30k service
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NewGuyJosh, Aug 24, 2016.
  1. Aug 24, 2016 at 11:15 AM
    NewGuyJosh
    NewGuyJosh [OP] Well-Known Member
    I have a 2014 double cab offroad and am coming up on my 30k service. I called the dealer today to inquire about what is supposed to be done and they stated the following:
    Oil change, tire rotation, "More thorough inspection", replace cabin filter and air filter.
    The cost for their service was $225 or they would sale a service planned that covered up to 45k service for $299. I offered to change the filters myself and the price was going to be $70 for oil change, rotation and inspection.
    When I look at the schedule A in the manual it says that it should also include lubricating propellar shaft and re-torqueing propelling shaft bot as well as replacing the spark plugs.
    So what really needs done at the 30k service?
  2. Aug 24, 2016 at 11:18 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    The last paragraph would be a good idea.
    asuchemist likes this.
  3. Aug 24, 2016 at 11:22 AM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    The 4.0 V6 requires a spark plug change at 30k. The 2.7 I4 does not. The prop shaft requires grease every 15k if it has grease fittings, but most people lube those at every oil change.
  4. Aug 24, 2016 at 11:23 AM
    NewGuyJosh
    So is it worth it to buy the service agreement for the next 4 services if they cover everything the book says? Do most people just do it themselves after the free toyota care changes end?
  5. Aug 24, 2016 at 11:27 AM
    NAAC3TACO
    2014 SR5 DCLB 4x4
    I personally did not even use Toyota care. The oil changes and tire rotations are so easy that I just do it myself.
    Lester Lugnut likes this.
  6. Aug 24, 2016 at 11:32 AM
    PaulHarke
    PaulHarke Member
    Paul
    Goodyear, AZ
    2005 Tacoma Prerunner
    the toyota care plus plan for 30k service includes, oil change, rotation, spark plugs, rear diff fluid changed, air filter, cabin filter, rear brake clean & adjust, and just ask them to grease the shaft while performing the service if you do purchase the plan. shouldnt charge you in my opinion.
  7. Aug 24, 2016 at 11:33 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    That's really not too bad a deal. I mean the inspection in NY is $37, so for another $33 you get an oil change and rotation. Seems solid.
  8. Aug 24, 2016 at 12:13 PM
    Mr.Gadget
    Mr.Gadget Well-Known Member
    NC
    2011 DC 4x4 SR5 SB/2012 DC 4x4 SR5 LB(sold)
    That Is what they said mine needed at the time and said it was a 700 plus $ to do it.
  9. Aug 24, 2016 at 12:16 PM
    JD_P
    JD_P Well-Known Member
    Terrebonne, Oregon
    2015 TRD Off Road Access Cab
    Same here as well as rear diff oil change. I will do the plugs soon. I am no mechanic, but these things were pretty easy to do.
  10. Aug 24, 2016 at 1:52 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    If you can, lube the u joints every oil change. I thought all the diffs and transfer case, if equipped, were also to have fluids changed at 30k.
  11. Aug 24, 2016 at 2:07 PM
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    Prerunners have no fittings to grease in the drive shaft.
  12. Aug 24, 2016 at 2:10 PM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    Plugs and rear differential fluid. Grease zerks on drive shafts. Oil, filters (oil,cabin,air)
  13. Aug 24, 2016 at 2:30 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    If you wanna save yourself some dough, do the oil change, cabin air filter, engine air filter, and rotate tires yourself. Probably do everything for about $50 total with some elbow grease.
    You can change your own spark plugs for about $15 depending on if you have the tools ( which you can always borrow from autozone). Although my opinion changing these at 30k is overkill. Probably can easily wait til 40k or 50k.
  14. Aug 24, 2016 at 3:27 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Not true.
    Prerunner owners need to check for grease fittings.
    Mine came from the factory with zerks in the universal joints.
  15. Aug 24, 2016 at 8:07 PM
    dawgn86
    dawgn86 Well-Known Member
    2013 Toyota Tacoma
    My pre runner has 3 zerk fittings on the drive shaft
  16. Aug 25, 2016 at 4:06 AM
    ARB1977
    North Texas
    I didn't see any on my base SR5.
  17. Aug 25, 2016 at 9:28 AM
    GTOJim
    GTOJim Well-Known Member
    Jim
    SF Bay Area
    2013 PreRunner TRD OffRoad V6
    I purchased the dealers $299 service package, at 20K the service writer kept insisting on doing the 30k. I kept saying no, then he said it's your truck and you can do whatever you want, like something bad was going happen.
  18. Aug 25, 2016 at 9:43 AM
    NAAC3TACO
    2014 SR5 DCLB 4x4
    He's on commission.
    MadDaddy, Lester Lugnut and big_jarv like this.
  19. Aug 26, 2016 at 7:26 AM
    tacomanewhampshire
    tacomanewhampshire New Member
    In regards to changing the spark plugs at 30k, you'll notice the manual (at least for my V6) has a footnote (4) which says it is required for the 'terms of the Emissions Warranty.' Turns out that warranty is only good for 2 years and 24,000 miles. I'm no mathematician but, "hey Toyota, that already expired 6,000 miles ago!" Another car manufacturer scam debunked. Might want to keep working harder on those 'sticky' gas pedals.
    That being said, the warranty does also note that certain items are covered for 8 years / 80 k if you change spark plugs at 30k and 60 k. The only significant one being the Cat Conv.
  20. Aug 26, 2016 at 7:36 AM
    dtopgun515
    dtopgun515 Well-Known Member
    Darrell
    Hey Yall Georgia
    13 TRD Sport
    5100's up front set to 1.75, SCS Stealth 6 wheels, Nitto Terra Grappler AT's
    65k, haven't changed mine yet. Just went on a trip to Florida and averaged 20 mpgs...
    JSU likes this.
