30,000 mile service costs $1,100???
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 4xThad, Oct 4, 2022.
  1. Feb 19, 2024 at 4:50 PM
    #261
    2k2
    2k2 Flareless
    Zak
    Gen 3 SR 4x4 4cyl AC
    See Build Thread
    Thanks. I'll have a look at the rotors. If they appear to be in descent shape I'll just replace the pads. As far as I know nobody in my area will even turn rotors any longer...theyll just tell you to go buy new. It doesn't seem to be worth anyone's time vs. the cost of new ones. 60k OEM pad replacement worked out for me on my last taco for about 200k, just as long as I didn't wait until I was hearing the squealers.
    If they look scored, worn, rusty, etc I'll bite the bullet. I'm generally pretty easy on the brakes, although I have had A few hard braking situations in the past 60k.
    I'll look into the brake fluid as well .. seems like something I should probably do if I'm replacing other parts.
  2. Feb 19, 2024 at 5:10 PM
    #262
    ArtDawg 5150
    ArtDawg 5150 Member
    Roger
    PNW
    2022 Tacoma SR5 Double Cab Long Bed
    On my 2005 Tacoma, I changed the engine oil and rotated the tires evert 7500 miles. I did the diff and trans service every 60k. I had the brakes and power steering flushed every 75k. Replaced the plugs myself every 60k. About every 50k, I'd throw a bottle Seafoam into the crankcase a couple hundred miles before the next oil change. I drove that truck for 17 years and put on 280,000 miles. When I went to trade it in, it still ran just as good as new. The Toyota maintenance your dealer is recommending is way overkill.
    davidstacoma and CygnusX191 like this.
  3. Feb 19, 2024 at 5:33 PM
    #263
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Sounds like you've got a good head on your shoulders.
    ASE brake fluid interval is 2 years/30,000 miles, Toyota recommends 3 years/50,000 (superior seals and construction etc).
    No need to get funky with an abs bleed unless you're having problems. Hand pump vacuum bleed or gravity bleed works just fine. Plenty of YouTube university on that one, fairly simply process.
  4. Feb 19, 2024 at 7:48 PM
    #264
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    Glad you did it yourself and the dealership can still kick rocks. Big ones.
  5. Feb 20, 2024 at 12:08 AM
    #265
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    It’s no longer your thread because you said the word “oil”. You brought it on yourself. :rofl:
    andthen, CygnusX191 and usmc2msu like this.
  6. Feb 20, 2024 at 3:22 AM
    #266
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    :rofl: there is truth to that statement
  7. Feb 20, 2024 at 9:36 AM
    #267
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    TacoTime55, usmc2msu and CygnusX191 like this.
