30K Service - Spark Plugs?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tcbe6472, Dec 20, 2010.
  1. Dec 20, 2010 at 10:21 AM
    tcbe6472
    tcbe6472 [OP] Well-Known Member
    Tommy
    Lake Jackson,TX
    09 TRD
    My 09 is coming up on the 30K mile service and noticed the service manual suggested spark plug change??
    My question is simple, who has done this and was it worth the extra$$
  2. Dec 20, 2010 at 10:22 AM
    NWtacoma
    NWtacoma Well-Known Member
    Kent,WA
    2011 TRD Sport 4x4
    265/70/17 bfg AT
    i had it done at the dealer :-x
  3. Dec 20, 2010 at 10:23 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Did my own 30k service and did not change the spark plugs. Seemed like a waste of money to me.
  4. Dec 20, 2010 at 10:24 AM
    Mark C.
    Mark C. If you want it bad, you usually get it bad!
    Mark
    Connecticut
    2010 MGM SR5 4WD AC
    LED Dome, Reed Switched LEDs in Glove Box and Center Console, Bumper Fogs, Tailgate anti-theft, LEDs over Cig lighter, Back-up camera anytime, Outside Temp add-on, Hidden GPS power, Sockmonkey 3rd Brakelight decal, 4X4 switch illumination, reed switch controlled engine compartment Flood LEDs, Elite Hitch Cover, Plasti-dipped cupholders and door switch control panels, Elite Hitch Cover.
    Got 34k on mine and haven't yet. Guess I oughta pull 'em and take a look.
  5. Dec 20, 2010 at 10:44 AM
    tcbe6472
    Tommy
    Lake Jackson,TX
    09 TRD
    Thanks for the quick replies.. Sounds like it would be a good idea t change them myself. I think the dealership quoted something like $225 to change them which is freakin crazy..
  6. Dec 20, 2010 at 10:45 AM
    AZBACKCOUNTRY
    AZBACKCOUNTRY Well-Known Member
    Doug
    AZ-between the hammer and the anvil
    11' AC TRD OFF-ROAD 4x4
    Pelfreybilt front aluminum bumper,AVID off road weld on sliders, RCI Offroad IFS & transmission Skid (steel), RCI LCA skids (aluminum),upper grillcraft, relentless hi clearance bumper,OEM color matched front grill color, ARE MX camper shell, wet Okole realtree seat covers,pelfreybuilt hi lift mounts,ICON 2.5 Coil-overs extended,, ICON tubular UCA's. Allpro expo leafs, SS extended brake lines.Bilstein 110 extended rear shocks.prinsu Cabrac.dwreck pod mounts OKLED 18w cubes.Baja Designs Squadron-R Sport, LED Wide Cornering, Ambers fog/driving 20" IGGY LED Single Row bar.tepui awning,rotopax 2 gallon, TREDs and mount , 100 watt renogy solar panel.victron 20 amp Bluetooth charge controller,Pro comp wheels - cooper st maxx 285/75/16 tires. Skygear bussman fuse relay smart box. ARB 12v plug hard wired for ARB fridge. Pelfreybilt gas tank skid. Smittybilt X2O 10K winch
    oh and throw a bit of anti-seize on there. You won't be sorry- that stuff works!
    Azbackcountry
  7. Dec 20, 2010 at 11:23 AM
    SlurpeeBlueMetallic
    SlurpeeBlueMetallic FFFFFFUUUUUUUUUUUUUUU...
    This.
    Definitely do it. Use the recommended plugs (they're cheap) and save $200 over the abso-stupid dealer quote.
    I did mine at 28k using Chris4x4's write up linked above... took a little over an hour. A couple of things I learned while doing it:
    - I used a 15" extension for most of the work (just gave a better reach) with a 3" and 6" in tighter spaces...
    - Tape your plug socket to the end of the extension... sucks to pull the wrench back and have it not come with you :(
  8. Dec 20, 2010 at 12:07 PM
    guitars&tacos
    guitars&tacos Well-Known Member
    North Metro Atlanta
    2018 White TRD 4x4 Off Road 6 MT
    I always say that someone put it in the book to do for a reason so do it. I did mine at 37K miles and it took 1 hour and was not hard. Plugs costs less than Chinese takeout. Its a no brainer to me. I didnt notice any difference in my truck to be honest.
