3" Revtek Lift Question
Discussion in 'Suspension' started by Godfish, Jul 27, 2007.
  1. Godfish
    Godfish [OP] New Member
    Hi, I bought a 3" Revtek Supsension lift for my 1998 Toyota Tacoma Ext. Cab and I am wondering what size tire to put on. I'm going with a 33" tire, I called revtek and they suggested going no bigger than a 33x10.5 with 4.5" of backspacing. Do you think I can get away with less backspacing to let the tire hang out a little more past the rims. I have 2" fender flares on right now.
    Thanks in Advance
  2. Panama Red
    Panama Red Well-Known Member
    I think you are confusing "offset" with "backspacing" (they are opposite). The lower the offset, the more the wheel extends beyond the fender. The greater the backspacing, the more the wheel extends beyond the fender.
  3. MarkC
    MarkC Carolina Alliance: Warheads On Foreheads Division
    Mark
    Yokota AB, Fussa-Shi, Japan
    99 4x4 SR5
    2 inch spacer in the front, and homemade add a leaf in the rear, billet grille, bull bar
    32's brother man you will be plaesed
