3" lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by leif_5, Oct 9, 2015.
  1. Oct 9, 2015 at 2:39 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    The single AAL is just that, it is a single leaf installed in your existing leaf pack. The progressive AAL is 3 leaf mini pack installed in your existing leaf pack. The progressive AAL progressively builds resistance as it is compressed, so it initially compresses easier giving a better ride. The single leaf pack will be very stiff to compress from the beginning giving a harsher ride.
  2. Oct 9, 2015 at 2:42 PM
    VandalTaco
    VandalTaco Well-Known Member
    Will
    Moscow/Idaho falls, Idaho
    07 DCSB TRD SPORT
    OME 887 lift, 16" XD addicts, 285 duratracs, leather seats, badass JL/Focal stereo
    3" at first but it's settled a bit so probably about 2.75". The 885s put you at 2.5"
    Smashing[QUOTED] likes this.
  3. Oct 9, 2015 at 2:49 PM
    10X TACO
    10X TACO Well-Known Member
    Wally
    Plantation, FL.
    2015 Tacoma TRD Sport PreRunner
    What coil do you recommend for a DCSB 2WD?
  4. Oct 9, 2015 at 3:39 PM
    VandalTaco
    Will
    07 DCSB TRD SPORT
    887s for ~3" I don't think the weight difference from 2 to 4wd will make much difference... If you contact @HeadStrong Off-Road I'm sure Marie will help you out with any questions or concerns you might be having. She was very helpful when I was going through this whole process.
    HeadStrong Off-Road likes this.
  5. Oct 10, 2015 at 5:28 AM
    Telkins88
    Telkins88 Well-Known Member
    Ohio
    2021 TRD Sport 4x4 Premium
    Goodyear Ultraterrain AT 265/70r17 1” front and rear lift
    I had 887s before and they gave me over 3 inches of lift. I wouldn't recommend them for your purposes especially not without aftermarket upper control arms.
  6. Oct 10, 2015 at 8:15 AM
    VandalTaco
    Will
    07 DCSB TRD SPORT
    Over three inches? On a double cab?
  7. Oct 10, 2015 at 8:29 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Did you use a top plate spacer?
  8. Oct 10, 2015 at 9:16 AM
    Telkins88
    Ohio
    No top plate spacers. Yes a double cab V6 auto.
  9. Oct 10, 2015 at 9:35 AM
    VandalTaco
    Will
    07 DCSB TRD SPORT
    Then you or whoever installed it did something wrong
    geekhouse23 likes this.
  10. Oct 10, 2015 at 9:47 AM
    Telkins88
    Ohio
    lol ok
  11. Oct 10, 2015 at 11:49 AM
    SouthCarolina
    SouthCarolina Member
    Bill
    Piedmont, South Carolina
    2013 tacoma Sr5 4x4
    Stock
    So how hard is it to install the headstrong kit?
  12. Oct 10, 2015 at 7:05 PM
    Tacoma SS
    Tacoma SS Well-Known Member
    Denver
    Supercharged 09 on 35s
    Boost and flex and 35s
  13. Oct 10, 2015 at 7:37 PM
    Taco Salad Sport
    Taco Salad Sport Well-Known Member
    Castle Rock, CO
    2012 Sport DCSB 4x4
    Did anyone with 3" of lift extend their brake lines? Curious because I remember reading (and writing down somewhere) that I needed to do that when I end up lifting.
  14. Oct 10, 2015 at 8:04 PM
    geekhouse23
    I did on all 4 corners
  15. Oct 10, 2015 at 8:21 PM
    #35
    Hartford
    Hartford Well-Known Member
    Maine
    2011 Acc Cab 5spd
    You aren't going to get a softer feel with three inches of lift at a 1k price point. You might, might, be able to get to get a stockish feel at three inches of lift at a 2-3k price point doing all of the install yourself. IMNSHO.
  16. Oct 10, 2015 at 8:25 PM
    #36
    Hartford
    Maine
    2011 Acc Cab 5spd
    Depends on what lenghth, collapsed and extended, shocks you go with in the back and how much droop you can get out of the leaves. The front is pretty safe with any extended travel, not long travel, coilover you can find as the cv-joint or ball/uniball joint will bind before the brake lines do. Most of the time.
    ETA: It depends on your set up and the only way to be sure is to take your own measurements and cycle it all your self. But you are pretty safe with OME lift as they seem to limit all the down travel to be safe with all other components being stock.
  17. Oct 10, 2015 at 8:43 PM
    #37
    Justinlhc
    Justinlhc Not looking for a relationship
    Is this for a 2wd or 4wd? Any 3"+ lift you get besides a spindle lift(for 2wd) will have "alignment issues" with stock control arms.
    If you're 2wd your best bet is a spindle lift and a 3 leaf AAL. You'll probably even have money left for a new set of shocks.
    If you're 4wd you better factor in the cost of UCA's because any 3"+ lift you pick will require them if you don't want the "alignment issues" you mentioned. SPC(light racing) UCA's can be found for $375.
  18. Oct 11, 2015 at 9:33 AM
    #38
    ndmak
    ndmak Well-Known Member
  19. Oct 12, 2015 at 12:48 PM
    #39
    HeadStrong Off-Road
    HeadStrong Off-Road Well-Known Member Vendor
    2011 Toyota Tacoma and 2019 4Runner
    Good afternoon Wally!
    I find it very helpful to supply our customers with a list of coil specifications so they can compare the coils side-by-side. It is always hard to guarantee the exact lift height because so many variables come into play. The largest being the over all weight of the truck. Each truck varies based on model/trim. For instance a 2wd weighs less then a 4wd and a access cab less then a double cab. For example a double cab 4x4 will gain approx. 2.5" of lift from the 885X coils whereas a double cab 2wd can gain approx. 3" of lift from the same coil. Also sometimes when taking before and after measurements customers will yield more lift then advertised or expected. That can be attributed to the ware and tear on the factory components. If the truck is 10 years old and has 100k+ miles on it then the lift coil might seem to provide more lift in that instance then it will on a brand new truck. This is simple due to the condition of the factory parts being worn in. The same is true when measuring lift from replacement leaf packs and add-a-leafs. Please let me know if there is anything that I can help you out with.
    Eibach 112-620 coils 620lb spring rate 381mm in length
    Eibach 52-1600 lift coils 610 lbs spring rate 391 mm in length
    OME 883 coils 590 lbs spring rate 375 mm in length
    OME 884 coils 590 lbs spring rate 390 mm in length
    OME 885 Coils 590 lbs spring rate 395 mm in length
    OME 886 coils 660 lb spring rate 402 mm in length
    OME 887 coils 590 spring rate 400 mm in length
    Arailt likes this.
  20. Oct 13, 2015 at 4:09 AM
    #40
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    From what I hear, on the second gen trucks the difference is so negligible, it's not worth spending the money and effort on.
