3" Lift
Discussion in 'Suspension' started by makalapaboy, Apr 29, 2008.
  1. Apr 29, 2008 at 10:34 AM
    makalapaboy
    makalapaboy [OP] New Member
    North Las Vegas
    08 Prerunner TRD Off-Road
    I was just wondering if I got a 3" lift what are the biggest wheels and tires I can put on without having anything scrape or cutting anything. also if you could tell me what is the total height of your truck cause I live in vegas and if you go down to the strip your most likely parking in a garage which might not fit a lifted truck.
    Thanks for the input
  2. Apr 29, 2008 at 12:04 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    Stock tire size is the largest you can put on with a 3" kit without doing any trimming.
  3. Apr 30, 2008 at 8:46 PM
    audiophile22
    audiophile22 The Anti Alliance Alliance. BAM!
    Little Rock, Arkansas
    2007 Tacoma
    Pioneer 9600, Alpine Amps, Infinity Speakers, XM, Ipod 5% tint, Rain Guards, Debadged. 3" Toytec Lift, Flowmaster exhaust, more to come...
    eh ehhheeemmmm, i have three inch lift. Before i did the lift I put on 31.5" all terrains.... now i could easily do 33" and not scrape... soo... uhh... yeah.
  4. Apr 30, 2008 at 9:21 PM
    roxspin72
    roxspin72 Enjoying my addiction
    NC
    Speedway Blue, TRD, 4X4,
    Oh Yeah!!!
    Nah Brah... Definately need to trim with 33's. Mine are actually 32.87" and had alot to trim w/my readylift 2.25" up front. So, I'm sure there is some triming to be done unless you go w/the 6" lift's that are out there...
    Note: dont just think of turning radius, you must also think of travel, ie.. speedbumps and all sorts of other road conditions. I trimmed til nothing could stump me. And I am pleased with the outcome...
  5. May 1, 2008 at 9:40 PM
    audiophile22
    2007 Tacoma
    ok maybe some trimming, but just going a size bigger than stock like I did doesn't make u have to trim... I'm gettin 33's soon... So i guess i'll be breakin out the saw and gettin to work....
  6. May 2, 2008 at 2:44 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    the largest size b4 a lift is a 265/75/16 or the 265/70/17 equivalent.
    u shouldnt need too much of a trim after that 3" lift. u might be able to get by w/ just removing the front mudflaps...or if u want to keep them, they'll need to be trimmed down for sure
  7. May 2, 2008 at 2:46 PM
    audiophile22
    2007 Tacoma
    those things are LONG gone!!! i think the first time i backed up on a trail my tires caught them and chewed them up... looks better without out it anyway
  8. May 5, 2008 at 11:27 AM
    zmtnbik
    zmtnbik FMLYHM
    4x4 Trd Off-road
    Donahoe (Icon) C/O, TC UCA's, Dakar leafs, BilStein 5125's, 285/70/17 BFG MT KM2's, Raceline Renegade 17x9's, u-bolt flip kit, debadged, TRD CAI, TRD exhaust, URD MAF controller, 20% front window tint, 3M clear bra on bumper, cam locks in all storage compartments, fog light mod, Alpine X100 deck, Co
    I tried timming my mud flaps, that latest about 50 miles, until they fell off. It's not worth trimming as you have to remove too much material so they don't rub. A solution I found was to mount up some 88 mud flaps and trimmed them down to fit. They did the job for a while, but have opted to run w/o flaps.
  9. May 5, 2008 at 9:16 PM
    BIg Ned
    BIg Ned New Member
    so, are you saying that with just a 3" lift and taking off the mud flaps, you can run 33's?
