3'' RevTek, Can I run 285/70/17?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mobbinkelto, Mar 26, 2013.
  1. Mar 26, 2013 at 4:34 PM
    mobbinkelto
    mobbinkelto [OP] Member
    2010 Toyota Tacoma Mag Gry/2016 Toyota Tacoma Sport
    Ive noticed this question coming up alot and im sorry but, I have a 3' RevTek lift and was wondering if I could run 285/70/17?
    Just curious in seeing what other people run with this lift..
    thanks
  2. Mar 26, 2013 at 4:40 PM
    spark4
    spark4 Well-Known Member
    Orange County, CA
    09' 4x4 Dbl. Cab TRD Sport
    I ran 285/70/17 on a 2.5" lift. I ran them on stock sport wheels so I had to use spidertrax spacers though. You should be fine
  3. Mar 26, 2013 at 6:19 PM
    mobbinkelto
    ok right, you think itd be fine even if I ran an agressive tire like km2's or similar to that?
  4. Mar 26, 2013 at 6:21 PM
    06 tacoma owner
    06 tacoma owner Well-Known Member
    Will
    Western KY
    2006 AC super white 4x4
    4 inch lift, 6000k HIDs, weathertechs, Pioneer head unit with bluetooth, 285/70 trail grapplers, aero turbine muffler w/ flowmaster 3 inch stainless tip
    You should be good.
  5. Mar 26, 2013 at 7:50 PM
    redtacoma88
    redtacoma88 Well-Known Member
    John Austin
    TN
    2012 TRD Off Road
    See Build Page...
    Should be fine. If you have stock wheels spidertrax spacers might be smart
  6. Mar 26, 2013 at 7:53 PM
    Corndawg
    Corndawg Well-Known Member
    Corey
    Utah
    2007 double cab TRD off road Radiant Red
    2.5 inch pro comp lift Cobra XRS 9745 Detector 15 band scanner Pioneer DEH-P6900UB Python 991 remote start/ security. Tinted license plate covers Fog Light Mod PIAA Extreme White 4000K Replacement bulbs Red LED Dome and Map lights LED replacement tail light bulbs Black Weather Tech Floor Liners front and rear
    yeah i have 285s with my 2.5 inch pro comp. i removed front mud flaps little grinding when in reverse....
  7. Mar 26, 2013 at 8:14 PM
    mobbinkelto
    how about if I get some pretty offset rims, will it still have no issue?
    I basicallly want the same setup your running as wheels and tires go.
  8. Mar 26, 2013 at 8:25 PM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    You can run 285s with no wheel spacers if you buy wheels with 0 offset or less, dont go any lower than -12 offset though. Check out scs stealth 6's
    Do you mean no issue as in no rubbing? Because there is a good chance you will rub
  9. Mar 26, 2013 at 8:42 PM
    mobbinkelto
    okay thank you, and yeah those rims are raww. definatly the style im looking for
