305/75/16
Discussion in '1st Gen. Tacomas (1995-2004)' started by asdf, Oct 27, 2009.
  1. Oct 27, 2009 at 7:37 PM
    asdf
    asdf [OP] Well-Known Member
    Charleston, SC
    03 PreRunner
    3" in front, stock in back, 285/75/16 BFG KM2,5% tint all around, UWS black low profile, DTRL,line-X, deckplate...
    is it possible to run a 305/75/16 with a 4 in lift? how much trimming will need to be done?
  2. Oct 27, 2009 at 8:24 PM
    asdf
    Charleston, SC
    03 PreRunner
    on stock rims will they rub UCA?
  3. Oct 27, 2009 at 8:31 PM
    ttylerr
    ttylerr Well-Known Member
    Tyler
    Fort McMurray, Alberta
    09 MGM 4Banger 4x4
    5% tint all around, Alpine IVA-W505, 16x8 Mojave Teflon Rims w/Hercules Terra Trac 265/75, Grillcraft Grill, Slimcubby HIDs, Front 5100's @ 0 w/Eibach 1.6" springs, URD Short Shifter, Extang Trifecta Tonneau Cover, Uniden Pro510XL and K30Mag Mount, Relentless Fab Bumper soon to come
    305/75/16 is a 34" tall, 12" wide tire... i don't even think they will fit on stock rims. stock rims are only 7" and you would have huge rubbing issues without wheel spacers and still likely have to do major trimming. not 100% on a first gen but for sure on a 2nd gen taco
  4. Oct 27, 2009 at 8:49 PM
    Dellosa89
    Dellosa89 Love peace and Taco Grease
    Brian
    Murrieta CA
    07 Prerunner TRD Off Road
    Fox 2.5 Coilovers, Camburg 1.25" UCA's, Icon RR, Icon aal,EVS foam bump stops, Borla Catback, HID Headlights and fogs, Defiant light bar, 3 hella 700 hid, Satellite Radio, Sony hu with 10'' sub, custom jetski rack, TRD seat covers, secondary air filter removed.
    Why not just go with 285/75/16 33"tire, It will look good with the 4" lift.
    Also what are u doing to get a 4" lift.
  5. Oct 28, 2009 at 4:24 AM
    tacoman101
    tacoman101 Well-Known Member
    scott
    vermont
    2001 Tacoma sr5 xtra cab 4wd
    blue led headlights, 285/75/16 grabber AT2's, custom pedals, custom shifter, flowmaster 40 series muffler, bedlinered fender flares, 2.5" lift kit via shackles and spacers, custom exhaust out the back, chrome exhaust tip, and Herculined bed, Weathertech floormats, Cabelas Trail Gear Camo Seat Covers ... Nice thing was I got the truck for $4000
    thats the set up im running but with only 2.5 inches of lift, and there is barely any rubbing
  6. Oct 28, 2009 at 9:54 AM
    asdf
    Charleston, SC
    03 PreRunner
    cause i have someone that wants to give me 4 BFG all terrains for 10 bucks a tire that have 50% tread left and are in perfect condition. but he needs them gone quick so he can get his muds put on. they are 305/70/16 and i need to know if that would fit so i can get them soon
  7. Oct 28, 2009 at 9:57 AM
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue 5.3l v8 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 37/12.5/17 mickey thompson baja atz Allpro hybrid bumper grill craft grill wicked flow muffler inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    just buy them only 40 buck if it doesnt work you can resell them most likely for even more
  8. Oct 28, 2009 at 10:28 AM
    MiikeyD
    MiikeyD The Green Machine
    Upland, CA
    Green Prerunner DC 2.7L
    Suspension / Wheels / Tires 3.5" Fabtech lift w/ AAL 265/75/16 BFG A/T American Racing Baja Audio Alpine HU CDA-9886 Kicker DS650 Z-Edition 1000W Memphis M3 US Amps 4000W 2.5Farad Cap Lighting 6000K HID 2 Hella 500FF 2 Aux Bed Lights 2 Aux Driving Lights Performance Volant CAI Flomaster Super 44 Doug Thorley Long Tube headers (coming soon) NGK Iridium Sparkplugs Accessories Scanguage II Cobra LTD27-NW with 3' Firestik Radio Shack Triple Trunking Scanner Harbor Freight Hi-Lift Cosmetics Flat Black Bumper Trim Flat Black Grill Surrounding with Satoshi Clear Corners Future Modifications (not specific) Longtravel w/ king shocks or fox Caged bed Shackles rear suspension. Fox / king shocks custom front bumper Custom Glassworks extreme kit for 01-04 (only have hood and passenger side.. need driver panel) Supercharger + 8port intake manifold optima yellow top battery remounted new rims caged interior rear bench removal 4 sparc
    they 305/70/16 or 205/75/16? arent the stock tires xxx/70/16?
  9. Oct 28, 2009 at 5:02 PM
    tacomaholic
    tacomaholic Well-Known Member
    i got them on 6 in lift and dont rub
  10. Oct 28, 2009 at 7:35 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    305-70-16 and 315-75-16 will fit on a 4" drop bracket lift on the first gen trucks... while the geometry of the lift will keep the sidewall away from the UCA, you may end up with rub on the frame rails at full turn and articulation... your best bet is to run 4.25" or 4" backspace...
    285-75-16 will fit on a 3" suspension lift with a backspace of 4"
    the first gen trucks are completely different in wheel well clearance than the newer gen trucks...
  11. Oct 28, 2009 at 7:40 PM
    Dane-Taco
    Dane-Taco Well-Known Member
    Justus
    Wasilla, AK
    '10 Doublecab 4x4 TRD Off-Road
    Bilstein 5100s set at 0, OME 886 coils, Camburg Ball-Joint UCAs, 295/70/17 Nitto Trail Grapplers on 17x9 Moto Metal 957s, 2" Tuff Country AALs, SX8000 Gas Shocks (Rear), Homemade Satoshi Grill, Redline Hood Struts, Locker Anytime Mod, Map Light Mod, Diff Breather Mod, Fog Lights Anytime Mod, Extra Bed D-Rings, Sock's Badges and Decals, PIAA 520's, Illuminated 4x4 Switch Mod
    2nd Gen TRD, 265/70/16
  12. Oct 28, 2009 at 9:53 PM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    yah, u would think that when they built a bigger tacoma, they would have designed a lil more clearance or proportionately the same as the first gen tacos...
