32" LED Light Bar Mounts - Stealth and Flush for 3rd Gens
Discussion in '3rd Gen. Tacomas (2016+)' started by MojaveMadman, Dec 22, 2015.
  1. Jan 23, 2016 at 12:55 PM
    #121
    Tacoma2GR
    Tacoma2GR Well-Known Member
    Hesperia, CA
    2020 TRD Sport 4x4
    What are those two back plastic boxes in the pictures
  2. Jan 23, 2016 at 1:09 PM
    #122
    MojaveMadman
    MojaveMadman [OP] Cali Raised LED
    Los Angeles, CA
    2010 Tacoma TRD OR
    All New Everything
    Those are the air dams that sit on each side of the grill area. You will have to trim them in order for the LED and mounts to fit in there. It is done very easily and the way it is trimmed, none of the mounting points are removed, just the flap that hangs down into the lower grill that just got filled with the LED.
  3. Jan 23, 2016 at 1:42 PM
    #123
    fxrman
    fxrman Well-Known Member
    palm springs
    Quicksand 2016 trd double cab off road
    OVT 1.03 Tacoma bed matt Husky floor liners Insain fab aluminum bumper with Baja design s8 30" light bar DB custums grill with Baja design s8 30" light bar
    This might be tough as I'm going to the dealer on Monday morning to sign all the paper work and hopefully pick up my truck...!!
  4. Jan 23, 2016 at 1:45 PM
    #124
    fxrman
    palm springs
    How do i send you a PM..??
  5. Jan 23, 2016 at 2:53 PM
    #125
    MojaveMadman
    Los Angeles, CA
    2010 Tacoma TRD OR
    All New Everything
    Click on my name and select "start conversation."
  6. Jan 24, 2016 at 10:46 AM
    #126
    octaco0623
    octaco0623 Active Member
    California
    Anybody know of anyone whos installed a 50in curved light bar on the upper windshield of there 2016 tacoma?? I'm curious if anyone has done it yet. I'm waiting for my bar and brackets to ship.
  7. Jan 25, 2016 at 8:20 AM
    #127
    MojaveMadman
    Los Angeles, CA
    2010 Tacoma TRD OR
    All New Everything
  8. Jan 27, 2016 at 2:38 PM
    #128
    Krezz
    Krezz Well-Known Member
    Kevin
    Ontario, Canada
    '18 Tundra Platinum Crewmax
    All mod's listed on website - regarexpeditions.com
    If the air damn (which is already removed from the OR) is just taken off the truck, would that eliminate any need to file or trim anything? I ask, as mine is a leased vehicle and most of my mods thus far, can just be removed and then reinstalled onto my next Tacoma.
  9. Jan 27, 2016 at 2:40 PM
    #129
    MojaveMadman
    Los Angeles, CA
    2010 Tacoma TRD OR
    All New Everything
    The air dam is the only thing that needs modding. So yes, you can just put them on the shelf if you want. Or see how much a new one costs... maybe $40 from the dealer down the road...
    Krezz likes this.
  10. Jan 31, 2016 at 10:15 AM
    #130
    Woody79
    Woody79 Well-Known Member
    Kevin
    Utah
    2016 DCSBOR 4x4 Quicksand
    Icon Stage 2 TRD Pro Wheels 285/70/17 BFG KO2's Header Rail Extang Solid Fold 2.0 Tonneau Cover
    I'll let Chris post the full update and details but as expected the testing for the Flush mount brackets went great this week. Install was easy and I love how beefy his brackets are. I also purchased the Cali-Raised single row LED through Chris as well. I'm super impressed with the quality and brightness of the LED and the included harness works really well and saves a ton of time. Here's a quick teaser pic of the single row LED flush mounted with his brackets:
    RNJNKE and ridez like this.
  11. Jan 31, 2016 at 11:55 AM
    #131
    Woody79
    Kevin
    Utah
    Also, I thought I'd do a quick write up on wiring up the LED to a factory style switch. To start, I bought this Mictuning switch from Amazon that fits the factory blank on the left side of the wheel. I also bought a really nice little relay holder directly from Cali-Raised here that holds up to 3 relays and bolts on the inner fender into factory threads not being using next to the battery. The Cali-Raised LED comes with a nice wiring harness, relay & fuse so other than some misc type wiring connectors you shouldn't need anything else.
    Step 1: Mount your relay in the desired location next to the battery. This will help determine how much you can cut off some of the other cables as they are plenty long. There are lots of ways to do this but as I mentioned above I used a relay bracket to make it bolt on easy and provide for expansion in the future:
    Step 2: Route the thick red/black power wire for the LED along the fender and down to the LED. There are lots of places to zip tie to and you should be able to route it nice and clean. Cut to length. I cut off the spade terminals that come on the harness as I don't see the need to unhook the LED in the future and it's just one more connection that can fail. This is nice, thick 14 AWG wire so you'll need the BLUE connectors. I like the weather tight version as they include built in shrink tubing and prevent bad connections down the road:
    Step 3: Cut off the switch from that came with the Cali Raised harness. I cut off the white connector and all as you won't need it and it makes it easier to fish the wire through the firewall:
    Step 4: Fish the wires (white, blue, black) that will go to the switch through the firewall. I chose to go right next hood latch cable and was able to push right through the rubber grommet in the firewall using a hanger. Then I taped the wire to the hanger and pulled from inside the cab:
    Step 5: Remove the lower dash panel from below the steering wheel. This seems much harder to do than it actually is. Just bite the bullet and pull it down, it makes life WAY easier on the next couple of steps and if you don't you will risk scratching the dash or breaking tabs trying to access the switch. To do this, remove the sill plate by the door (it just pulls straight up on tabs), next remove the kick panel (1 thumb screw and 2 tabs - pull towards the center console). This will expose a bolt behind the top of the kick panel that needs to be undone. Then undo the other 2 bolts that are visible. Next, just simply start pulling down on the dash panel, it's held in by 11 clips, they won't break and come out easy. *Note the knee airbag will stay in place so no need to mess with it:
    Step 6: Wire up the new switch. This is also easier than it seems. The Mictuning switch comes with a wire harness with 4 wires. 3 of the wires go to the white, blue, black that you fished through the firewall and 1 wire will splice into the Cargo Lamp switch on the dash. Here's how you should wire it:
    GREEN = WHITE
    RED 1 = BLUE
    BLACK = BLACK
    RED 2 = GREEN WIRE ON CARGO LAMP SWITCH
    Step 7: Plug in the switches and put the dash back together. Should look like this:
    Step 8: Finish wiring the relay by hooking up the short RED wire with the in-line fuse to the battery and the short BLACK wire with the ring to the grounding strap:
    YOUR DONE!!! The switch has 2 bulbs inside. 1 will illuminate when your parking/dash lights come on. The other will illuminate when the Switch/LED is in use:
    MasonSTL, chiefjim, Radtrd and 25 others like this.
