30,000 mile questions?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SurfnWolf, Sep 17, 2008.
  1. Sep 17, 2008 at 11:21 AM
    SurfnWolf
    SurfnWolf [OP] Well-Known Member
    Fayetteville NC
    2006 Tacoma Prerunner Double Cab
    ok got a call from toyota to do the 30,000 mile service. But I like to do most myself. I have the 2006 Double Cab V6 2wd
    One thing I havent heard before was " retorque the propellar shaft" ?
    How necessary is that, and what kind of torque? I havent read the manual yet so just asking?
    Also I ask them about replace plugs with Iridium>? They go to the manager and he says I cant replace my plugs with Iridium on that model, I have to use standard? I have seen on these threads others have switch so I question that? Anyone else heard anything about not using Iridium?
    Brian
  2. Sep 17, 2008 at 11:26 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    good to see another fayetteville member...
    as for the plugs, i put champion iridiums in my 07 DC prerunner w/ no probs.
  3. Sep 17, 2008 at 11:31 AM
    S_A_Aceman
    S_A_Aceman KS National Guard
    06 TRD Sport Speedway Blue
    Air Cleaner mod
    I was going to do the plugs on my '06 a month ago... Napa quoted me $12 each for plugs, so I didnt do them. But I havent looked into a reason for the expense. Any leads here?
    Ive done all of my services also, almost ready to hit 40000 miles. I checked the clips on the rear diff.. and found bad universal joints. Thats all there is as far as I know. Normally a propeler shaft a front drive axle as Ive heard
  4. Sep 17, 2008 at 11:32 AM
    SurfnWolf
    Fayetteville NC
    Thanks! Rick Hendrick is pretty good to work with so far, but I usually do most myself? Still probably buy my parts from them for the 30,000 mile change.
  5. Sep 17, 2008 at 11:52 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    with a 2 wheel drive, at 30k, its a really easy diy!!! oil and filter change, replace the diff fluid, check air filter, rotate tires, and change the spark plugs.............and mostly everything else is just checking everything over. on the 06 i had, when i did the 30k on it....i just went with the standard denso copper plugs...about $3 or so a piece at the dealer. i didnt see any point in changing over to iridium(although you can do so) with what they cost, and no real power/mileage gains from them.
  6. Sep 17, 2008 at 12:07 PM
    SurfnWolf
    Fayetteville NC
    Ok,,,but someone help me out with the "re-torque propellaer shaft bolt?"
    Never done that one before...where is it? whats to torgue lbs? is this in the manual with explanation?
  7. Sep 17, 2008 at 12:18 PM
    vtachtom
    vtachtom Member
    Tommy
    corona ca
    05 double cab prerunner trd
    Billie 5100's X4 with Deaver AAL in the back, more to come
    ya where the heck is that thing and can some post a picture of it thanks
  8. Sep 17, 2008 at 12:20 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    im pretty sure the ft. lbs for the prop shaft(driveshaft) are 60 ft lbs, and i think its the bolts around the shaft near the transmission.
  9. Sep 18, 2008 at 7:53 AM
    vtachtom
    vtachtom Member
    Tommy
    corona ca
    I got under there today and there is a few bolts near that area. I pic would really help. thanks Guys
  10. Sep 18, 2008 at 4:34 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Its the bolts that connect the drive shaft to the transmision. ANd that connect the drive shaft to the rear axel. If you follow the drive shaft up to the tranny, you will see the bolts that need to be torqued. Just stick a wrench on them and give a tug. Main thing is to check for looseness. :)
  11. Sep 18, 2008 at 8:06 PM
    vtachtom
    vtachtom Member
    Tommy
    corona ca
    hey Chris thank so much.
  12. Mar 17, 2011 at 7:53 PM
    samsung
    samsung Well-Known Member
    George
    Sugar Land, Texas
    2011 PreRunner doublecab TRD Offroad
    undercover lid/Ipod integration kit/Pop n lock/bed rug, fumoto drain valve, full piping Wet Okole covers, Blacked out badges, Lamin-X fog light cover yellow, window tint, ARB deluxe bumper with fog light kit,DSM UCA'S,3 support shrockworks sliders,complete OME lift with 886X coil and dakar leaf spring with 3 degree axle shims and center pin lenghtener,warn VR10000 winch,amsteele blue synthetic rope, daystar winch isolator, daystar delrin rollers, IPF 900xs Extreme Driving H9 Kit 900XSD (900XSD),Horn on fire with shot Penning,
    for the plugs i just put the factory plugs that i got from the dealer for around $3 a piece. It's not too bad of a diy, the two rear plugs in the driver's side takes a little longer, since you have to move some hoses and brackets out of the way and some long socket extensions work really well on the driver's side. As far as the propeller shaft re-torque don't know much about it, searching here in TW to see if i find anything.
