3" Toytec Lift Lifted My 2009 Regular cab 4.5 inches!?
Discussion in 'Suspension' started by Tonka Tacoma, Apr 14, 2011.
  1. Apr 14, 2011 at 8:02 PM
    Tonka Tacoma
    Tonka Tacoma [OP] Well-Known Member
    Eric
    Plattsburgh, New York
    2023 TRD Sport- Long Bed
    I just installed a 3" Toytec Lift and according to my measurements, I obtained 4.5'' of Lift From It? I'm Not Sure If It Is Because It's a Regular Cab Or What, But It Rides Perfect and My CV Angles look Good, So I'm Not Worried About It. I Was Wondering If This Is Common With A Toytec Lift.:cool:
  2. Apr 14, 2011 at 8:04 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    lets see those CV angles. Also just adjust the preload to get the desired height
  3. Apr 14, 2011 at 8:04 PM
    schiz94
    schiz94 Thread Jacker
    Caleb
    Bellingham,WA
    08 Tacoma Reg Cab
    Morimoto Projector Retrofit, alpine cda-105,Wheelskins leather wheel cover, wet okoles,5% tint on back and 24% on front two windows,Debadged tailgate,custom sockmonkey centercap decals, xr rims pced gloss black.
    Looks good. Glad you aren't worries about it. :p
  4. Apr 14, 2011 at 8:06 PM
    Blue
    Blue You're my boy blue
    Dylan
    Sierras
    ex 99 current 04 TRD
    where did you measure? Ground to top of flare? You put bigger tires on didnt you?
  5. Apr 14, 2011 at 8:07 PM
    YellowDog01
    YellowDog01 Well-Known Member
    04 4x4
    Is it the Coilover kit or is it just the 3" Spacer?
    Lifts take some time to settle in...I'd give it some time.
  6. Apr 14, 2011 at 8:07 PM
    Tonka Tacoma
    Eric
    I Can't Adjust Them. It Is an Old Man Emu Coil With A Top Plate Spacer. I Did Use The 1" diff. drop and My CV Boots Look Pretty Decent. It Can't Hurt Anything Else Can It?
  7. Apr 14, 2011 at 8:08 PM
    sambojee
    sambojee Well-Known Member
    Sam
    Iowa
    2011 TRD OffRoad
    Bilstein 5100 all around set at 2.5. 1.5 AAL in the rear. 265/75/16 Hancook Dynapro MTs on Black Moto Metal 951s. Black badges. Aftermarket grill. TRD seat covers.
    looks awesome, just make sure ur cv angles look right
  8. Apr 14, 2011 at 8:12 PM
    Tonka Tacoma
    Eric
    Yup, I measured From The Ground To The Bottom Of My Flare Through The Center Of My Hub. My Tires Are Only 265-70-16 In a BFG AT. They are only about 3/4 Of An Inch Bigger Than Stock.
  9. Apr 14, 2011 at 8:17 PM
    Tonka Tacoma
    Eric
    I Have Drove The Truck About 60 Miles So Far And It Did Settle a little bit. I Want It Settled In Before I Get An Alignment. Who Knows, Maybe It will Settle More.
  10. Apr 14, 2011 at 8:25 PM
    saxscraper
    saxscraper New Member
    Portola, CA
    OME/Allpro Suspension, Snugtop, Duratracs, and some other stuff...
    Which OME coils did you use? How big is the spacer?
  11. Apr 14, 2011 at 8:34 PM
    Tonka Tacoma
    Eric
    Im Pretty Sure The Coils Are 884s. Thats What I was Told To Get For A Regular Cab. My Top Plate Spacer Is The 3/4" That Came With The Lift Kit.
  12. Apr 14, 2011 at 8:51 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Take that spacer off. ANything over 3" lift, and you have a good chance of busting your CV's.
  13. Apr 14, 2011 at 8:55 PM
    snorola
    snorola Well-Known Member
    Brett
    Canmore Alberta
    06 4x4 Dbl Cab
    SAW 2.0 Coilovers Eibach 14" 650lb springs Camburg UCA's All pro expo springs OME rear shocks All pro front bumper All pro IFS skid All pro sliders SCS f5 matt black rims Lightforce blitz 240's
    show us your cv angles!
    Whats your measurement up front from centre of the hub to the bottom of your fender?
  14. Apr 14, 2011 at 8:58 PM
    Tonka Tacoma
    Eric
    Even With The 1" Diff. Drop? Like I Said, My CV Angles Are Pretty Good.:confused:
    What Would Make It Settle More, If Anything?
  15. Apr 14, 2011 at 9:01 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    That 1" "Diff Drop" only drops the front of the diff 1". The point of the axels is only changed by about 2* or so. So...In a nut shell, Yes.
  16. Apr 14, 2011 at 9:01 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Piccssss
  17. Apr 14, 2011 at 9:05 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Do those tires and wheels look bigger than 265/70R16 to anyone but me? I wanna say the OP is rollin' 265/70R17.
  18. Apr 14, 2011 at 9:07 PM
    OZ-T
    Peter North
    British Columbia
    I don't know , my 265/70/17 look like they should touch at front and mud flap
  19. Apr 14, 2011 at 9:09 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Must just be the negative offset of the DCs that makes me think that, then.:)
  20. Apr 14, 2011 at 9:13 PM
    Tonka Tacoma
    Eric
    Rims: 16X8 DC-2s
    Tires: 265-70R-16s-BF Goodrich All Terrain TA's
    I'm 100% On The Tire & Rim Size. I'm Not Sure Why They Look So Big In The Picture. I Agree That They Look more Like 17s.