  12. Jan 31, 2016 at 12:41 PM
    #132
    JDO16 Taco
    JDO16 Taco New Member
    David
    Bucks County, PA
    2016 Silver Tacoma TRD Off-Road
    Great tutorial, Kevin. I have a similar setup coming from Chris and this will be very helpful!
  13. Jan 31, 2016 at 1:52 PM
    #133
    Buddha717
    Buddha717 Well-Known Member
    Ron
    Harrisburg, PA
    2016 Inferno Tacoma TRD sport DCLB PTJBL
    Fantastic tutorial. Great photos too. Thanks. I'll be installing mine when it comes in. What grill are you running?
  14. Jan 31, 2016 at 1:55 PM
    #134
    Woody79
    Kevin
    Utah
  15. Feb 1, 2016 at 8:42 AM
    #135
    MojaveMadman
    Los Angeles, CA
    2010 Tacoma TRD OR
    All New Everything
    Ok here is the long overdue Flush pictures and info. Two of these have been mounted now and they are awesome! I am taking pre-orders on these until the 5th of Feb and have 9 remaining at the pre-order pricing.
    I tested with two different LEDs. The top one is a Baja Designs 30" Stealth and the bottom one is the Cali Raised Single Row Spot. Both are great LEDs. It is hard to see from the pictures but you will have to cut out the slats in the grill and when I did the Baja Designs one, I had to make the opening a little bit wider. I did learn that this plastic cuts very easy with a sharp knife. I used my Kershaw pocket knife and it made very nice straight and clean cuts. This install is straight forward and the hardest part is putting the bolts in the LED, it takes a little patients as it is a tight fit. But if I can get my hands in there, I know it will be something any of you guys can do! Enjoy the pictures and please let me know if you have any questions!!!
    76DC666C-0D39-4B8F-812F-078AB6015A23_zps_57aef4b82a36e6b439b2adbf49fd15bb07f0fc6e.jpg
    EC7F2E98-994E-4768-A168-D88A6A68120B_zps_0a41f5e1b8381f45be35a68d7310fc8aae3b2fba.jpg
    15DB138A-B78B-450E-93D4-CC6B6C5EF59C_zps_ea7174c73ee5773be0ef1e45a2b5fcd86e3095bd.jpg
    DD174477-7B8D-49D7-929C-878E09D1DB4F_zps_5b7d0aaf5dbae8284b9b6c88da25184555b9cf22.jpg
    Parker315 and Woody79 like this.
  16. Feb 4, 2016 at 8:09 AM
    #136
    jrlin718
    jrlin718 Well-Known Member
    Jonathon
    Louisville, KY
    2016 TRD Sport Barcelona Red 4X4 Double Cab
    Plastidip front grill and badges Bilstein 5100 shocks set at 0 OME 888 coils Lights Racing UCAs Headstrong AAL TRD Pro Wheels Matte Black BFG KO2 275/70/17 Rocky Mounts DriveShaft SD KB Voodoo Bed Rack ECGS 8 in clam shell bushing Custom Bedside Decals TRD MTB Edition CBI front bumper CBI rear high clearance bumper CaliRaisedLed 20 in single row bumper ARB CKMA12 Air compressor
    Do you still have any available for the preorder?
  17. Feb 4, 2016 at 8:13 AM
    #137
    MojaveMadman
    Los Angeles, CA
    2010 Tacoma TRD OR
    All New Everything
    Sorry all pre-orders are sold. I will begin taking orders again next week once I get all my parts welded up and at the powder coater.
    Krezz likes this.
  18. Feb 4, 2016 at 8:15 AM
    #138
    Buddha717
    Ron
    Harrisburg, PA
    Hey Chris. Do you have an expected ship day for the stealth brackets?
  19. Feb 4, 2016 at 8:16 AM
    #139
    MojaveMadman
    Los Angeles, CA
    2010 Tacoma TRD OR
    All New Everything
    Estimated ship date is 12 Feb 2016. However, there is a chance one of my laser cut packages will arrive today! If I am that lucky, then I will weld up everything tonight so I can get them to the powder coater tomorrow. Should allow me to get things out a few days sooner.
    Krezz and Gettin Lost like this.
  20. Feb 4, 2016 at 11:38 AM
    #140
    Krezz
    Kevin
    Ontario, Canada
    Very exciting!! Once this project if complete, I can begin my skid plate adventure. Been talking about this with all the guys I work with also, may have some more orders for you down the line I hope. I love to inspire lol.
    MojaveMadman [OP] likes this.
