.
  11. Feb 4, 2011 at 7:47 PM
    Calijavier81
    Calijavier81 Active Member
    Puyallup, Wa.
    2011 Tacoma DblCab TRD Sport 4x4
    Stock
    I am in the same situation, deciding what lift to get. I'm sold on a 3" lift, but not sure which way to go....Bilstein 5100s, ToyTec Ult., FabTech, etc. I really want to go with a coil over for an overall better ride. And though i am not looking to exceed 3", I am looking at purchasing UCAs too. My main concern is having enough clearance all around to accomodate a 285/65R18 Nitto Trail Grappler. Does anybody run this tire on a 3" lift? If so, what lift? Any necessary cutting? Please let me know, so i can make my purchases...thank you!
  12. Feb 5, 2011 at 4:22 AM
    udy2554
    Naples, NY
    I did have to trim a little offf the flare at the bottom. So far I haven't had to do the body mount mod. I still need to raise the front of the truck an inch or so, but so far no more rubbing! I just used tin shears on the flare and inner wheel well liner!
  13. Feb 8, 2011 at 10:56 AM
    Coloradomx24
    Colorado
    They are 3 inch revtec spacers in the front with a AAL in the rear to level it out
  14. Feb 9, 2011 at 6:07 PM
    thegreatest
    J Money
    nice. just purchased those 3 days ago:cool:
  15. Feb 9, 2011 at 6:23 PM
    #35
    malander
    malander That's some tight butthole
    max
    Missouri
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    Just a side note to anyone considering a lift... UCAs are not *needed* but they are highly recommended. I still wish I would have saved up for them before I put my lift on. Keep in mind that if you can't get you're alignment dialed in you may end up with weird tire wear. This may be important to you if you're going to throw on some massive new tires that cost $800....you wouldn't want those wearing funny
  16. Mar 2, 2011 at 5:43 PM
    #36
    Calijavier81
    Puyallup, Wa.
    Stock
    I just put mine in last weekend, and the 2.5 setting with the spacers is pushing more than 3"! So be careful in your decision, because you'll need UCA's with this set up. I'm going to take the 1/2" spacers out this weekend (leaving the .25 drivers side spacer in) in hopes to salvage my stock UCA's (at least for now). If i could go back, i would of adjusted them to 1.75...oh well, the eibach coil was STIFF and a pain in the ass to compress, so im leaving it at 2.5 for now. If you guys are thinking about the bilstein 5100s all around with the AAL kit, i recommend it, but i caution you to think about the 2.5 setting with spacers if you dont have new UCAs.
  17. Mar 7, 2011 at 1:43 PM
    #37
    Calijavier81
    Puyallup, Wa.
    Stock
    Heres what it looks like after 2 weeks (AALs settled in)...front adj to 2.5"