  10. May 6, 2008 at 12:52 AM
    makalapaboy
    North Las Vegas
    Thanks for all the input but now i have another question. i plan on getting the 3" lift kit from toytec, lift coil kit with AAL whats the differance between the added leaf spring or the 1 1/2" block? also even though i dont have a 4x4 would i still need a diff drop kit? i just never lifted a truck, and i just want to do it right. and should i replace any shocks? i got a 08 tacoma AC i got the stock 3 pack leaf spring. hope i gave you guys all the info to get some good answers. Thanks again
  11. May 6, 2008 at 2:14 AM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    supposedly an aal is a better choice than the block, but i have an aal and 1" block under mine. the block is supposed to increase axlewrap, but i didnt notice any with mine. i think its mainly the larger blocks: 3"+. The diff drop is for the front differential, so on a prerunner this is not necessary since there is no front diff. you might want to replace the rear shocks on your truck. mine would top-out sometimes so i switched to some 0-2" list Bilstein 5100 and couldnt be happier with them; no more violent topping out and it rides a little better with them.
  12. May 6, 2008 at 5:21 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. Custom dents.
    You still have the factory 3 leafs so the aal will be fine. If you had the Tsb done Toytec reccomends the block, because if you added an additional leaf on top of the tsb you would have more than 3" of lift. Atleast that is what I was told. Now if you go and the the Tsb done for your truck and you have a non TRD you will get the shock upgrades the 5100 Bilsteins. Your call. My lift with coils and block with the drop kits was $460 and arrived in 4 days. If you look at your front wheel wells you will see the plastic nubs that are in the front will most likely have to be cut. It will depend on how aggressive a tire you go with as of to how much you have to cut.
  13. May 6, 2008 at 8:51 AM
    makalapaboy
    North Las Vegas
    i got the TRD off road package with the Bilstein shocks should i still replace the shocks?
  14. May 6, 2008 at 9:48 AM
    Khaos
    Khaos Big Member
    Bryant
    You don't have to. But it will greatly improve both your ride and suspension travel.
  15. May 6, 2008 at 10:58 AM
    RelentlessFab
    Eric
    Sparks, NV
    well, its kinda your preference. Some 5100's will probably ride better, but id change them out if you find the rear shocks topping out. or, theres a extension that can be bolted onto the factory bilsteins to add another inch or so to the total length of the shock.
  16. May 6, 2008 at 7:55 PM
    L_Jackson
    L_Jackson Well-Known Member
    Houston, TX
    2007 Black Sand Pearl PreRunner Acce
    Tinted Windows, Tow Hitch, 3" Toytec Lift, American Racing Outlaw II Wheels, Cooper Discoverer 33's, Aries Bull Bar w/ (2) 5" Lights, Nerf Bars, Fog Lights as DTR Lights, Roll Bar w/ (4) 5" Lights, Sony Speakers, 2 Extra Tie Downs
    i did a 3" toytec lift, and my 33's rubbed... i had already taken off the mud flaps, but had to trim the inside flemsy wheel well plastic some up front by the fender. used some band cutters and it looked a little ugly so i cleaned it up some with a dremel tool.....
    mainly when you crank the wheel all the way... but.... trim some extra... cus when you are in the truck, and if you have a passenger, the weight brings it down some more... and as you rolling, the truck leans some more than just sitting still with the wheel turned...
  17. May 11, 2008 at 3:43 AM
    tacodave06
    tacodave06 Active Member
    central valley
    06 dub cab 4x4 3" lift
    3" susp lift. weld wheels w/ mud terrains. mb quart 6x9's in front
    i got a 3" revtek spacer kit with 285/75/16 and no rubbing
  18. May 11, 2008 at 8:59 PM
    TmansToy08
    TmansToy08 3 Time Toyota Man
    Vancouver British Columbia
    Toy Tacoma TRD
    I added a 3 inch lift with a stock component via Truxxx.com. No mods to the sus. This is a level lift. I swapped out my stock 16 inch for 17's with BF A/T's. Even with this lift, there is a litte slight rub on the lower front fender well at tight turning. Just wanted to put my cents in. You can see my truck in the gallery.
    Regards,
    T
