305/65/17
Discussion in 'Wheels & Tires' started by solus, May 10, 2010.
  1. May 22, 2010 at 2:16 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    Colt...LUCKY...lol. mine ran $200. that coupled with needing to trim some inner fender and beat back that pinch weld, should have no rubbing w/ the 315/70/17. only rub w/ different circumstances on the fender pinchwelds right now
  2. May 22, 2010 at 2:22 AM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    Well I didn't have mine rebox welded...thats mainly for aesthetic purposes plus I knew the guy at the shop :eek:
  3. May 22, 2010 at 2:23 AM
    The_Hodge
    SC
    i did...now i dont feel so bad :D
  4. May 22, 2010 at 2:24 AM
    ColtsTRD
    Scott
    AZ
    :thumbsup:
  5. May 22, 2010 at 2:27 AM
    ColtsTRD
    Scott
    AZ
    Jamie, what size tires do you run?
  6. May 22, 2010 at 1:24 PM
    The_Hodge
    SC
    i've got a set of 285/75/16 and 315/70/17
  7. May 22, 2010 at 1:52 PM
    solus
    solus [OP] HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    I was thinking of running 305/65/17 which is still a 33" but 12" wide...
    its about a 1/4" smaller in diameter and about an inch wider
    I'm just not sure if they will fit without a cab mount chop... PRS is running them without the chop so I guess they work.
  8. Jun 16, 2010 at 6:41 PM
    solus
    solus [OP] HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    Done... they fit perfect...... with my new RCD lift!
  9. Jun 17, 2010 at 10:22 AM
    cantac09
    cantac09 Official TW Igloo Builder
    Hugh Jass
    Saskatchewan
    tundra
    stock
    any rubbing because i was thinking about getting that size when my duratracs wear out
  10. Jun 17, 2010 at 10:27 AM
    solus
    solus [OP] HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    nope..
  11. Jun 21, 2010 at 12:05 PM
    TacoMIA
    TacoMIA New Member
    Miami
    09 PreRunner SR5
    Hey Mark, after reading thru all the posts on this thread, i was hoping you could clarify for me. what did you finally go with? the 305/65-17s? And if so, how much of a lift? 'cuz that's the exact size i'm thinking of getting but wanted to keep the lift to a minimum. also, do you got any final pics? i followed your pics, but there are like 3 or 4 different trucks on there.
    thanks!
  12. Jun 21, 2010 at 12:20 PM
    solus
    solus [OP] HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    yes I did... I got 305/65/17 BFG A/T
    I already had a 3" lift (OME 885 w/ 1/2" spacer, Bilstein 5100s, Toytec TSB AAL)... decided to dump that and went with a RCD 4.5" lift kit
    figured I didn't want to chance whether or not the 305s would clear w/ just 3"...
    with 305/65/17 and RCD kit
  13. Jun 21, 2010 at 12:23 PM
    sandman427
    sandman427 KR FAB
    Amir
    WAY THE HELL OUT THERE, So Cal
    BAMF TACO!!
    2 ten inch kicker cvt subs, pioneer deck and alpine 1000 watt class D amp, and flowmaster exhaust, 4 inch camburg lift spindles and my coilover is adjusted to 1" (5inch total) in front and 3" All Pro leafs, KING off road racing reservoir shocks and coil-overs, KR FAB CUSTOM BUMPER with three 9" HELLA 4000 Race LIGHTS , HID headlights with rigid amber LEDs , "KR Fabrication" custom built bumper, sliders and tiregate, Full size spare with matching rim, custom bed bar with two amber off road lights, cb radio, also BHLM (thanks Ray), and debagged
    looks good bro...
  14. Jun 21, 2010 at 2:34 PM
    solus
    solus [OP] HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    thanks
  15. Jun 21, 2010 at 2:58 PM
    #35
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    i just lookded it up on the tire calc...the 305 65 17 is actually a smaller tire than the 285 70 17. doubt you will have problems
    -----wait you already know that. didnt read far enough
  16. Jun 21, 2010 at 3:16 PM
    #36
    solus
    solus [OP] HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    yeah but they are a wider tire and thus when you turn you will rub the cab mount or atleast thats what would have happened on my truck prior to the new lift
  17. Jun 21, 2010 at 3:27 PM
    #37
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    ahh gotcha. is this the tire size everyone has that has there tires sticking out a couple of inches outside of the fenderwell?
  18. Jun 21, 2010 at 11:10 PM
    #38
    solus
    solus [OP] HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    nope, its all in the backspacing of the wheel, or they use wheel spacers
  19. Jun 21, 2010 at 11:31 PM
    #39
    Its_Taco_Time
    Its_Taco_Time Well-Known Member
    Yorba Linda
    07 Tunda DC TRD Offroad
    CST spindles, Magnaflow, TRD intake
    Just saw this...for the record 305/65/17 rubs like hell on my cab mounts with a 3" lift. I had to trim up my flares pretty good too.
  20. Jun 21, 2010 at 11:37 PM
    #40
    solus
    solus [OP] HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    ^good thing I didnt get them when I had 3" lift
