3" lift questions
Discussion in 'Suspension' started by Dcrooks84, Apr 23, 2008.
  1. Apr 23, 2008 at 1:55 PM
    Dcrooks84
    Dcrooks84 [OP] Sir Anal Loin of Beef
    Ohio
    05 double cab SR5 Pkg #8 lng bd 4X4
    Removed secondary air filter, Fog light anytime, Map light mod, Scan Gauge II, Polished Stainless Steel Westin E-Series Bull Bar, Black GrilleCraft Grille, Borla CatBack Exhaust
    Hey guys I am seriously looking at putting the toytec 3" lift on my taco. The questions I have is would it be best to put the bilstein 5100 on there as well? Along with that should I do anything else, like do the drops on the CVs? I don't want to cause excessive wear on anything because of this.
  2. Apr 23, 2008 at 2:03 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    Negative on the 5100s.
    Which Toytec kit did you get? I'd suggest buying new shocks along with it. I'd buy the diff drop just to be safe.
  3. Apr 23, 2008 at 2:05 PM
    Dcrooks84
    Ohio
    I have not purchased a lift kit at all yet. I have no lifting experience, I was hoping to see what everyones thought was. I might go with another kit if it would be better.
  4. Apr 23, 2008 at 2:12 PM
    ellsworth
    ellsworth Well-Known Member
    Buffalo
    08' off rd 6 speed
    6 inch Fabtech, st stabilizers, 18x9 DC -1s 305/65/18 bfg at's
    Check out truxx level kit...3" front and 1" rear...No spring disasembly...I am very pleased with this kit..I have 305/60/18's No rub, my stock tires were 265/70/16 with passenger rating..My new BFG's are the new mud terrains with a aggresive crawler style sidewall...very strong tire...the diff drop is a little over rated but I installed it anyway..there 14mm spacers for the front diff tab mounts..thats it..if you want the stock ride unchanged, check out truxx level kit...install less than 3 hrs with handtools..(if you do go with a coil preload kit or a above the mount kit, unhook the outer tie rod ends and swing em out of the way, much easier install)
  5. Jan 3, 2010 at 2:13 PM
    zurdo41
    zurdo41 New Member
    Antonio
    Brownsville, Texas
    06 PreRunner
    Tuff Country 3" lift kit
    Hey guys i currently have a 2006 tacoma with a 3 inch lift and i am running on 275/65r18 hancook at tires. I really dont like the way they look, am new to the offroading system so i need some help. I wanted to put some 305/65r18 BFG KM2, but i am not sure if they will fit without rubbing. Is there anything i could do to avoid rubbing on the fenders.
    thanks.
  6. Jan 3, 2010 at 5:56 PM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    you serious,u like that kit?
  7. Jan 3, 2010 at 5:58 PM
    pataco
    Down by the lake
    05 4x4 trd dc white
    dude,that is called thread jacking.glad its not my thread.:goingcrazy:
  8. Jan 3, 2010 at 6:05 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    x2 :fenforcer:
  9. Jan 3, 2010 at 6:08 PM
    ColtsTRD
    Scott
    AZ
    Toytec makes a solid lift for Tacomas and there alot of guys on here running that same lift your inquiring about (assuming its the Ultimate Lift Kit they offer). One more thing you'll have to look into is after market UCAs to fix your alignment issues you'll have. Check out Total Chaos and Light Racing...it all depends on your budget :)
