300AACTaco's Black '15 DCSB Alaskan Adventure Build
Discussion in '2nd Gen. Builds (2005-2015)' started by 300AACTaco, Jan 20, 2015.
  1. Jul 14, 2016 at 8:21 PM
    #541
    NickofTime
    NickofTime Well-Known Member
    Nick
    Anchorage, Ak
    2006 White Tacoma DCSB TRD
    I just throw money at my truck
    Hmm if all you added was the winch and some aftermarket fogs then there shouldn't be any problems. The winch wouldn't be full time power usage. The fogs.. Maybe, but not if they LED
    300AACTaco[OP] likes this.
  2. Jul 14, 2016 at 8:24 PM
    #542
    NickofTime
    Nick
    Anchorage, Ak
    It would be crummy if they spliced off your headlight power to run relays to power the spots and light bar. Any pics of the wiring?
  3. Jul 14, 2016 at 8:25 PM
    #543
    FarNorthTaco14
    FarNorthTaco14 James 2:18
    Jeremiah
    Anchorage, AK
    2012 SR5 6-Speed Manual
    Soft topper, Kings, Total Chaos and stuff!
    ^^^What he said
  4. Jul 14, 2016 at 11:15 PM
    #544
    300AACTaco
    300AACTaco [OP] Well-Known Member
    Alaska
    Black '15 DCSB TRD Off Road 4x4
    ARB Old Man Emu 90000s and 60091s OME 886s, Trim Packer, Icon Tubular Uniball UCAs, CMC, Invisible Sway Bar, Dakar Rear Leaf Packs, Timbren Rear Bumpstops, All Pro U-bolt flip up kit, Method Race Wheels NV 16X8 4.5BS, Cooper ST Maxx LT285/75/16, DEPO Black Tail Lights, Weathertech Floormats, Cascadia Vehicle Tents Mt. Shasta in Earth Tone Green, Custom Green Tree Fabrication Bed Rack, N-Fab Spare Tire Bed Mount
    I supplied a special adaptor for the dually fogs that way they can wire right up to the factory switch, they can only turn on when the headlights are on. I wouldn't think it would be an issue since I took the factory fogs out, and the winch is only real thing I added power wise since the fogs were just a replacement
  5. Jul 14, 2016 at 11:16 PM
    #545
    300AACTaco
    Alaska
    I had them do the light bar a while back, it's been working flawlessly ever since, they just moved it from behind the grille and into the bumper today, no wiring for it
  6. Jul 14, 2016 at 11:28 PM
    #546
    300AACTaco
    Alaska
    Shit they also didn't even put the abrasion sleeve on the rope, and that's something that you have to do when installing the winch if I'm correct....:
    The abrasion sleeve is provided with the synthetic rope and must be used with the synthetic rope, at all times to protect the rope from potential abrasion wear. The sleeve has a loose fit so it can easily be positioned along the synthetic rope to protect from rough surfaces and sharp corners.
  7. Jul 14, 2016 at 11:28 PM
    #547
    NickofTime
    Nick
    Anchorage, Ak
    Well maybe the oem fogs run off different power than the headlights. And the adaptor that you gave them:notsure: maybe they used to splice off of the headlight power. I have heard that depending on winch power, the amperage of the stock alternator isn't quite enough for powering a winch. But again, that shouldn't dim your headlights. Is there a quick disconnect for your winch? You could try unplugging it to rule it out? And I think the Fogs have connectors? Might help GTF to isolate which thing is robbing power. I plan on running a similar setup to yours so... :popcorn:
    Hoping I might be able to save myself $660
  8. Jul 14, 2016 at 11:29 PM
    #548
    300AACTaco
    Alaska
    Learn from my mistakes! No quick disconnect for the winch, I don't know what the hell is going on lol, I just want my headlights to work
  9. Jul 14, 2016 at 11:31 PM
    #549
    FarNorthTaco14
    Jeremiah
    Anchorage, AK
    :spy:
  10. Jul 14, 2016 at 11:33 PM
    #550
    NickofTime
    Nick
    Anchorage, Ak
    Hoping to not have mistakes happen in the future..
    C'mon GTF..
    Is there a fuse or something for the winch?
  11. Jul 14, 2016 at 11:34 PM
    #551
    300AACTaco
    Alaska
    It wires straight to the battery and is powered that way, apparently it only draws power though when you plug the controller in but idk
  12. Jul 14, 2016 at 11:38 PM
    #552
    NickofTime
    Nick
    Anchorage, Ak
    Hmm. Well if I was in AK I'd be more than happy taking a gander. Sorry man..
    Good thing about GreenTree is that those guys are honest and trustworthy. It sucks that they didn't Ops check the truck before handing it to the customer, but we can all rest easy knowing that they'll do whatever it takes to make it right.
  13. Jul 14, 2016 at 11:39 PM
    #553
    300AACTaco
    Alaska
    Thanks man that'd be nice of ya! And yeah I messaged Dan at GTF and he said they'd take care of it so I trust em to make it right, especially since I spend so much money there
  14. Jul 14, 2016 at 11:40 PM
    #554
    FarNorthTaco14
    Jeremiah
    Anchorage, AK
    You deployed or TDY?
    NickofTime[QUOTED] likes this.
  15. Jul 14, 2016 at 11:41 PM
    #555
    NickofTime
    Nick
    Anchorage, Ak
    Deployed... ADAB. But comin home soon!!
  16. Jul 14, 2016 at 11:42 PM
    #556
    FarNorthTaco14
    Jeremiah
    Anchorage, AK
    Lol you're right next to me! Im in AUAB leaving real soon!
    That's good to hear
  17. Jul 14, 2016 at 11:44 PM
    #557
    NickofTime
    Nick
    Anchorage, Ak
    I have a feeling we'll be taking the same flight home :anonymous:
  18. Jul 14, 2016 at 11:46 PM
    #558
    FarNorthTaco14
    Jeremiah
    Anchorage, AK
    Lol show yourself!
  19. Jul 14, 2016 at 11:59 PM
    #559
    300AACTaco
    Alaska
    I find it funny how when I picked up my truck I noticed they hadn't put the abrasion sleeve on the rope but I totally spaced it and forgot that you have to completely spool out the rope and remove it from the drum to put the sleeve on. Hopefully we don't have to drop the bumper to install the sleeve.
    FarNorthTaco14 likes this.
  20. Jul 15, 2016 at 12:18 AM
    #560
    NickofTime
    Nick
    Anchorage, Ak
    You're friends with Dave Curtiss right?
    Sorry for the thread jack. Was the sleeve not on there before you had it moved into the bumper?
    Edit: the winch was new to the truck wasn't it?
