30,000 mile Warranty Service
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ConantTaco, Sep 25, 2023.
  1. Sep 25, 2023 at 11:47 AM
    ConantTaco
    ConantTaco [OP] Well-Known Member
    Dave
    2019 Tacoma TRD Off-road
    Our truck is going in for the 30,000 Warranty Service.
    What does it involve and cost?
  2. Sep 25, 2023 at 11:50 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    They're gonna try to sell you a whole bunch of shit. Stay strong, soldier.
  3. Sep 25, 2023 at 11:52 AM
    ConantTaco
    Dave
    I'll tell my wife, she's taking it in.
  4. Sep 25, 2023 at 12:01 PM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    Take it to a good ( key-word=good ) independent shop that works on Toyota only.
    I found one for mine and another for the wife's Subaru.
    Typically better than the dealer and much cheaper.
    Otherwise you're looking ( guessing here ) at $500 ~ $900 ...
    Do let us know how it turned out.
  5. Sep 25, 2023 at 12:05 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Send your wife a screenshot of the owner’s manual.
    Chances are; they’ll quote at least 4-6 nonsensical booshit to the tune of 4 figures.
    Irons likes this.
  6. Sep 25, 2023 at 12:11 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
  7. Sep 25, 2023 at 12:14 PM
    ConantTaco
    Dave
    Sure will!
  8. Sep 25, 2023 at 12:35 PM
    LeakyAC
    LeakyAC Captain jackass
    2016 SR5 Access Cab 2.7 4x4 Super White II
    -Uni filter secondary air pump mod -A/C drip line extension mod -ARB F + R diff breathers relocated -ARB front recovery point -"Tow Package" class V receiver + oem 7/4 plug + aux ATF cooler -Toyo Open Country ATIII 245/75R16 -Yellow fog lights (amber Lamin-X w/ PIAA amber H16s) -BakFlip G2 tonneau cover -TRD Pro grille -Body-matched bumper caps -Blackout emblems -Husky X-Act Contour floor liners -RokBlokz mud flaps -oem bed mat Not yet installed: -0" lift Bilstein 5100 F + R w/ 4Runner front shock lower bolt swap -Total Chaos LCA cam tab gussets
    Just Google the service schedule it's not complicated
  9. Sep 25, 2023 at 12:50 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    McHale, Irons and LeakyAC like this.
  10. Sep 28, 2023 at 5:36 PM
    ConantTaco
    Dave
    Long story short, it came to 850$
  11. Sep 29, 2023 at 4:25 AM
    maxmk8
    maxmk8 Well-Known Member
    2022 Electric Lime M/T Taco
    Did you pay it?
    Chew likes this.
  12. Sep 29, 2023 at 12:27 PM
    Taco_mike73
    Taco_mike73 Well-Known Member
    York, PA
    2020 Cement SR5 DCSB 4x4
    Lomax tonneau cover, oem bed lights, AJT Design chrome delete, black out badges & tailgate letters, AVS hood deflector & vent visors, Solkie tech hood supports, interior LED lights, Tufskinz mud guards, RedArc TowPro Liberty, bed mat, kicker speaker upgrade, Hikari ultra H11 low beams, Diode Dynamics SS3 fogs in yellow, Meso customs total taillight stage 1. Coming soon: Compact powered sub install Future mods planned: bigger tires (265/75/16) BILLSTIEN 5100 lift
    These item need done. note that most of it is inspections. $850??? I'm glad I do my own or use an independent mechanic.
    • Check installation of driver’s floor mat
    • Inspect and adjust all fluid levels
    • Inspect wiper blades
    • Lubricate propeller shaft (4WD)
    • Re-torque propeller shaft bolt
    • Replace engine air filter
    • Replace engine oil and oil filter2
    • Rotate tires
    Inspect the following:
    • Automatic transmission fluid cooler hoses and connections
    • Ball joints and dust covers
    • Brake lines and hoses
    • Brake linings/drums and brake pads/discs
    • Cabin air filter
    • Drive shaft boots (4WD)
    • Engine coolant6
    • Exhaust pipes and mountings
    • Front differential oil (4WD)
    • Fuel lines and connections, fuel tank band and fuel tank vapor vent system hoses
    • Fuel tank cap gasket
    • Radiator and condenser
    • Rear differential oil
    • Steering gear
    • Steering linkage and boots
    • Transfer case oil (4WD)
    • Transmission for signs of leakage
  13. Sep 29, 2023 at 12:45 PM
    ConantTaco
    Dave
    Needed done for a trip, so we coughed up .
  14. Sep 29, 2023 at 1:12 PM
    OffroadToy
    At the rate their service prices keep going up won't be long when you can't get out of there for under $1000. Just curious... for the rear, front differentials and transfer case gear oil how many quarts di they charge you for? I had mine done at the dealership years ago and they charged me for 11 quarts when it only takes around 7. Asked the service supervisor about it and his reply... well, sometimes they take more. Haven't been back since.
    Taco_mike73 likes this.
  15. Sep 29, 2023 at 2:24 PM
    rtzx9r
    rtzx9r Well-Known Member
    Bueller
    2016 TRD Sport
    LS1 swap with nitros.
    What did they do, aside from an oil change and tire rotation that required parts? Just curious.
    Chew and BeastBoy like this.
  16. Sep 29, 2023 at 3:40 PM
    Chew
    Chewy
    Midwest
    19 TRD OR
    The techs I know say they performed a wallet flush. That’s a jab at their service writers BTW.
    WBTaco likes this.
  17. Sep 29, 2023 at 4:20 PM
    maxmk8
    What needed to be done ?
    Chew likes this.
  18. Sep 29, 2023 at 5:48 PM
    brian2sun
    brian2sun Well-Known Member
    California
    ‘21 TRD OR DCSB ‘17 4Runner Limited ‘97 4Runner SR5
    Other than the normal engine oil & filter and tire rotation, changing the fluid in the diffs is the only additional thing for a 30K service. 6 qts of gear oil is about $50-100 depending on brand and it takes about an hour to do both diffs. So even if they charged you $100 for the oil + $300 labor for about 2 hours (that’s how long everything should take in a 30K service - and that’s on the high end at $150/hr)… At $850, they got you for more than double what a semi-reasonable dealer would charge. Don’t go back there.
  19. Sep 29, 2023 at 8:14 PM
    Blak Shinobi
    Blak Shinobi Well-Known Member
    taco
    2020 MGM Sport DCSB 4x4
    n/a