  9. Dec 20, 2010 at 2:19 PM
    jg7
    jg7 Active Member
    Just changed the plugs in my '05 4Runner today. (same 1GR-FE V6 engine)
    It had the factory plugs and 67500 miles. I saw something about 30K service (DOH!) on here and went to change them ASAP.
    When I pulled them out, they all looked well used and the gap was about .060" (.041" new), but nothing I would normally be overly concerned about. Advance Auto didn't have the OEM copper plugs so I just got the cheapest Denso's they had and they were $2.99 each (platinums I think).
    I don't notice any difference in how it runs, nor do I think it is critical to replace them like clockwork every 30K like an oil change. However it is cheap and easy to do so why the hell not? Good excuse to clean up the engine and inspect for other issues. Toyota is making $$$ on this deal and insuring they don't have to replace any emissions components under warranty.:p
  10. Dec 20, 2010 at 2:35 PM
    joerussell610
    joerussell610 When all else fails read the directions
    Him
    Making myself at home in your house
    2005 DC Sport Edition 4x4
    K&N, fog light mod, remote rear halogen fogs mounted under rear bumper, TRD skid plate, Flux Capacitor, Mr. Fusion upgrade soon
    Do any of you guys do the top engine service or Induction service before replacing the plugs? If you dont it is well worth the cost of the kit from Toyota to perform it. Runs smoother, starts right up. Need to do it before replacing plugs.
  11. Dec 20, 2010 at 2:37 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Yeah the dealer was asking for like $150 to change mine out!! I was like screw that!! I still need to swap out my plugs cause I am going on 39K.:cool:
  12. Dec 20, 2010 at 7:55 PM
    SlurpeeBlueMetallic
    Haven't heard of that kit before... got any part numbers or links to it?
  13. Dec 21, 2010 at 5:24 AM
    boxxed
    boxxed Well-Known Member
    Denver, CO
    09 Off Road
    I just want to make sure that this part number is the correct plug to use for my 09 trd off road. Owners manual says: K20HR-U11
    Thanks
  14. Dec 21, 2010 at 6:07 AM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    I assume you have the V6...
    It's an easy DIY...really easy. And cheap: you can get plugs for under $2 each.
    The V6 has copper plugs that wear fast but as others have noted you don't have to change them. Some people have gone up to 50k on them, but you can be sure they aren't firing as hot or efficiently as new..
    I pulled mine and re-gapped them at about 25K. They'll go to 50K I'm pretty sure but at least they'll work better for me.
  15. Dec 21, 2010 at 6:22 AM
    Dadic 78
    Dadic 78 Well-Known Member
    Fil
    Edmonton, AB CANADA
    08 Double cab TRD
    Honestly, they're cheap, it only takes about 1.5 - 2 hours to do it yourself, and it's what the manual suggests, so why not do it?
    I just changed mine, and my gap was out to .055 from the suggested .041
  16. Dec 21, 2010 at 9:36 AM
    SlurpeeBlueMetallic
    If you're going to go through the effort to pull them, why not put in new ones? They're cheap, even if you are set on OEM and have to pick them up or ship via e-Bay.
  17. Dec 21, 2010 at 10:57 AM
    JKD
    JKD Well-Known Member
    I've had no luck finding a place that carries the Denso plugs. We have Autozone, CarQuest, NAPA, Wal-Mart and O'Reilly. None of them carry regular Denso plugs. Looks like I'm going to go with the NGKs instead.
  18. Dec 21, 2010 at 11:08 AM
    tegdog
    tegdog Taco Lover
    Indiana
    09 Tacoma Dbl TRD Sport
    ventvisors,seatcovers, bug shield,TRD CAI,TRD CAT BACK,blacked out emblems,bed extender, TSB leaf pack,Pro Dry filter, Grill craft upper, lower, & triangles, Hella 500 Black magics
    I was just thinking the same thing myself.
  19. Dec 21, 2010 at 11:24 AM
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    i have 68,000 miles on my truck and i still havent changed my plugs. no probs yet, but i am planning on changing them soon. anybody have experience with iridium spark plugs? are they any better?
  20. Dec 21, 2010 at 11:37 AM
    MAXTacoma
    MAXTacoma Well-Known Member
    Lexus GS 350
    75k on the original plugs, probably should replace them soon.
