3" lift out of eibachs & 5100s
Discussion in 'Suspension' started by TurfTaco, Sep 27, 2010.
  1. Sep 27, 2010 at 1:04 PM
    Fabulous
    Fabulous Well-Known Member
    Fabian
    Calgary, AB
    2017 Tacoma double-cab TRD Sport
    TRD Pro grill and fog lights, Toytec Boss lift, 265/70-17 Duratracs on 17 x 8.5 FN Verge wheels, LEER canopy, 30% tinted front windows.
    I didn't have the TSB done on my truck. I got a 2" Toytec AAL, and the 5100's all around with the Eibach spring at 0.85 on the front (plus 1/4" taco lean spacer on drivers side). I have 265/70-17 tires and pre install the front of my truck was at 35" measured through the hub. Back was at 37" through the hub. At the moment the front is at 37.25" and the rear is at 39.25" and it will hopefully settle a bit in the back when I tow my dirt bike and such. It sounds like I would have a lot of rake, but I think it looks good the way it is. You can tell there is rake, but it's not a lot.
  2. Sep 27, 2010 at 1:11 PM
    huntark03
    huntark03 I'd rather be hunting!
    Maumelle, AR
    2005 Limited Tundra DC 4X4
    Spidertrax Wheel Spacers aFe Pro Dry Drop in Air Filter Weathertech Liners Bilstein 5100s w/ OME 885 coils and ToyTec 1.5" AALs Light Racing UCAs
    Looks like I need to do some measuring to see where I stand right now... Thanks for the info man!!
  3. Sep 27, 2010 at 2:09 PM
    jr114
    jr114 Well-Known Member
    Jon
    SoCal
    Truck
    Icon Ext travel CO, Icon tubular uniball UCAs, Maxtrac Spindles, Icon RR rear w 2"aal.
    sounds about right. with my 285/70s im at 40ish up front and just a little more in the rear. the guys over at wheelers told me to get the .5 spacer run the billys at .85 with the eibach and use the camburg uca's. stoked should work and get a better ride than this procrap lift.
  4. Sep 27, 2010 at 6:19 PM
    TurfTaco
    TurfTaco [OP] Is there a long john silvers on the island?
    URE
    07 Deer Collector
    285/75-16 BFG KM1's, AVS vent visors, AVS hood shield, pioneer avic F900BT, pac steering wheel control adapter, Boyo rearview camera, pac ipod interface, tinted windows, Toytec 1.5 AAL, Bistein 5100s (front set to .85) Eibach coils, Black headlights, grillcraft black billet insert, N-fab light bar, 4 Hella FF700 lights & color matched grille, Sockmonkey bedside decals. 16x8 MT sidebiters, Weathertechs, Fabtech spare carrier.
    The 1/4" driver side spacer fits no problem. If you use a 1/2" spacer you will have to get extended studs...learned this from outlaw7. He has this setup with 285s.
  5. Sep 27, 2010 at 6:23 PM
    TurfTaco
    URE
    07 Deer Collector
    Ok, stock #s were Drivers Front (34.25") Passenger Front (34.50") Drivers Rear (36.06") Passenger Rear (36.375") and now with the eibachs and 5100s at .85 with 1/4" driver side spacer: Drivers Front (37.25") Passenger Front (37.50") Drivers Rear (37.75") Passenger Rear (38") Same size tires in both scenarios.
  6. Sep 27, 2010 at 6:26 PM
    TurfTaco
    URE
    07 Deer Collector
    And I really think all i will have to do to fit 285s is remove the front mudflaps and trim the black fender liner nipple thing in front of the tire. There won't be any flexing this truck anyway...too old and too poor to be tearing shit up. We'll see how it goes....Damn I aint ever gonna wear out these BFG AT's! Proly gonna get 70k out of em.
  7. Sep 27, 2010 at 8:24 PM
    jr114
    Jon
    SoCal
    Truck
    op, thank u for taking the time to measure that out. much appreciated
  8. Sep 28, 2010 at 11:21 AM
    Burns
    Burns Excellent Member
    17 DCSB Off-Road
    Bilstein 5100's @ 2.0", Wheelers 1.5" AAL, 265/75/16's
    Def man 4x4 makes a difference, I have the Eibachs on my stock billys and I only got about an 1" of lift.
  9. Sep 28, 2010 at 11:35 AM
    huntark03
    Maumelle, AR
    So I prolly would get any additional lift going from 5100's @ 1.75 to Eibach springs and 5100's at .85??
  10. Sep 28, 2010 at 11:59 AM
    Fabulous
    Fabian
    Calgary, AB
    Well, like I said mine is a double cab 4x4 short box, and with a full tank of gas and after settling it is at 2 1/4" of lift. I was going to go with the 1.75 setting on the 5100's with the stock spring but heard it was rough, so I went with new springs also as they were only $145 from Toytec...it's up to you, but I really appreciate the extra 1/2" of lift I got from the eibach springs at the 0.85 setting. Honestly, I think the 5100's at 1.75 combined with a 1.5 Toytec AAL would look really fresh if your just looking for a bit of lift...up to you.
  11. Sep 29, 2010 at 6:36 AM
    Burns
    17 DCSB Off-Road
    The lift you get will be minimal but the Eibachs spring make a big differance in the handling of the truck. When my stock billys wear out I will be installing 5100's at the .85 setting with my Eibachs.
  12. Sep 29, 2010 at 7:05 AM
    Fabulous
    Fabian
    Calgary, AB
    I agree. The ride difference is huge compared to stock. I have to take my truck back to get my alignment dialed in better, but on a ride last night the thing handles like a dream...no more bouncy/ floating ride.
