3" lift out of eibachs & 5100s
Discussion in 'Suspension' started by TurfTaco, Sep 27, 2010.
  1. Sep 27, 2010 at 7:01 AM
    TurfTaco
    TurfTaco [OP] Is there a long john silvers on the island?
    URE
    07 Deer Collector
    285/75-16 BFG KM1's, AVS vent visors, AVS hood shield, pioneer avic F900BT, pac steering wheel control adapter, Boyo rearview camera, pac ipod interface, tinted windows, Toytec 1.5 AAL, Bistein 5100s (front set to .85) Eibach coils, Black headlights, grillcraft black billet insert, N-fab light bar, 4 Hella FF700 lights & color matched grille, Sockmonkey bedside decals. 16x8 MT sidebiters, Weathertechs, Fabtech spare carrier.
    For those curious about the eibach coils paired with 5100s, I just had them installed and set the 5100s to .85 with the 1/4" drivers side spacer and got a full 3" of lift over stock. I am still running the stock size 265/70 tire for now. I think I now have enough lift for 285s. Anyone else get 3" out of this lift? I assume a 4x4 would get a little less...
  2. Sep 27, 2010 at 7:07 AM
    huntark03
    huntark03 I'd rather be hunting!
    Maumelle, AR
    2005 Limited Tundra DC 4X4
    Spidertrax Wheel Spacers aFe Pro Dry Drop in Air Filter Weathertech Liners Bilstein 5100s w/ OME 885 coils and ToyTec 1.5" AALs Light Racing UCAs
    What do you have in the back...TSB spring w/ TSB 1.5 AAL??
  3. Sep 27, 2010 at 7:08 AM
    TurfTaco
    URE
    07 Deer Collector
    1.5 AAL Non TSB springs. I'll look at it and it looks level, then look again and it seems slightly lower in the back, but its pretty close. I may go to a 2" AAL later.
  4. Sep 27, 2010 at 7:10 AM
    huntark03
    Maumelle, AR
    Ok...I'm thinking this same setup but I have a 4X4 and the 4 leaf TSB spring. Thanks for the update man! :cool:
  5. Sep 27, 2010 at 7:18 AM
    huntark03
    Maumelle, AR
    How is the ride...any wandering or new noises?
  6. Sep 27, 2010 at 7:30 AM
    TurfTaco
    URE
    07 Deer Collector
    Had a noise, but turned out to be a bad tire balance. Fixed. Does not wander. aligned good. It is stiffer than before when I just had the 5100s set at 1.75 but nothing major. All is good.
  7. Sep 27, 2010 at 7:35 AM
    TurfTaco
    URE
    07 Deer Collector
  8. Sep 27, 2010 at 7:56 AM
    Fabulous
    Fabulous Well-Known Member
    Fabian
    Calgary, AB
    2017 Tacoma double-cab TRD Sport
    TRD Pro grill and fog lights, Toytec Boss lift, 265/70-17 Duratracs on 17 x 8.5 FN Verge wheels, LEER canopy, 30% tinted front windows.
    I guess it really does make a difference if you have a 2x4 as apposed to a 4x4. I have a d-cab short box 4x4 with the same set up, and got just over 2" out of it.
  9. Sep 27, 2010 at 8:05 AM
    huntark03
    Maumelle, AR
    Got any pics of yours?
  10. Sep 27, 2010 at 8:13 AM
    Fabulous
    Fabian
    Calgary, AB
    I will soon. I had some post lift problems with mine in the form of 3 out of 4 of my lower a-arm cam bolts being seized, so I couldn't get it aligned. Truck has been in the shop since Thursday getting fixed to the tune of $900. I should have it back soon, and will post picks for you.
  11. Sep 27, 2010 at 8:14 AM
    huntark03
    Maumelle, AR
    Dang...that sucks! Good luck man!!
  12. Sep 27, 2010 at 10:11 AM
    Cortland
    Cortland THIS IS AMERICA!!!
    Cortland
    Arizona
    Clifford aka Big Red
    Camburg 4" Spindles, 5100's All Around, All-Pro 1.5" Leaf Pack, All-Pro U-Bolt Flip Kit, Avid Sliders, AFE Pro Dry Filter, Wicked Flow 18" Muffler
    I am planning on raising my 5100's to .85" to get a little more lift out of my Eibach/5100 setup. Is it really stiff? The ride with the Eibachs on 5100's set at zero is amazing!
  13. Sep 27, 2010 at 11:29 AM
    Hipster
    Hipster Nothing beats a Butter Shave..
    Tom
    Tucson
    '10 DC trd 4x4
    Billy's @ .85 w/ Eibachs front, TSB w/ 5100's rear + 1.5" AAL & shims, Debadged, Avid Bolt On Sliders, NFab Light Bar w/ (2) Lightforce 170's. Weathertechs, ATO bed bars.
    The ride is much better than stock. As far as my lift, it started out as 3" but settled to a nice 2.5"ish. Eibachs, .85 billy w/ 1/4" plate on drivers and TSB. Took about a month or so to settle and that was 3 months ago.
  14. Sep 27, 2010 at 11:35 AM
    huntark03
    Maumelle, AR
    Is all you have in the rear is the TSB?? Pictures??? :D
  15. Sep 27, 2010 at 11:53 AM
    Tacomanator
    Tacomanator Boiling denim and bangin whores
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    ^ This ^
    you'll have less than 3" once everything has settled. you will still rub the cab mounts with 285's, unless you do a chop... but it sounds like a nice set up you have there :thumbsup:
  16. Sep 27, 2010 at 12:04 PM
    spearhead
    spearhead Taco Supremist
    Winston Salem NC
    09 4DR Mag Grey 4WD Sport
    TRD CAI Eibach Springs 5100s all around Front set to .85 Toytec AAL
    Nice setup - any issues with the driver side spacer fitting on the billy's shocks-did you need extended threads?
    I have this set up waiting to be put on, myself.
    What size tire do you think you'll ultimately run? I have 16"s TRD wheels..
  17. Sep 27, 2010 at 12:06 PM
    spearhead
    Winston Salem NC
    Ahh so 285's have too much meat-
    I wonder if having 16s vs 17s is a variable or if some Spidertrax would make a difference...?
  18. Sep 27, 2010 at 12:11 PM
    Fabulous
    Fabian
    Calgary, AB
    When I first put mine on it was at 3", but within a day or two it settled to just over 2"...like around 2 1/4" or so. Ride seemed really nice compared to the soft stock set up even though my alignment was way off. I find the ride very similar to my Wife's RAV4 Limited. Firm, but in no way stiff or jarring.
  19. Sep 27, 2010 at 12:17 PM
    huntark03
    Maumelle, AR
    Fab,
    Do you have the TSB and/or an AAL on your ride?? Personally, I don't like the bro look or too much rake. Still can't find a good picture of a truck with Eibach/5100 at .85 and TSB leaf pack w/ 1.5 AAL.
    Thanks man!!
  20. Sep 27, 2010 at 12:43 PM
    jr114
    jr114 Well-Known Member
    Jon
    SoCal
    Truck
    Icon Ext travel CO, Icon tubular uniball UCAs, Maxtrac Spindles, Icon RR rear w 2"aal.
    op can you post up #s from the ground to the center of the wheel well? and i dont think that you will have to chop the body mounts. im running the procomp 3" lift with 285/70/17s no rubbing. only alignment issues. i have the eibachs and billys in the garage and want to put them on when i order the camburg ball joint uca's. just wanna make sure ill get enough height out of the billy eibach
